Škoda Felicia @ Nürburgring
UP ON THEM ! The @Thefeliciahacker will get a heart attack if he sees this.
Skoda Felicia Has Issues Starting Up at Specific ECT
Fuel pressure measured via FP gauge ? Maybe the regulator does not work properly.
How you measure this? Fuel filter is OK?
Skoda Felicia door light switch
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe socket had not enough cable to come out to work properly, i was afraid that if i was pulling it could made a danage.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAs for the plastic cap of course it's removable. I didn't wanted to buy only this (even as a Used part) because the switch was a bit damaged. ________________________ This is the switch from Alhambra Ibiza Inca Cordoba , similar and you can see the 3 pins and the < > clips better, totally 4 parts.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe problem was that there was not enough cable to pull out to install the new switch, i tried but failed. It was dark, cold and i was in a hurry and i didn't wanted to push things more (i was in the country and no car electrician close by) so i made a patent, put a screwdriver between the car body and the red socked so there would be enough resistance. This was i manage to make the ''click'', i push it back gently, it buttoned i made a test with he interior light and everything is fine. The photos are not good but i had no time for better but you can take an idea. Has any other fellow Skodian had the same problem with me? It's indeed not enough cable down there or it was just mine? I wonder in the drivers door things will be again so ''tight''?
In the past i had a problem with my passenger door (interior) light switch, sometimes worked sometimes not. I spray a bit of Contact Cleaner and OK but after some years i realize that it became lose, was a bit slacked but since still working i let it as is. Few weeks ago i realize that the rubber cap was missing, probably from the wiping from the car wash the employee push it and lost. I couldn't let it like this so i ordered from a Cz store the switch, the parts code is 6U0 947 561 A. One night i decide to do the job, i realize that the slacken was because one of the clips was broken, has 2 like < and > shape. I use my fingers to remove the first part (button and spring) but i had to use a bent pliers for the second (with 3 pins like Z style) and the third part revealed with the 3 pins.
2000 Skoda Felica 1.3MPI 50KW
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWhat's your experience in this sector? You know they work from where? I already told you that, you should have done years ago and not now at 2025. Here is the answer from a famous programmer at 2021 as he send it to me:
Battery, starter solenoid-motor are checked? What brand of coolant sensor you have? The yellow one? Have you run a diagnostic test for possible errors?
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanObviously you don't know the local market good enough. ECU chip tuning started in Greece at 1999. The problem is not that there are not good programmers here, the problem is that almost no one now will bother to work with your car since there are thousand other cars (NA or turbo) that waiting and we are talking for 300-800+ HP. Some have ''plug and play'' and some ''custom'' especially made for each client.
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanNow but few years back you wanted an ECU chip: 😎
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFelica 1.3 has 236mm brake discs.
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanLet the I.C.E last.
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have tested: Paper filter (factory type) from 2-3 brands, gauze filter (K&N and BMC), POD (cone filter) 2 brands and just for experiential purposes No filter at all. The best results were from the k&N filter, beware to buy one from a local official dealer or a well known store and not from ebay because it's very easy to sell you an imitation. I have also modify my air filter box, i have removed the factory clapet and it's thermostat, make it smooth inside plus an extra hose from the grille to brink more fresh air inside, i kept the factory hose which brings air from the factory bumper. https://www.briskoda.net/forums/topic/514344-engine-cover-do-we-really-need-it/page/3/#findComment-5851822 I have some pictures added. The POD (cone filters) produce a rough sound and that's for show-off only in our car, keep in mind that i have a ECU chip plus custom exhaust from headers to the tail pipe (45mm external).
D.FYLAKTOS replied to vladimirzootin's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHello, i have a Felicia 1.3 ,year 2000 MPI with many modifications (not extreme). There are many sectors so you have to specify which one and your budget. Keep in mind that there are some restrictions here in GR so for example i can not say anything about an engine swap because it's illegal here and won't pass the MOT nominally but in other countries you can do it. By the way where are you come from?
oil filler/rocker box cap
I have bought a new one few years back 047103485 You can keep the original and buy a new rubber seal from a Skoda dealer or Skoda parts shop.
Looking for a blower/heater motor possibly?
You mean the No22 ? You don't have a/c ?
I have a ''bitter'' experience with water/moisture in my car. Bags this style https://www.planetstore.gr/images/thumbnails/1000/700/detailed/102/96-652.jpg are a bit dangerous because when they get fill with moisture sometimes have a leak all the liquid it pours down. I prefer this type https://expresspoint.gr/wp-content/uploads/2024/09/fe1352d8-154d-4c82-9ba9-76ad9ec41183-e1726769073375.jpg https://b.scdn.gr/images/sku_main_images/024421/24421510/20210319155207_syllektis_ygrasias_1000gr_70701291.jpeg of course with the car not moving. Newspapers below the carpets help a lot.
I think it's Skoda 6U0 819 021 https://www.briskoda.net/forums/topic/359108-heater-blower-problem/ Relative topic. https://www.ebay.co.uk/b/bn_7018908076 https://shop.euroimpex.lt/en/dalis/1257672/heater-blower-assy https://kritosparts.gr/Code/6U0 819 021 Sources for parts.
Skoda Felicia leatherette seat covers
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman2 examples from leatherette seat covers (and not only) from Greece. For sure it's not like real leather but does not cost a fortune like it. By the way i have checked my notes, mine are from January 2016 so i have them for 9 years. 💪
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFor Summer holidays sometimes another bag is added in the back, no problem for the Leatherette seat covers, they can stand the ''abuse".
Favorit Windscreen Wipers and Washers Not Working
Update: I had some years to buy from this shop (skoda-parts.com) and recently i saw two things: 1) the shipping rates are far more less the before, en example 8,7 euros for an order to Greece via courier 2) is related with online-dily.cz s.r.o, the payment goes to skoda-dily.cz In the past i had problem ordering from other Cz stores because they had only the bank Transfer system for payment which meant more cost (commission) and delay for verification etc. Add the delay answering in the email and you have the whole picture but the guys in skoda-parts.com are far more better to do business with.
Skoda Felicia I will make the indicators LED
It's from Skoda Octavia not Felicia, lot of work. https://www.youtube.com/watch?v=njxje8Yt6Yw Here is some relative from Felicia. If you are experienced electrician then go for it, otherwise let it go because many things can go wrong and the remove-install back process isn't easy.
My Felicia has a broken windshield wiper
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have found this video ''too late'' but i think it's good to be here in case of another member wants to remove his own rear wiper motor. Personally i never removed the Securing plate and the Latch (1:43-2:11), no needed.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanRear seats covers. As you casn see also are in almost perfect condition although there were ''used'' a lot. Many times put on them suitcases (luggages), bags, many kind of items (wood, metal etc) from IKEA, small furnitures etc and i have use them in the past for ''adult things'' and still look OK.
