Everything posted by ords
SatNav help
OP needs to post a pic of the p/no and software version then someone call tell him if it's MIB1 or MIB2
Octavia L&K Seat Memory Dead
I'd start with the fuses. Also check that no wiring or connectors have been disturbed.
Interior light
Do you get the doors open warning on the MFD? If you do, it would suggest the door switches are ok.
Interior light
Is the problem with all doors? Does the rear roof light come on? Do they come on when unlocking?
SatNav help
It looks exactly like my Amunsden unit and it looks like there is an SD card already in the SD1 slot. See what type of card it is. If your sat nav works then there is no need to buy another card which has to be a genuine Skoda sat nav card.
SatNav help
You need to answer paulski's question in full or post a pic
SatNav help
What head unit do you have? Amunsden or Columbus?
Several error messages
Could be water has got into the ABS connector.
Spare keyfob not working central locking.
Is the red light flashing on the keyfob?
what do you like and dislike about your Octavia?
What would you rather have?
Silver trim replacement
Someone had this query already and at the time couldn't get the trim seperately
heater problem
You could try re-calibrating it.
messages
A simple search on Google says that it's a fault with the cylinder 3 glow plug or circuit
Mk3 octavia cruise control fitting
There are quite a few threads if you use the search facility
Heater fan not working
You may have better luck if you post on the Superb forum.
Halfrauds strike again - can't even change a battery! I should know better!
Mine has stop/start. 2013 model
Please tell me why the earlier cars don't need coding?
USB DAB Dongles
The aerial is in the rear glass on the hatch lid
Cambelt Failure
I guess if you've taken out an extended warranty, you'll have to have it changed at the recommended times otherwise you may not be covered.
Battery life for 2019 Octavia VRS
On what basis are they recommending it? Have they tested it or just going by age? Mine is still on its original and stands for weeks on end without being used. I know it's luck of the draw.
Whining noise 7 speed DSG
We need more info. Model, year, 6 or 7 speed box? Does it do it in all modes, all gears? Does it do it when coasting/freewheeling? Does it go away when braking?
Anti siphon device 2017 Octavia
Googling this problem Googling this problem, other car makers like BMW & Ford seem have their own adaptors. As the fuel nozzle at the pump is a standard size I don't see why these wouldn't work.
https://www.amazon.co.uk/TDI-Diesel-Fuel-Nozzle-Adapter/dp/B00696Y74O
Obdeleven
Front fog lights can only be used if visibility is bad. Or do you mean they come on with the main beam?
- After changing DSG clutch slip
