pab567
FREEDOMTech
Everything posted by pab567
  1. Indeed, you bouth the wrong kit. Ask your Pioneer dealer for the proper one.
  2. As requested... all the codes of this car TMBFM6NJ5HZ055263.pdf
  3. There are no updates available for your car, the most recent maps have been published few years ago and there will never be more updates published. Check in your phone Bluettoth profies allowed for connection with your Skoda Bluetooth module.
  4. Why don't you install OEM unit series MIB STD2 PQ and use Android Auto or APple CarPlay for navgation online? It also has built-in high quality Bluetooth module and perfectly matched the car...
  5. Using OEM parts you can install patched Bolero or Amundsen. You need: 1. glove box unit 2. display unit 3. extension cables You also need new USB if you want to have support for Apple CarPlay as well, not just Android Auto. EUR 450 should be enough for Bolero but not for Amundsen. If you are interested pls contact me on PM.
  6. Part number of infotainment unit?
  7. Unfortunately this is NOT a simple fix - requires soldeirng and either manual programming with not corrupted image or, if this doesn't help, EMMC replacement. In such case, you might think about retrofitting with "full" Bolero version 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874. Both will give you features you don't have with your old unit: - Android Auto - Apple CarPlay - Voice Coimmand - support for Reav View Camera Amundsen has alo OEM navigation built-in. If you are interested pls contact me on PM.
  8. Check if you have file metainfo2.txt in the root of SD.
  9. I beleive this is a problem of corrupted EMMC. Try to change language setting to any other - if after restart it returns to original setting then it confirms corrupted EMMC.
  10. Pls post part numbers of your old unit and the one you bought from salvage.
  11. @Hradlo - officially not possible, achievable under condition you find anywhere 03xx firmwar (I don't have it) Others check you PMs. If nothing on PM then you already have lates FW for your unit.
  12. No, yyou cannot, as you have Bolero MIB1 unit which has NO OEM navigation built-in
  13. There are no maps updates for units installed in Superb II since couple of years and there will never be new maps released.
  14. Remove the broken display and send me the picture of th eback side (with connection tapes), I might have one spare.
  15. If coding is correct then probably new USB is faulty.
  16. Shoul dbe recoverable. You can try with SW update. To determine SW version pls post a picture of the label located on the upper cover.
