Everything posted by Gabbo
Spare Parts - Where to buy from?
Yep looks like the right one & £25 including postage to Switzerland seems a great price.. Have you used them before? After Xmas I need to replace the steering position sensor used for the AFS cornering lights. I'll see if I can order both together to save on shipping.. Thank AG Falco 👍 Gabbo
This link seems to be for seat belt fixtures? This was the part I found: https://skodapartsdirect.co.uk/product/skoda-octavia-2014-2020-glow-plug/ Skoda part number is: Bosch SKU: 04L963319E Beru SKU: 04L963319AB These seem to be the generic part numbers: BERU Glow plug GE133 BOSCH Glow plug 0 250 403 009 Gabbo
Hello all, I'm looking for some recommendations where to buy replacement parts in the UK (or Switzerland but I guess it's asking too much)? I'm initially after a glow plug for my 184PS TDi 2014 (cylinder 4 so just standard plug I think). The garage here in Switzerland wants 60chf(~54£) each 😱, I've seen them for £35 from a Skoda garage in the UK (choice of Bosch or NGK) They are £12 + £15 shipping in AutoDoc but I've heard bad things about them not being genuine parts or fully compatible... Are there any recommendations for where you buy spare parts? Preferable a smaller or local retailer in the UK but a reputable website is also fine. Thanks in advance for any recommendations or hint in the acceptable glow plug price. Gabbo
My Skoda
This is a bit chicken & egg I guess because without Skoda connect you cannot access the OTA updates for the maps & infotainment. It's strange an update is needed though because Skoda connect is not a new service app should have been sorted for many versions
My Skoda
Confirm with them "what device" actually needs an update & to what level/version? It's possible to install the updates for Columbus "unofficially" yourself I believe
My Skoda
A garage will charge you the download time & installation time even if they already have the necessary files & the installation requires no interaction. Nothing says they have a 100Gbps, they will charge you for an hour downloading at 100kbps... My company paid approximately the same at BMW for a navigation update. ~€450
Rear wiper blade for L & K estate
Do you have the part number for the old wiper arm? Do you know if it's different between the estate and hatchback?
My Skoda
Perhaps it's something they can do remotely? In my case, I didn't leave the car, the guy went to his desks & logged into some kind of Skoda website. After a few seconds he came back and said try to reconnect your user profile & everything worked. All they probably needs is your VIN & Skoda app user ID/login name
What oil type?
Agree, I had the same conversation with him because I wanted to change to 5W30 after the 3rd 1L "top-up" after 21k km However, the garage is "monitoring" the consumption at the moment and has checked for leaks around the engine and into the exhaust system 3 times plus paid for the additional oil so I didn't push too hard. As mentioned I plan to change to 5W30 in the future once they stop giving me free oil at least for one fill to see if it improves the oil consumption (and doesn't affect the fuel consumption).
What oil type?
On my new superb TDI (2024) mk3 there's a sticker on the bumper beam & it uses 0W30. I have high but regular oil consumption & I've asked the dealer if I can change to 5W30 as the previous engine. He said technically yes but as my car is in warranty it would no longer be valid if the oil consumption issues get worse. So I will stick with it for the first 3 years before I change.
My Skoda
I had the same issue with my new car. I was a bit "quick" for the dealers liking when I picked up my car & had already tried to connect as the main user before the "handover" guy arrived as he was with another customer & had the same error. He activated something in the Skoda system at his desk & then it worked at the next attempt.
This was my first thought... Where are you buying the previous version of the arm from? I'm going to pop into Skoda on Friday to see if they'll replace my blade under warranty & if not what they want for a new blade compared with a previous level arm.
Pressure sensor or not ? Glow plugs
It's on my Octavia not the superb. It's a 2014 184ps TDi. I've done almost 250k km so can't complain really but was thinking I could save a few hundred CHF by doing it myself
Columbus Map and Software update risks
The file format NTFS/FAT32 is important for SD cards. I can't remember which is the correct one. I got annoyed always trying twice and waiting 20 minutes to download the files again. I use a USB hard drive now for the transfer. Works just the same and is slightly faster than a usb stick.
