Everything posted by Dean
Parts search - window motor & wiring loom - Skoda Octavia RS 2002
@Octavia47 Are you on any of the MK1 Oct Groups on FB? If so, there are a few people who break them weekly. They'll have the parts needed and more. Look for Gav, I'm sure many others will state that hard parts too. Link Buy as many as you can. I think I have roughly 2 sets from breaking my own over the years, and it's been fortunate that I have to say the least.
- Saving a MK1 Octavia VRS Police Car, FJ54 WYP
MK1 vRS - Stage 2 R-Tech Tuned
Was trying to find the car, but all my searching has surfaced nothing. All the old sites I used for check plates, etc has closed. So, I cannot see retention plates, or reg changes.
Deleting attachments
OK, this is now fixed. However, it is a perk of being a FULL MEMBER. Not a 'Find my way'. There is a minimum of 49 posts which are required to enable this setting. Also, FREEDOM gets this perk too along with other increased profile settings. A word of warning; any images attached to older posts will be deleted and break the flow of the topic. So, be mindful what you're deleting.
- Deleting attachments
Octavia Alternator Removal
Wow, that's done a proper job melting that!
Excellent work, got a photo of it all finished?
Sunroof Seals?
Does this come through the interior light too?
- HELLO
sunshades edition 100
I can confirm, we got this feature too, it's on my current model. (2005)
Access to erwin Skoda
We know it can feel a little frustrating at first. The reason we require at least 20 content items before personal messaging is simply to keep the community healthy and genuine. We’ve found that open messaging from brand-new accounts can lead to spam, unsolicited promotions, or people joining only to message others without actually participating. By asking everyone to contribute a bit first, it helps new members get familiar with the space, join conversations, and become part of the community before jumping into private messages.
If this is the same issue that has plagued us all, were the fuse box on the battery melts? If so, it's very, very common on the VAG range of this year; Golfs, Seat, Ibiza, TT, etc. Search Results for Melted Fuse Box Example
Condensation
Sorry to bump such an old topic, but currently looking for more solutions on the Octavia. Pete, is it the same design by any chance? Any chance of an updated picture to be added?
Front Wiper motor and linkage-compatibility with Mk2 and other VAG systems
No, as the motor always returns to its position. And to be fair, once the scuttle panel is off, its 3 bolts I think to take it out, and the clip on the plug. Not hard at all. Use a flat head screwdriver or something similar to pop the linkage off each other, and take a photo too.
If you look for '443122235017' as it's a universal number it seems. The official part number used in the Octavia vRS - 1J2955113C This also matches - the MK4 GOLF. Part no. 1J1955113B. Plus the Leon, and Audi TT AUQ. Linkage ONLY Part No. 1J0955325A - Should you wish to renew it. I wouldn't worry about second hand. For the sake of £25, it's worth a punt. MK2 1ZU will not fit. When stripping, did you remove the spindles and clean them up? As you will find 3 washers, 2 orings and 1 circlip. It's worth doing that. If my memory is correct. I'm sure you can open up the motor and clean it out and regrease. Those arms, make sure they are straight and the rubber parts all greased too. If you followed a guide, I'm sure you would've done this. I would probably get another set and just swap over the motor and keep the original linkage. Some on ebay for sale: https://www.ebay.co.uk/itm/406534243168 https://www.ebay.co.uk/itm/286879711130 There are loads of people who strip these on the FB group, so you can always get one. I just noticed this. Take out the WHOLE unit, and strip it down on a bench and regrease.
Skoda Scala (2025) Car Seat Covers
I have these for my Octavia - but, they might not be suitable with airbag seats. So, a modification might be needed. https://www.amazon.co.uk/dp/B00MV0VCDQ
Xenon lamp unit question (stupid after owning for 5 years lol)
Yup, all built in.
Intermittent gear change problem
To me, that would sound like some sort of leak or, pipe expanding. The reason they quoted so is due to the recommendation of the doing the DMF while the clutch off. By the time you've factored in the prices of the clutch kit and DMF it won't be far off the price with labour. Of course, shop around. The price does seem a little high to me, I would expect more around the £600-£800... Now, if the car worth it to you and you're going to keep it for a while, then I wouldn't be put off by doing this. I don't really factor things like this in with the car, as with every car it will need doing, just like routine maintenance. Or, I would've got rid of so many cars... This is my personal opinion.
xenon headlight upgrade?
Sidelights are included as mine were LED and would’ve failed straight away. Existing halogen headlamp units on vehicles first used on or after 1 April 1986 must not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp for light source and lamp not compatible. https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-1-4
I had LED side bulbs in mine to match the whiteness of the xenon bulbs, to be fair they were in there when I bought the car. A mate doing my MOT says they have to be removed before I do the MOT, thankfully he had a check over everything for me. I also found I had LEDs for the high beams that made my lights flicker so they came straight out!
WILL LED BULBS PASS AN MOT?There are two popular alternative light sources that are often fitted to halogen headlights – HID and LED. But on 11th January the wording in the MOT inspection manual was updated to state that conversion of halogen to either HID or LED bulbs will automatically fail an MOT. To quote section 4.1.4 of the MOT Inspection Manual: HID lights (high intensity discharge) fitted to halogen headlights have been reason to fail an MOT for a while now, but fitting LEDs has always been a bit of a grey area. Technically only “E Marked” bulbs could be fitted to headlights, and LEDs do not typically carry such markings. However many people would continue to fit them as an alternative for halogen for longer life and greater output. LED’s are also a cheaper and far simpler alternative to HID Xenon bulbs that often require extra work installing additional wiring and ballasts. Any ambiguity on the rules for LEDs has been put to rest with this clear MOT guidance now though. It’s not entirely clear on the reasoning behind this new wording – some cite changes stemming from Brexit, others argue it’s just to keep any loopholes closed. But now it’s important as a motorist that if your vehicle is not using halogen bulbs when it should be, you’d better consider swapping them back as an MOT failure would now be entirely justified.
Remember these lights are over 20 years old now, and comparing to new lights now, they’ll always look dim. You can try and get some brighter ds2’s, but not LED’s if you’re in the UK as it will fail MOT. Orsam or Philips seem to be quite good. Also ensure the lights are clean, inside too. There is a guide somewhere on how to clean the inside but you must take care.
- Xenon headlight sensor
Returning member
Welcome back Lee! Reckon you could start making/selling them again...
- Hello everyone!
