Everything posted by thomasaspin
Intermittent shudder / misfire Fabia VRS MK2
I myself live in oldham if you need any help
Sounds like they have damaged the vacuum pipe while changing the plugs , there’s a few posts on here about it , if not they could have damaged the coil packs / wiring and or not correct spark plugs at correct gap
How do I increase the idle speed on 2014 1.4 VRS ?
You can increase the idle speed in vcds in advanced settings
Recommended online parts suppliers?
We sure are I always use AUTODOC parts they are practically the same part just not stamped up oem
2011 Skoda fabia vrs auto box ecu issues help
You can replace the pressure vessel yourself for very little money in fairness the repair kits are on eBay , so saying it needs a new ecu when the vessel is faulty is complete nonsense , I know a gearbox specialist who would be able to fix it but it’s a bit away from you might be worth sending them the mechatronics unit ?
Oil level check show up.
I think you might be burning oil good sir
AUTODOC app on iPhone or android
DSG maxidot gear blinking
My Dsg failed around the same mileage that’s why I did a dq200 to dq250 swap which could be worth looking into if the gearbox fails
Help with error codes on my 2013 CBZA engine (1.2 TSI)
Check for air leaks in brake servo also common on the 1.2 tsi’s
- vRS - what is the currently favoured spark plug?
- Skoda fabia mk2 shaking when accelerating in second gear and further. Any advice ?
Annoying crunch noise over speed bumps
Could be a broken spring ? Or a failing suspension gas strut
Horrid noise on cold start - tensioners on their way?
I would be replacing the oil pump and replacing the oil as a matter of urgency if you keep getting oil pressure warnings and also cleaning the oil pick up line in the sump it’s potentially gummed up
Sounds like the timing chain struggling to tension due to low oil pressure
Fabia MK2 VRS 'The Red Baron'
Hi mate project is pretty much complete gearbox works fine just making a proper mount for the gearbox as you need essentially a hybrid mount between the dq200 mount and the dq250 mount , I’m starting a new project soon that I will be posting on here , I’m taking a rover k series turbo engine out of a rover 75 and mating it to a dq250 gearbox from a golf R and sticking it in a mg zr.
Another Misfire Post
Hi mate not saying this will be a one stop fix for yourself but a good fix is to fit an uprated plug (not the oem plug that Skoda/vw fit) in tandom with changing from standard coil packs to Audi R8 coil packs should fix any missfires that are not piston ring/ burnt valves related
Fabia Mk2 vRS Twincharger water pump part numbers. Supercharger Clutch.
Could be an airlock working its way out ?
AMD's 2 litre 304bhp 162mph Fabia Monte Carlo TDi *6 speed conversion*
Good to see the honesty! there’s been quite a few expensive failures with that Skoda of yours hasn’t there 👍
Bit Of a messy install that for a gauge good sir , could you not of engineered a nice vent gauge pod? something properly engineered like this would do the trick not just stuck through the vent 👍
Not hurt at all , just pathetic how you have to comment stuff like that as if it’s a contest are you unhappy with your own life that beating someone in a straight line gives you some sort of satisfaction I wouldn’t waste my petrol against you , I tell you what why not do a run down on how much you have spent on the Monte Carlo to get it to the power yours is and I will do the same and I’ll laugh at how much money you’ve put into a base model fabia I bet my spending is a tenth of yours for more power 😂🤣😂🤣 #darksidefanboy , oh and throwing money at darkside developments doesn’t make you part of there motorsport team it makes you a customer your that far up there ar*e it’s like the darkside human centipede
Ah I see start trying to comment on grammar because you can’t take the truth about making snide comments about other platform vehicles (diesel vs petrol) you wouldn’t stand a chance against a Dsg fabia vrs especially one that has a Dq250 box with a quaife LSD and can hit 2.0bar of boost at the Rev limit wheel spin or no wheel spin but hey you can always hope can’t you kidda 👍 maybe you can slap a few more stickers on for more horsepower so you can stand a chance.
You haven’t got a hater YOU hate on other platform cars like a muppet making snide comments because your a jealous tool