Do you have any experience changing the glow plugs on the Vag Diesels? I have an 184ps TDi (2014 vRS Octavia) with a glow plug 4 error. Access to the plug seems straightforward but I've read alot about shearing the plug when trying to remove it... Is it easy enough to do if you are careful & soak with a little WD40 before hand?
Automatic V Manual Transmission - And does manual have assisted driving features same as auto
Yes except you have to change the gears for yourself & the auto will be more practical in several situations. E.g. In a line of slow moving traffic the auto will crawl & creep, stop, continue without intervention etc. In a manual you will need to use the clutch & change gear as necessary. One feature I love on my DSG is if you drive on A roads with ACC active, it will automatically slow the speed for a roundabout, drive at a suitable speed to navigate the roundabout & then accelerate afterwards. Driving assistant functions will always be better/more integrated with DSG. There are other considerations for the choice between manual and DSG Like upfront costs, service costs, chance of failure & fuel economy etc
Columbus Map Update problem
In the screenshot you published there is a button "update software". If you press this with the USB C device connected does it find the map update? Have you extracted the zip file onto the memory stick? Usually you have to extract the files & folder structure from the zip file not just copy the zip file..
Would it be worth/possible to replace the wiper arm to the old part which would take the old fitting/clip? Or is the clip integrated into the assembly or can it be swapped between the old & new blade? I'd imagine the OEM blade is 3x the price of the 3rd party version from Bosch/Hella/Conti? My superb is 1 year old and I have the same problem with the rear blade. If it was changed in March 2023 it's surprising that there aren't aftermarket parts from the usual suppliers available already.
Removal of buttons from infotainment system
Are there some apps which would have the TV channels you might want which you could stream to the cars display or watch via CarPlay/Android auto instead?
Diesel judder
Had the problems started before you put in the diesel cleaner & refueled?
Oil consumption
I have a new 2l TDI which is consuming around 1l of oil per 7000km. As it was new I took it back to the dealer at 6800km and 13500km. They checked everything, topped up the oil and told me it was "normal" consumption. I just passed 21k km and it asked for more oil. I'm "recording" the situation with the dealer as I have 3 year warranty but I'm a little disappointed if it stays like this. Unless it gets worse they've said there is nothing they can do because it's within the VAG spec. I'm waiting for the first full service at 30k if they will insist on an oil change as 80% of the oil has already been changed. The only explanation they have was that they had seen more cars like this due to the change in oil spec 0W30 compared to 5w30 from my Octavia TDi. Within the warranty I would not be allowed to change the oil spec particularly if something was not optimal and it got worse as it would be more difficult to claim against VAG for a new engine/DPF etc Gabbo
Replacement Battery Recommendations
I made the same change in my Octavia as you can't but the 68A version. I didn't change the coding just replace Varta 68A for Varta 70A. I've had no problems since in almost 2 years.
Oscillating noise...in certain circumstances.
Could it be the power steering pump which I find makes a whooshing sound for 10-15s after manoeuvring when at or close to full lock ?
Side mirror does not automatically lower when reversing
Exactly because when you leave the selector on the passenger side mirror you also have the chance to move the normally mirror position by mistake... It would be much more convenient to have an on/off setting in the infotainment to use it or not. When you select reverse it automatically selects the sensor view it cameras, a simple button here to dip/not dip the mirrors would be perfect
Start stop turns off engine before complete stop
I've had a Volvo XC90 & Mercedes GLE and both have the same behaviour where when coming to a stop you mentioned. the engine will sometimes cutout around 10kph before the vehicle comes to a stop if you are braking very lightly. My 2023 MK3 Superb also does this. Quite annoying as often in cuts out then restarts if you release slightly the brake and then cuts out again when you reach 0kph. I guess this is an emissions thing to try to win a few grammes more of CO2 by stopping early.
