D.FYLAKTOS
  1. I never liked the ''bad boy'' hoods and lights cover. Blocked out? You mean this way?
  2. No Vika, it's cheap chinese quality. https://www.b-parts.com/auto-parts/electrical-and-electronic/radiator-fan-skoda-felicia-ii-estate-6u5-13-165959455g-1998-1999-2000-2001-883935 Too expensive !
  3. Amazing but..to much work (i can't do it so i have to pay a repair-shop) plus very high budget. Felicia has 236mm, i have found for Ford Sierra/Sapphire Cosworth 283x24mm (vented) and for the 1.3 model the 240-x13mm I have 14'' wheels but i had to find an ''specialized'' brake repair-shop for installation etc.
  4. Hmm, not enough incoming air to the radiator with this design. I live in a hot climate country so i am not optimistic.
  5. Back then at 2000's was something that was attracting interest but now the company stopped producing aftermarket parts for Felicia https://milotec.de but that grill can still be found https://autodilyfojtik.cz/predni-maska-sportovni-felicia https://www.agauto.cz/15346-milotec-predni-sportovni-maska-skoda-felicia-1997-2000-po-faceliftu-milotec/ https://www.skoda-tuning.cz/produkty/maska-milotec-skoda-felicia-facelift-lim-combi/ I saw that thread while looking for an aftermarket grill although my initial thought was to ''de-badge'' the original and keep the chrome outline.
  6. As we say here ''the Hope dies last". 😉 That was the initial reaction from a mechanic, an innuendo about Ford but he didn't knew at the time which model etc.
  7. Unfortunately we won’t be able to get these as vented discs only because your current setup and callipers are designed to work with these particular solid discs and not vented ones. The thickness between them will be slightly different which would then cause the disc to not fit through the calliper. Sad news, my dream just crumbled.
  8. After the rollover i wanted to ''lighten the climate''. Beyond that i think a strut bar and an anti-roll bar would help a lot a car on the road. The winner is Citroen Xantia.
  9. A member of a local Skoda forum was present that day in that Acropolis Rally and describe to us how the Czechs worked with simple (but effective way) and later how the surprised the whole WRC world with that win.
  10. Which of these 5 designs is the best? The answer is not what an ordinary driver expect.
  11. Mine worked for few years and suddenly stopped so i don't care about it at all because i don't use it. In SP-EL the price is high, does worth to spend so much money plus shipping and installation? I don't know for Cz but for GR definitely not. 😃
  12. https://en.skoda-club.net/manuals.php?ddlb_category=11&ddlb_model=9 I have some other links but not now available.
  13. Here is a list from Mahle https://www.euspares.co.uk/manufacturer/mahle-original/temperature-switch-radiator-fan-10434 click and red the details for each one Switch-on point [°C]: Shut-off Point [°C]: Here in Greece (Hot climate) we use 80-85 C although some owners with older models use 75-80 C (in the second case the radiator fan will work more often but in shorter time)
  14. My latest Cold start were one click better than previous, maybe the ECU remembered the good old times with NGK lambda and Champion spark plugs. After the trip i made another Gas station pump test. 8] 360,3 Km distance and 25,08 ltr fuel which means 6,96 ltr / 100 km or 40.58 Uk mpg. The results could be better (yes better) because the air pressure on tires was one click lower and i had some hard traffic the latest kilometres before arrive at home. Now after refuelling i will make at least 100 Km on city traffic and after another gas station pump test let's hope that i will close this chapter.
  15. I think the time has come, a separate ''sub-forum'' must be created with a title something like ''Ask the Master'' or ''The God of mechanics speaks'' or ''the knowledge is ME" ,where the One and Only-Best in the West will give (after the member begging on his knees for answer and pay his respects) an answer which will not doubted for any kind of reason! No matter if the ancient Greek legislator Solon (639-559 BC) said ''“Γηράσκω αεί διδασκόμενος” which can translated ''I am getting older always learning" here we have the exception which is a World phenomenon. So, from now on ALL the Skoda owners in countries with warm climate must prevent for the radiator fan running too often. Why? Because when the radiator fan in high environment temperatures works often will damage your engine-make it overheated or explode etc, is that clear? Yes. Any doubts? No..who would dare after all?
  16. I asked you many times to put me on your Foe list and you didn't had the guts to do it, so here is your chance, for once in your life act like a Man and do it. If you ask ''why you don't do it?'' the answer is ''i have done it in the past but you still made quotes in my posts'', so let's do it now together and case closed. Somehow or other you have turned 99,99% of the members here against you with that ''smart @ss'' attitude plus you do not admit your mistakes. You are just a simple common mortal as all of us, you will never-ever be something special and you will never-ever you receive some recognition-distinction.
  17. For decades the Bosch Household appliances (washing machine, refrigerator, etc.) were made by a local company PITSOS but many people thought that they were manufactured 100% in Germany. As for vented discs i will ask some other repair shops next week IF a pair of 20mm can fit in my stock calipers or the whole project does not worth the effort, it's a pity that when i had the money i didn't had the opportunity to search for a 4 piston calipers.
  18. So you don't suggest to buy brembo discs next time? Any thoughts about Zimmermann?
