ords
Everything posted by ords
  1. Was it like this before the change? Does it do it in all modes or just S mode? Why did you have to change the clutches?
  2. Fight to get it replaced under warranty. Have you noticed any difference in cranking speed? Unless you know you've really abused the battery it shouldn't need replacing yet.
  3. You could also not be covered by your insurance as the car is not roadworthy, some safety systems do not appear to be working.
  4. Next time you feel it a bit skittish in eco mode, change to sports mode and see if there is any difference.
  5. What year is your car? You have put 2007.
  6. This should be the p/no which you can Google 5Q0035726E
  7. Can you look for the wiring to the sensors yourself? It's possible they haven't been re-connected properly and water has got into the connectors.
  8. I would take the carpets & felt out and as soon as you see water on the floor try and see where it's coming from.
  9. I didn't realise that you can open the boot from the inside, that's why I was confused.
  10. Sorry, I didn't mean it to appear to be so abrupt.
  11. There are many threads on this subject. Use the search facility.
  12. Instead of coming to a complete halt, why can't you shift to "N", press the brake pedal slightly and restart the engine? Then into "D". Obviously needs some care depending on traffic conditions.
  13. What do you mean " can open it manually from in the boot"? I'm assuming you've tried the central locking switch in front of the gear lever?
  14. If it was a decent system it would suggest an alternative route if possible. Only on rare occasions has mine said it's changing the route because of current traffic conditions.
  15. Take a picture of the battery label. Someone will tell you if it's the right spec.
  16. Your battery is a year old under warranty. Get it checked out.
  17. If you can get the battery fully charged, disconnect one of the terminals and leave it for as long as possible & then try to start it. If it starts then you know the battery is ok & there is a current draw which needs investigating. Your battery will be covered by its warranty as it's only a year old. Get it checked out. Was the new battery coded when fitted? I know it's the luck of the draw, but mine is on it's original battery, gets left for 6/8 weeks at a time and always has enough power to start up.
  18. If it's a manual this may help.
  19. It's not you. It's very slow to get updated info. Most of the time it will say slow moving traffic in x number of miles but do nothing to suggest an alternative. Mine loves narrow lanes as well. Keep your Garmin in the car or use Google maps as a back up.
  20. Have you tried different modes?
