Wiring on new battery.
Are you saying the battery has been connected backwards? If so, nothing would work... π€ Got a picture to explain the problem more clearly?
Problem with DRL after changed BCM
When the factory coding of byte 18 is 00, it typically means that none of the 01-FF 'presets' have the correct light config for the vehicle spec. Instead, it needs a custom config applying with VCP or ODIS. Where are you based?
VCDS Options
Anything that can change the lcode or adaption channels should be able to perform the changes. I have no idea what xtool is or what it's capable of, maybe ask the manufacturer?
Cruise control not working
Some are black as they have a layer of carbon attached to the PCB π So depends on the version, it's probably normal. Feel free to add a picture...
The most bizarre lighting issueΒ
It's trivial to check the settings with VCDS. No idea about Carista... At least on my FL vRS, the reverse lamp check are controlled by: - channel ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 - channel ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29
If the previous owner fitted LED reverse lights, they may have recoded for the car from them. The fault codes from Carista look completely mad and don't tally with how VCDS etc show them so I wouldn't put much faith in the descriptions. If possible, I'd get the car scanned with VCDS as at least you'll get a more sensible description. You can also check the bulb settings for the reverse lights at the same time. As for dead short, the BCM is pretty smart so will apply a small amount of current first. If it detects a dead short it'll disable that light channel to avoid blowing a fuse. If a dead short occurs while the bulb is on, then there is a chance it'll take the fuse out before the BCM can react.
Brake DISKS and PADS size and which brand to go for????
Fixed servicing is 1 year or ~10k miles depending what comes first. Flexible servicing is 2 years or ~20k miles depending what comes first. It'll depend on your thoughts about oil longevity and typical driving which suits best. As for grade, I believe this is from the owners manual but you should check yours:
Yes, the brake fluid should be changed after the first 3 years and then every 2 years afterwards. It's not hard to flush new brake fluid through the system. However, if you get air into the system you'll need VCDS or similar to cycle the ABS pump to purge it.
Component protection MIB2.5
Yeah, you need valid FAZIT/GeKo credentials etc to allow access to the VAG servers I'm afraid. It's a long and drawn out process to get access and not cheap as far as I know Still, plenty of remote options given you've got access to a VAS5054a, they'll be cheaper and more understanding than a dealer!
1.6 oil/filter change...
Ideally, when swapping the fuel filter you should prime the low pressure side to purge any air from the system. It's not because of a fault code, it's to prevent damage to the high pressure fuel pump and other components due to running dry or air pockets... Filling the filter holder with clean diesel will reduce the amount of air ingress and therefore lower the risks.
outside temperature error
Likely the sensor or wiring
Yup, it'll need CP pairing and then FeC/SWaP codes restoring. This can be done with a VAS5054a and licenced ODIS with a valid online subscription for Skoda. However, you probably only have the hardware rather than the software with a valid subscription? Instead, you might want to contact one of the various companies who offer remote coding. You'll still need the VAS5054a but there is no need for ODIS or a subscription as they will use their own I assume you had a MIB2 unit? I'm not sure if the FeC/SWaP codes are directly compatible between MIB2 and MIB2.5 so there may be an extra step to unlock some features
Where do I get a new jack (at a fair price) for my octavia
I doubt a small bottle Jack will be any more stable... I'd only use either for an emergency tyre replacement. Even then, ideally on flat, solid ground whilst being suitably wary the car could move. The one time I had to use the widow maker on my MK2 Octavia, it worked perfectly and I survived π₯³
I'd stick to the VAG jack, they aren't expensive on eBay... As a random example: https://www.ebay.co.uk/itm/401656650593 This certainly can happen unless you can spread the weight and use a proper jacking location.
2012 Octavia window master switch
I'd probably grab a good condition used one from eBay. If you remove your existing switches, you can check the part number to make sure you get the correct replacement.
Depends how closely the LEDs simulate the electrical characteristics of an standard bulb...
Removing Yeti Instrument Cluster - Odometer Reading
Yup
VCDS what do I need? - READ BEFORE BUYING
Gendan do the 3-vin HEX-V2 for Β£225: https://www.gendan.co.uk/product_VCV23.html
TPMS - Real one or monitor wheel turning speed like in MK2 vRS?
Almost certainly the latter I'm afraid
46 - Central Convienience
Byte 0 of the CAN gateway should be coded as 35 as it's a PQ35 platform car... Address 46 is a 'virtual module' and is actually part of 09. As such, it won't show up on an autoscan or let you do any coding/adaptions, it only exists for legacy reasons as some modules need to communicate with 46. Instead, you'll need to perform changes in 09
Unlocking all doors from driver's door key lock
@J.R. why not buy a used remote key from eBay etc? You can pair the remote fob side but ignore the key blade/immo. That'll give you a key that can unlock/lock the car but nothing else. What happens with your normal remote key if you unlock the car with the key blade and then immediately use the key to turn the ignition on?
Post an autoscan so we can see how your car is configured π
Another headlight problem
Easiest way is to have a volunteer watch the laptop as you drive. For live monitoring: - Start VCDS - Select control module - Choose 55 Xenon Range - Select advanced measuring blocks or measuring blocks You then want to select the following, I don't think you need the group/field bit, just the description: - Group 1 - Field 2, Vehicle Speed - Group 1 - Field 3, Steering Angle - Sensor (G85) - Group 2 - Field 0, Sensor Signal - Front (G78/G289) - Group 2 - Field 1, Sensor Signal - Rear (G76/G77) - Group 2 - Field 2, Actuator Motor - Left Headlight - Group 2 - Field 3, Actuator Motor - Right Headlight - Group 3 - Field 2, Dynamic Cornering - Light Left - Group 3 - Field 3, Dynamic Cornering - Light Right - Group 4 - Field 2, Movement - Front Suspension - Group 4 - Field 3, Movement - Rear Suspension Your volunteer should be able to watch the figures changing as you drive along. If you don't have a volunteer, use the log button to create a CSV file of your drive. If you familiar with excel, you can make graphs to see what happened, if you're not, feel free to attach the CSV here and I'll take a look
Radio swing upgrade
Pretty sure the swing is an all-in-one unit so everything is in the dash. If you want a Bolero, Amundsen or Columbus, they are two parts units. The display is just a display and the actual headunit lives above the glovebox. I only mention it as you'll need to figure our how to extend the wires and possibly swap various glovebox parts to get the new version in.
I think at that point you just hit the On/Off/Next button a few times to complete the basic settings. I'd be tempted to log the front/rear sensor output along with the up/down and left/right motor positions as you go for a drive. That'll confirm if the system is working. The AFS system is pretty good at throwing faults/warnings so given you have neither, it seems like its fine? The missing startup dance is weird, I'd definitely expect to see it with the headlights on as you start the car at night.
