ords
Everything posted by ords
  1. What engine size, manual or auto?
  2. My 1.6 doesn't need topping up between services. There is this thread
  3. Ok, but one sensor was coming up as faulty but doesn't affect the speedo?
  4. Possibly, but what ever sensor(s) the speedo uses could also control the stop start.
  5. The odd one out is the stop start error. Is it working? Suggest you get the battery and charging system checked
  6. What was the problem?
  7. Stop start batteries are not designed to be fully charged. Usually only charged to 80% by the battery management system.
  8. It's at the other end of the engine
  9. If yours is DSG then it will use more fuel. It holds onto the lower gears much more compared with normal & eco even if you're light footed. It's also eager to down shift. I've no experience of driving a manual with these modes
  10. Possibly suitable? https://www.amazon.co.uk/Condenser-Without-Compatible-Trade-Vehicle/dp/B08KR9WHQK/ref=sr_1_3?af=eyJxdWFydHpWZWhpY2xlIjoiMTA2LTExNjcxIn0%3D&crid=1QECS5N5YFXFL&dib=eyJ2IjoiMSJ9.k56PgKXXthFVi4CxdXiLXgchItbHQvPchArHz3Rz1bIdPv3A8LcR_CW5RRZI93m0QTMWjZT2-gXDmOWosEdAcbc_3JusW_BsS2q-ZWQt1tlBKTsfwMljWTeMNuKZGniRPIejjO73LWXPeo0ZmgUGEzrp_TtKUvdgH4ZHDqqUbHsa239Q_4jlnrq6kcQLEVkoyWzmWp_sQH_ky86vom-5fFk1pZ91D9laqkxO_ESph0g.j0NYPUznLZYqhin_0708IwCst1AaztABn6PQBlUB52k&dib_tag=se&keywords=skoda+octavia+air+con+condenser&qid=1723149688&sprefix=skoda+octavia+air+con+condenser%2Caps%2C130&sr=8-3
  11. Do you get the radar type visual display on the screen?
  12. Get the battery and alternator voltages checked first.
  13. I was thinking a fuel pump relay sticking
  14. Could be a sticking relay.
  15. If this is a diesel, then perfectly normal.
  16. Vacuum cleaner with the blower on full speed?
  17. Battery voltage doesn't look that healthy. Is that reading with the engine running?
