Everything posted by pab567
Latest Infotainment version Bolero
PM
Amundsen MIB2 Firmware Update
Possible but not with VCDS - unit must be patched (hacked).
@KevSex you have download link on PM
Try another card, possibly max. 32GB, formatted under FAT32 with cluster size = 4096 bytes
Let me guess... you put update files on pendrive?
@Baltazar you have download link on PM. For maps pls visit Skoda Update Portal
All check your PMs
You do it from th ewrong menu - it should be service menu (long press menu item).
I need Bolero Update :-)
@Pleaseokno check your PM for download link
Any update contains all the languages available in previous versions - but no new languages are added.
All check your PMs
Columbus and speakers problem
Is your car equipped with Sound System?
- Columbus replacement
Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
Check your PM for download link
Ignition ON is not necessary
SAT NAV UPGRADE
Model number and SW version of your infotainment unit? Or at least VIN...
@Idol pls check your PM
Fabia MK3 Adaptive Cruise Control Retrofit
Officially this is not possible as ACC is controlled by FEC/SWaP code and Skoda does not offer such upgrade. If you know someone who works in VAG and can generate such code then it should be possible.
@lway you hit the point - too busy to review just like that, I react only when I'm tagged. All check your PMs.
Stereo upgrade
Indeed, your unit is Columbus MIB1 with DAB/DAB+ receiver. Direct replacement, that works with your display unit as well as the new display unit you mentioned (5E0919605M), is Columbus MIB2 3V0035020x (or 3V0035021x if you want to add Premium Bluetooth and LTE modem functionality, x means any letter). Another possibility to use any of display units mentioned above is Amundsen 5Q0035874x (x = letter A, B, C) or 565035874. You can also install Columbus MIB2.5 unit 565035020x / 565035021x but this will require display unit 5E0919606D which is expensive and hardluy available. If you are interested in any of mentioned above units in P&P version pls contact me on PM.
6" to 8" display upgrade
You are welcome
make it and you will find out...
Just take a knife and from the blue plug cut out excessive plastic trim that block you pluging it into black 4-pin socket in display unit
Virtual Cockpit works with Amundsen 5Q0035864C (non-DAB) and 5Q0035874C (DAB/DAB+) and MIB2.5 Columbus (5650350....). With Amundsen, you can display the map either on display unit or Virtual Cockpit while with Columbus you can display map simultaneously on both.
Guys, pls do not mix glove box unit with display unit. EVERY MIB2 glove box unit works with EVERY MIB2 screen. Some buttons may not work, e.g. NAV and TRAFFIC if you have non-nav unit (Bolero) or APP (if you use facelifted screen with pre-lifted glove box unit). 3V0919606 is a DISPLAY UNIT for Columbus glove box unit. 3V0919605A is a DISPLAY UNIT for Bolero glove box unit. If you have Bolero glove box unit and you replace your 6.5" display unit 3V0919605A with 8" display unit 3V0919606 everything will work but NAV and TRAFFIC buttons.
