Dean
Administrators
Everything posted by Dean
  1. If buying the Kufatec loom, confirm with the company to make sure it fits. As you’re in Spain, I am unsure if any laws in regards to retrofitting. You’ll have to look around in regard to the extra wire needed to use the full beams. I am sure as they can as standard on my vRS.
  2. I'm sure you've seen it. But, Richard's yellow MK1 is now for sale. A lot of time and effort put in to ask strong money. https://www.facebook.com/groups/1634192436827448/ £3750 2003 Škoda Octavia · Hatchback · Driven 117,000 kilometres 2003 skoda Octavia vrs 117000 miles, Lots of history an receipts Some service history, Forge Front mount intercooler, Various Polybushes including the dogleg, Spax full adjustable coilovers not that old, Rear arb Strut brace Deletes done,ie 249 and Sai Replaced starter motor, Replace steering wheel, New alternator to battery fuse box loom, Decat-2.5 inch pipe with 1 back box not overly loud, sounds nice, Stage one Re-map, New Ramair cone filter/with Neuspeed heat shield New engine bay fuel pipes Engine dress up, Boost gauge, amp gauge, Double din stereo, Cambelt water pump @ 115500 March 25 Cam cover gasket, changed June 25 Power steering fluid changed june25 Fuel filter+pollen filter+new plugs,June 25 oil + filter changed May 25 Both sills repaired professionally , April 25, New power steering pump, oct 25 Recon steering rack, oct 25 New battery Oct 25 Private Plate included Mot till May 2026, Any more info pls pm
  3. Surprised it failed an MOT as both my vRS and my old L&K have never worked. But, the light adjustment does within the headlight. You should see these go up and down with ignition and light on. Just ask them to set the beam pattern manually and it should pass. That way you can look into getting the parts you need as they are quite difficult to get hold of now.
  4. Same way on iPhone. Click and add it to your Home Screen via the Safari Browser. No app, it’s just a simplified version of a browser window that you can have notifications on.
  5. Ah ok, I see. Let us know how you get on. Sorry I couldn’t be more help.
  6. I may be wrong here, but I don’t think it’ll work with that type of radio. There are other listings online for similar products, I would cross reference these and see what radios work. While I like OEM. It’ll be easier just to check a nice single din radio in. It’ll be plug and play.
  7. That would be the first thing I’d remove… Got a picture? These engines do not like blow off valves as they are not designs for them. You need a diverter valve. You can still get the ptshhh sound if you wish with a open cone filter or a cold air induction setup.
  8. While this is connected to the CD changer plug, I don't think these use the CD changer option. It should be using the AUX settings? However, I could be wrong... Either way, make sure you connect the red wire to 12V+, the black wire to 12V-. Then try the CD changer (as I guess it's meant to mimic a connection) and, also try the AUX option too.
  9. Hi Conor, As you look into the engine bay, each side should be a small grommet if it's there, down by the bonnet hinges. From my old L&K. Every time it rained, my carpet was soaked, and it ended up ruining the underlay. I had to rip everything out to try and dry the interior. Under the scuttle panel, to the right of the cabin filter, I had this grommet missing. This was for left hand drive cars who had the bonnet latch wire coming through the firewall. UK cars have it on the right. Purchase a load of bungs/grommets and sealed it over. Never had a leak again.
  10. Not many left, harder to find MK1's in the last couple of years. I'd look in the new year, these seem to pop up in the summer. Keep holding out in the FB Groups I'm sure someone will reply with one for sale.
  11. Unsure if you’re willing to take the badges off carefully, I’d have them please. If not, just a size will do for now. Sorry for the late reply.
  12. Had this happen to me. Thankfully I was doing work on the drive. There’s a strainer on the pickup pipe, but you don’t want that getting clogged up with larger pieces as you’ll starve the engine of oil. Best interest is to order a new dipstick, and get it changed. Drop the sump and clean it all out. While you’re there, you may as well change the pickup pipe…
  13. Indeed. That would be similar to plugging in a device to the wall socket and not connecting it to the device... If there is a wire broken somewhere (as an example), then it cannot communicate.
  14. These work on a loop system. So the rear works off the front loom. A break or corrosion on the wire will cause issues. The above states there is a short to ground, so there must be a break somewhere. I would remove the front door card and inspect the whole loom for continuity. Very common, so look at the blocks, and wires going through the door frames and the B pillar with the connector blocks connect together. Example of what happened to mine (extreme)
  15. Hey, sorry for late reply. I am after the front wing/fender badges. And if there was a spare, to put one on the rear boot. So, yes the fronts please! Custom boot badge using original badging Images owned by JamieP86
  16. Possible this could relate to the pedal brake switch. Worth exploring.
  17. I’d upgraded to the VRS 312s. I’ve just put on some Mtec Disks and pads for the VRS. And see alright for the price.
  18. I might have a spare, but I won't be able to look for another week. If you need it fairly quickly, speak to Gav on the MK1 Octavia FB group. He has about 4/5 MK1 vRS's currently breaking.
  19. Good idea, I'll remember that for my next door handle job! Glad it's all done.
  20. Ah it's the same one I just posted then?
  21. https://www.autotrader.co.uk/car-details/202509036013431 Another #LIMITED EDITION NUMBER #664# #TIMING BELT DONE# #FULL SERVICE HISTORY# #LAST OWNER SINCE 2014# #2 KEYS# #RARE CAR# #12 MONTHS MOT# #WHEELS JUST BEEN REFURBISHED# #ORIGINAL CAR# #CAR HAS JUST ARRIVED IN STOCK MORE IMAGES TO FOLLOW# #CURRENTLY THE ONLY ONE FOR SALE IN ENGLAND#
  22. Did you have a reg or location on this?
  23. Oh yes! Don’t do what I do/did. First time I didn’t realise. But, ever since then I now count the groves left over or use a marker pen.
