D.FYLAKTOS
  1. Here is the Original (old) and the new VIKA (chinese) As you can see there are some differences. It's not a big issue, i will reverse the plug and let's see how the new fits and works.
  2. Yes, here it is mine. A characteristic example of what's happening here, the cars are parked as they should be and a moron raised the windscreen wipers, imagine this to happen some times more and the driver would have a problem as mine. We know about the term ''bonnet'' but we prefer the ''hood" when we speak about cars although we use the word "hood" when we speak about dress code. 😁 Today was a nightmare, i have installed the new motor but with many difficulties, i will post photos soon.
  3. There are holes in the 5th door (trunk) for the license plate, from the rear badge, maybe there is a leak from the rear windscreen wiper bolt, sometimes the trunk window gasket has a leak (it happened in me too) and water is collecting in the bottom that's why the factory opened 2 draining holes and put a parallelogram nylon cover behind that wooden panel to protect it. Even the other 4 doors of the car have that nylon cover, i will post soon from mine to see it better.
  4. Here an example, it's behind this cover of the trunk door (aka 5th door here in GR) https://d3bsbe39k8p2a0.cloudfront.net/images/product/6/9/2/4/0/28_1800x1255.JPG 097440623 VAG cover for door inner panel rear lid trim panel (leatherette/cloth) https://www.sbazar.cz/tsvoboda.51/detail/175072292-nova-tapeta-5dveri-skoda-felicia-seda-097440623 I put new nylon behind so any rain drops that may pass inside won't touch that wooden panel and will be driven to drain holes that the door has.
  5. Update: I am without rear windscreen wiper for few weeks, i faced rain two times and to be honest my hand reached the lever by habit. Yes, my car is 1% better looking and has 1% better aerodynamic 😄 compared to @Thefeliciahacker car plus i am one click lighter due to the motor-bracket absence so i can beat him (AGAIN) in acceleration and MPG 😁 but i miss that part and i think i am going to buy and install it soon.
  6. I was afraid of this and i asked for a cleaning few years back. Now i am using filter for kitchen hoods as an extra layer which stop everything (hairs, leaves, dust etc) but in my mind i have the thought to make a 3D printing oval shape receiver like a Casserole Dish with ### inside like this and add a filter like this after i cut it properly. For sure it's not like a stock constructior but it's far betetr than sponge.
  7. Yes but what about the leaves, hairs from dogs etc, some of them may pass inside, where end-up? On the evaporator?
  8. The weird is that in User Manual says: "TL-774 C Red colour 50% ratio" but D is red and not C and out engine it's an 1994 design.
  9. At Winter where there is no a/c? They say that moisture on the sponge creates for in the windshield.
  10. Yes but now the water goes in, the plastic tunnel ends inside the cabin (2 holes behind the seats).
  11. So the G11 blue and the G12 red did not cover (at 30%) your expectations and you choose the G13 in the same ratio as better?
  12. You had G11 (Green) before and for many years. For you the ''lowest'' ratio that can be used in Felicia is 30% and the ideal is?
  13. @Thefeliciahacker If you had 30% G11 and 70% distilled water you think could face lubrication and corrosion problems?
  14. The worst temperature all these 24 years for my Felicia was one day only at -4,5 'C in the year 2002 if i remember correct. Today i had a 200 Km trip, half in Mountain Routes and half in Highway (speed 100-120), the needle never touched the 90 'C line in the dashboard gauge, i don't have overheating problems, just that ''concern of mine" in Cold start.
  15. @hzoltaan What gear oil are you using now? Have you ever use an additive like this? https://www.liqui-moly.com/en/pro-line-getriebeoel-additiv-p000070.html#5198 https://www.liqui-moly.com/en/mos2-antifriction-for-gears-p000009.html#tab-label-description-title
  16. If you had 30% G11 and 70% distilled water you could face lubrication and corrosion problems? I think the minimum requirement is 20% antifreeze and covers till -8 'C. I have the assumption that if i have more antifreeze in my coolant (now it's too ''weak'') the engine will get hotter one click faster and will reach the 92 'C sooner than now. I don't know if this is right or wrong, thus i am asking.
  17. @Rooted My primary concern is in Cold start which of the 4 combinations will reach first the 92 'C Watter Wetter says "Improves heat transfer and reduces cylinder head temperature" but in small routes in City i don't think i have that issue. @Warrior193 I never liked that 50-50 ratio, some drivers (which don't like to search things) and even some mechanics-seller promote it.
  18. Some drivers here although live in hot climate use the 50% ,is there really need for this?
  19. As we say here "you will pay this later". In this case (50% mixture) the radiator fan will work more often for example in city traffic compared to 20% in a hot climate?
  20. The 50% concentration mixture from the first turn of the key in the morning (environment temperature) will reach the 92 'C first?
  21. Coolants and Their Application https://lairdthermal.com/thermal-technical-library/application-notes/common-coolant-types-and-their-uses-liquid-cooling-systems Water with Ethylene Glycol Cons: Reduced heat transfer efficiency compared to pure water.
  22. I am on leave, in few days i will return home, i will change the water expansion plastic can and i will raise the antifreeze at least in 40% presentance (now it's 20%) to see if there is an effect in the time that the temperature reach the 92 'C.
