Gabbo
Everything posted by Gabbo
  1. One way around this if you have stop start enabled is to park up, let stop start cutout the engine, the leave the car without pressing the ignition button. The lights will stay on, and when you lock the car, the ignition will automatically turn off & coming home timer will be started.
  2. Out of interest, what brand of AdBlue do you use to top-up? I've noticed most big petrol stations now offer this from the pumps but you can also buy smaller 5L bottles from most places. I'd prefer to top up myself than get charged a premium by the garage at each service.
  3. @Jonatan any news from the garage as to the root cause?
  4. The navigation/infotaiwnt unit. If you press the menu button, there's a tile of the main screen for service campaigns.
  5. In the main menu on the MIB3 there's a tile for service campaigns. If you select that does it inform you of any outstanding actions linked to your VIN?
  6. I think partially the legislation which defines very strict rules on how to apply limitations from low adBlue level once you've gone underneath the threshold to trigger the countdown. I guess the system can see you have topped up small amounts but doesn't display this in terms of adBlue distance remaining unless you add enough to move outside of the warning region. This is perhaps why you must add a minimum of 3L to deactivate the distance to "no start" warning.
  7. I tried this today. I dont really understand what refill quantity min & max means but I'll monitor it over the next thousand kms next week
  8. @Jonatan maybe worth to read the adBlue tank level in the driving data & then topup to see if the indicated level increases, then monitor over time to see if it rapidly decreases or doesn't change..
  9. Is there a way to view the measured level of adBlue through the MIB3? I haven't seen it but I'll look tomorrow. Anyone know what kind of level sensor the tank has? Do you have any PCodes? I'd guess there are two obvious faults to check, a leak of the tank or a faulty level sensor
  10. That's why I was asking because I normally the adBlue consumption on a car is pretty low so I didn't imagine a large tank so it should be more than capable to register 5L. It should register almost any filling amount but unless you make a significant step in level the reading is heavily filtered to allow for gradient or inclination. If you park on a level ground, it should recognise small amounts at least by the next start.
  11. Did you turn it off with VCDS/OBD11? I've just seen this thread & after a few months trying to get used to the DSG I think I'll do the same. I feel like I'm constantly flicking the paddle to put back the gear or braking unnecessarily when I'm accelerating above the speed limit or towards the car in front.
  12. It world be nice if the DSG used the front assist ACC sensor & inclination sensor to decide when to coast. E.g.not engaging coasting when the car in front is slowing down or when you are on a downward slope. I am used to a manual & use heavily the engine braking & anticipation to manage the speed. New to a DSG and the most annoying part is gear shifting or coasting which causes the speed of the car to increase. I can't understand why they design the system this way. For me it's more logical if I remove my foot from the accelerator that I want to slow down or at least maintain the current speed. With the combination of sensors and road mapping it should be simple to do this but instead it will engage coasting or shift to the next gear making me accelerate towards the car in front... I am constantly flicking the flappy paddle to make it reengage the gear. I think I'll invest in a OBD11 just to change this setting.
  13. How big is the adBlue tank in the Superb?
  14. Is there an option for setting the LHD/RHD automatically based on GPS? My Octavia had this option with the MIB1 to adjust the headlights but there was also an issue that on powerup the last location would not be remembered & it would default to Wolfsburg Germany until it established a GPS signal. I have been using the high beam assist recently in the new Superb & on the highway in Switzerland it lights up heavily the offside & I would say it's very reactive to disable the forward lighting when there's traffic in the distance. It's useful that Skoda gives you the option & it's not active by default. In our previous Mercedes, full beam matrix lights was "always enabled" if you set the light selector to Auto.
  15. My MIB1 in the Octavia gives me the choice each time, fastest, shortest, eco. You made me think & I don't remember having this option in the Superb MIB3. I have the online "traffication" & Skoda connect services activated so I'd expect it should have real-time updates through the internet for traffic & delays etc. I don't often drive many complicated routes but I'll try driving with the nav active more often. It nags you to do this anyway with the suggested routes screen each time you start the car.
  16. Is there somewhere you can see the update history or available updates from the MIB3 itself?
  17. Could the glow plugs not have been installed properly causing a loss of compression in ones of the cylinders? Do you see anything if you remove the engine cover? Is not uncommon to have an occasional poor tank of diesel from a garage or a badly timed regen which causes multiple heatups without reaching the target temperature for long enough. Dont forget the change to winter or summer spec fuel which the engine needs to adapt to.
  18. Several times when I've been driving I've had a message popup saying application updates are available. When I click "install now" it opens the store application but says "some features are disabled when the vehicle is in motion". When I look when I reach my destination I cannot find anywhere that lists updates available. Is there somewhere I can see which OTA updates have been applied e.g. Maps, trafication etc ? Are you able to manage it from the Skoda app? (I guess no).
  19. Original post says that the battery has already been replaced
  20. This is quite a common fault here too, so much that there a special insurance extra for damage from animals chewing things
  21. It says something about the superb & 280 that almost everyone seems to have problems that needed to be rectified, some at reasonable expense, and yet everyone loves it so much they would buy a new one tomorrow!!
  22. Would some of the missing systems suggest something other than a speed sensor fault? E.g. Road sign recognition Perhaps a CAN related fault or bad ground?
  23. I made a similar replacement in my Octavia TDI. Varta AGM 68Ah battery replaced with a Varta Silver dynamic 70Ah battery. I didn't make any coding changes or connect any diagnostic tools. I've not had any issues & everything has been fine since the first start with the new battery. Stop start worked immediately & my car has been for a service and timing belt change during the year since without any problems or issues flagged by the garage. In my opinion recoding is only necessary is you change the type AGM to EFB or vice versa or if you fit a hugely different size.
  24. Our VAG dealers provide an OBD dongle to monitor your car and provide additional functions like sending diagnostics to the dealer, find my car, journey statistics etc It's always plugged in & doesn't seem to cause any problems with the battery.
