pab567
FREEDOMTech
Everything posted by pab567
  1. Going from 02xx or 03xx to 04xx without patching the unit first is NOT possible.
  2. @asterixas I sent you link to zipped MST2_EU_SK_ZR_P0480T in PM, no password required to unzip.
  3. Problem new to me, try to run the firmware upgrade in Manual SWDL mode with "Select all" marked
  4. @KDQ I have just sent you link to MHI2_ER_SKG13_P4526 (1440) in PM. But reading your description I beleive this coudl also be battery issue - voltage might be going too low when starter is running.
  5. Enable developer mode in adaptation sof 5F unit with VCDS, OBD Eleven, ODIS, VCTool or any other tool. Install MIB STD2 Toolbox (be careful, you have firmware 02xx, there is some extra action you have to make, read toolbox manual for details). Patch swdownload from MIB STD2 Toolbox Modify metainfo2.txt file - change value of "RequiredVersion" rows to "0" Insert SD crad with 0480 firmware and modified metainfo2.txt Enter Service Mode - long press MENU button Select Manual SWDL Select all Deselect "Emergency" in both "cpu" and "main" Start uphgrade
  6. @jarkuu you have unit without eom sat nav so patching cannot be done from SD, only soldering path ☹️ @asterixas yes, you can, teh key is to install MIB STD2 Toolkit.
  7. Possible, there are several phones that can be paired. Pairing procedure is the same, check infotainment unit manual.
  8. Assuming you have Technisat unit, I sent you link to MST2_EU_VW_ZR_P0140T in PM
  9. @MathewJEH thx for info, I do appreciate it.
  10. @HEMTECO what i syour problem with your 3Q0035864?
  11. I can deliver MIB STD2 PQ unit, I have already sent you PM so you can share VIN.
  12. SKODA delaer can offer only unit replacement but if you are skilled enough to dismantle the unit, open it and disassemble then I can send you the BT module for replacement. Beleive me, it;s not a big deal. If you are arfraid you can find and electronics repair shop that can do it for you. I can do iyt also but as I am in Poland then it might be not very economical to send it to me for such simple repair (Brexit...)
  13. Then probably your BT module is broken. Where are you from?
  14. Do you have ignition switched ON? Bluetooth is available ONLY with ignition ON.
  15. There is no newer firmware so all you can do is to reflash with 0480
  16. @SkodaFan_Finland what's the exact problem - is it Bluetooth not working (as in one of your pics) or everything works fine just you can't install MIBSTD2 Toolbox?
  17. Part number and SW version of yopur infotinment unit?
  18. I assume MHI2_ER_SKG13_P4256_1_AIO_MU1440_20230504 is either the all-in-one firmware for native Columbus MIB2.5 SKoda units (5650350xx) or or for conversion of Columbus MIB2 units (3V00350xx) to Columbus MIB2.5. I will have it downloaded and tested when I have some free time and provide you with details.
