How to enable Traffic Sign recognition
Or you could post a picture and we can tell you 😉
FIXED: Problems with enabling Cornoring Fogs on Octavia SE FL 2018
Try tweaking the following adaption channels: static AFS light-Abdimmgeschwindigkeit change to 25 %/s static AFS light-Maximaltemperatur change to 100 °C static AFS light-obere Grenztemperatur change to 95 °C static AFS light-untere Grenztemperatur change to 80 °C
Switching standard headlight to xenox projector ones
For a proper retrofit, you'll need to add suspension level sensors, a headlight range (AFS) module, some wiring and finally recode the car I'm not sure if any modules (CAN gateway or BCM) would also need replacing. If you scan your car with VCDS or similar to can compare your car to those with factory fitted xenons to confirm.
I've never used OBDeleven (as I have VCDS) but as general advice: - make a backup before you do anything (no idea how OBDeleven does this) - make sure the backup is somewhere safe!! - make a note of everything you change - double check the adaption channels as they are often very similar Once you've done that, try following the OBDeleven guide below. It seems to match exactly what I did on my '18 plate vRS although a couple of the adaption channels were already set correctly so don't worry if you find the same. Good luck
Coding for rear lights on with DRLs with auto lights.
Then I'd suggest asking to see if they do Once we have an adaption map, it should be possible to suggest the coding. There are a few variants for the Octavia so it's best to see how the car is currently configured before suggesting changes.
Sure, can you post an autoscan and an adaption map for 09? Hopefully you're VCDS friend took both when they were connected
Rear fog light not working. Octavia 3 2017
Just had my drivers side rear cluster off, it has the same wire clipped on to the reflector so it appears to be normal... :/ When you replaced the rear lights, did you do both and use exactly the same part number? Might be worth connecting VCDS or similar but typically, I wouldn't expect replacing a rear light to need any coding etc.
MIB2 Retrofit
Nope, a Discover Pro MIB2.5 won't work in a PQ based car such as a MK2 Octavia. The only option that's compatible with the PQ platform is the "MIB2 STD PQ" aka Amundsen/Bolero or Discover/Composition Media. Even the, it's only the 'all-in-one' version that'll work (MY15+ Yeti and various MY15+ PQ based VWs). The ones with a separate display and 'brain' which lives in the glovebox are only for MQB cars.
Yup, just the drivers side should work as standard. I'd not noticed the white 2-pin plug being disconnected in your first post. That should definitely be connected to something and tallies with the warning on the dash... If I get time over the weekend, I'll remove my rear cluster and take a look for you. Unless someone has one handy or some decent pictures In the meantime, you can take the passenger side off and compare. That will have the same white 2-pin plug but it should be connected correctly with any luck
Just to rule out any confusion, is this the passenger or driver side cluster you're looking at? I only ask as the default setting is to have one rear fog light working which is on the drivers side Were there any warnings on the dashboard saying the fog light didn't work?
Rear view camera glitch
I'd suggest finding an autoscan and adaption maps for a similar car with it working. You can then compare to yours to see what differences there are. It should help you find out if it's software, hardware or configuration.
MIB2 Retrofit
I've never seen anyone attempt a VC retrofit on PQ platform cars so I doubt the genuine clusters will work as they are MQB based. That being said, it appears the Chinese have started making aftermarket 'android' VC for some cars, for instance: - this fits a few VW's: https://www.aliexpress.com/item/4000759618838.html - this fits a Jeep: https://www.aliexpress.com/item/4001160737615.html In time, they may introduce the same for older cars...?
MIB2 Retrofit
This thread may also help:
ECU Replacement opinions please
The orange light can come on for many reasons so without seeing a fault code, it's impossible to know if the ECU needs replacing or not. I'm not aware of any common ECU failures though... I'd suggest you find a local member with VCDS or similar to scan the car and confirm exactly what codes are present
- Amundsen Mib2 Map Updates 2021
coding the multimedia to turn off at car lock, not door open
It's #2. You should get a dialog box like this: https://www.ross-tech.com/vcds/tour/controller-channels-map.php I'd probably enter: - Single controller: 5F - No security code - Adaptions - CSV file Either PLA or CSV should be fine but I'm more familiar with CSV so I tend to choose that Bare in mind, you'll get end up with a CSV with ~2000-3000 lines in it so comparing might take a while. If you post them, I'll try and run them through some python I put together.
It could be coding, an adaption channel or the module software version Given you've got a two cars that behave differently, the best plan is to autoscan and create adpmaps for each and see what's different...
Octavia mk3 enable corning fogs- infotainment tick option or not?
Pretty sure once they are coded, they will always be active. I'm not aware of a menu option to turn them on/off from the headunit
Retrofit parkhilafe i need coding.
That's an example of a Octavia with a 5QA 919 283 C module fitted so the lcode might be correct for your car. However, I would suggest you use it as a base and check each bit/byte. Typically, VCDS gives a short description for known bits so read the description and make a decision based on that...
First hit is on google is: https://forums.ross-tech.com/index.php?threads/19347/ So I'd try 000308419618240 to start? If it doesn't work, post a full autoscan from VCDS
Amundsen MIB STD2 infotainment system with Android in Superb II
I believe so Any MK3 wheel will fit, the buttons are where you need to be careful.., They need to compatible with PQ platform cars so would have been fitted to a Yeti or MK2 FL Superb. You can switch the buttons easily enough. I used 5E0919719F which have green backlighting and no DSG paddle support.
I think you can recode the left roller as a "push-to-talk": - Go to address 16 (steering wheel) and check byte 1, bit 3. I can't remember exactly how it works as it's been ages since I had the original MFSW fitted. It might remove the mute function or make a short press mute and a long press voice control? The other solution is to fit a MK3 style wheel as that has separate voice and phone buttons
Auto Headlights
Your confusing the terminology: - Automatic headlights typically means the headlights will turn on when it gets dark and off when it gets light outside. - HBA (High beam assist) will turn the main/high beams on/off when their are other cars are detected. Automatic headlights do not need a camera, they use a light sensor in rear view mirror mount to detect ambient lighting conditions. High beam assist does need a camera and there are two different versions. The 'highline' camera lives at address A5 and is capable of lane assist, traffic sign recognition, high beam assist and proving data for SLA headlights. This is the version that lives under the triangular cut-out shown in your second image. There is also a 'lowline' camera which lives at address 20 and is only capable of high beam assist. This is fitted to the rear view mirror mount as shown here:
- FIXED - MY19 - enabling both rear fogs - not working - LED tail mod now available
Octy VRS buying tips
Based on this service video, probably not from the top: ODIS or VCDS would show it as address/module 32. The above video confirms OBDeleven shows it as 'lock electronics' so if that's missing, your car doesn't have a VAQ diff :(
