Everything posted by ords
Flashing coil light - I know.
Mine has just done the same thing. Coil light flashing and s/s not working. This was during a 200 mile trip of mainly motorway and A roads. Was still flashing when I reached home. No loss of performance. Was not used for a month and then had a 150 mile trip, 80% of it on the motorway. No faults at all but average fuel consumption down by 8 / 10 mpg. Could this be a sign of the egr failing?
DPF issues (sorry)
So in this case, if you were the OP, you would negotiate a deal on a car knowing it had a faulty DPF but the price you paid reflected this. After purchase would you then expect the garage to replace the DPF at their expense and if not use the Consumer Rights Act?
Wet Vac Alcantara?
https://www.cleanyourcar.co.uk/forum/viewtopic.php?t=8663
DPF issues (sorry)
D. Get a car with an engine suitable for your type of motoring.
DPF issues (sorry)
I'm a bit confused. How did you know it hadn't regenerated for a while?
DPF issues (sorry)
Do you mean they have refunded you £800?
Water pump belt
I'm guessing the water pump belt has a lot less stress on it compared to a timing belt. If the pump failed at an early age it may not be neccessary to replace the belt, hence it being sold separately.
Water pump belt
That's why I asked what engine the OP has.
Mis fire on cold start
If it's firing up straight away it would seem they're ok.
Water pump belt
What engine do you have?
How quickly does it start after being left overnight? If it takes a long time that could point to the glowplugs.
Cleaning the SD card port
That also jogged my memory and I've found a couple of links one of which mentions a locking device.
- New to Skoda - a few questions please.
Agree. Find out why you can't remove the card. It's possible that's affecting the other port.
It's an Amundsen as the Columbus system does not use an SD card for the sat nav.
Do you have 2 ports so you can try it in the other one?
Annoying rattle skoda octavia 1.4tsi 150hp stock
File does not play for me.
Gps tracker installation
I wasn't talking about the voltage, just the fact that as the front is live all the time so the rear would be if they're on the same circuit.
As far as I know they're both on the same circuit. Just plug something into the boot socket and see if it still operates after you lock the car.
The 12v socket in the console or the one in the boot?
Electrical errors after installing new battery
This is confusing as you have two similar threads running. Have you told the battery management system there is a new battery as suggested in the other thread?
Was the battery management system re-coded so it knows there's a new battery?
Overheating problem? Help!!
Going by Skoda UK's 5 year recommendation, you are due for a timing belt change which will include the water pump.
Coasting in Eco?
I run mine in eco all the time because it gets into the higher gears more quickly. With all the 20mph zones everywhere I'm in 4th gear using CC. It also stays in eco mode after a re-start, even overnight.
Need help with making sense of numerous failure messages that came all at once
It's always seems to be the luck of the draw with batteries. Mine is 9 yrs old and I've always used start/stop.
