Everything posted by Kenny R
DSG advice
It’s fine to turn the autohold off if you require, but if you feather the brake pedal you’ll learn to use the brake without the autohold cutting in when it’s switched on, allowing small movements to be made without having to touch the accelerator.
Karoq Windscreen Wipers
The first notch up is the auto wiper setting and the sensitivity is adjusted using the dial on top or the stalk. Looks like you’ve selected the next notch up which is manual constant, and the next one up is constant fast speed wipers.
Plastic Hub Caps over Steelies - A good idea?
I had VW Caddy centre caps, on my first Yeti winter wheels. I drilled the centers and fitted Skoda centre caps to cover the VW logo. On my second Yeti I had to fit a set of Skoda Riff wheel trims as Mrs R didn’t like the rat look black steelies. The answer to your questions is it’s really down to aesthetics, if your happy with the black that’s the way to go, and you can easily wash salt/ crud off as required.
Dash air vent
front parking sensors
The parking sensors will apply the brakes if the manoeuvre braking option is ticked in the parking and manoeuvring menu.
Just an 'idle' thought.....
- Scala Monte Carlo
Dual zone climate is standard only on the SEL. Monte Carlo trims are usually based on SE spec with some “ sporty” bits thrown in.- Just taken delivery. First two questions.
Only the left mirror dips and the mirror controller on the door has to be turned to L .- Seeing is believing...
And a set of plastic wheel bolt covers.- Personalised Plates... Cool, or Sad?
You cannot use a private number that makes a vehicle look newer than it is.- Personalised Plates... Cool, or Sad?
I had VR51 and my initials on my Mk1 Octavia vRS but didn’t keep it when I traded it in as though it would look odd on another car. I now have a personal current style plate of initials and numbers that are relevant to me. Confuses some folk seeing a 57 plate on a newer car 😂- Strange rear traction noise/reasoning when turn
No, it doesn’t have to been done by dealer, but it does need to be done by someone familiar with what is required. It’s all too easy to mix up Haldex and rear diff drain and fill points, and they have to be aware that the Haldex pump needs removed and the mesh filter cleaned. I believe that you also need to run the pump using VCDS on completion as per this… https://www.haldexrepairs.co.uk/generation-5-haldex-fault-finding-repair-guide/- Strange rear traction noise/reasoning when turn
Well, that’s probably the problem. The Haldex system needs regular services and probably more regularly than the 3 years Skoda state. It also needs the pump filter cleaned as well as oil change. Mine failed @ 14,500 miles.- 7 seater space-saver installation
£288 certainly isn’t cheap especially since it was only around £100 to choose as a factory fit option. I always like the security of having a spare wheel and got the factory fit on my current Kodiaq and the new facelift models now have a spare wheel as standard. I’m sure a how to in the guide section wouldn’t go a miss as there’s always others of the same mind that want a spare wheel and not to rely on the horrible gunk.- Strange rear traction noise/reasoning when turn
I had similar a while back, strangely enough straight after dealer changed Haldex fluid. Dealer fitted new Haldex pump and new fluid again under warranty and it’s been fine since.- Oil Filter location
- Fuse rating
- Order progress
On the Skoda UK website a live chat bubble appears at the bottom right of the screen, click on this and your into live chat. There are reports on here that the system the live chat operators use to check order details is allegedly down and has been for the past 2 weeks. Going by the lack of any tangible updates from my dealer, the whole system is in chaos and they have no clue what’s built, being built, awaiting completion, awaiting transport.- Disappointed in off road performance
You also need to keep the power on if the front wheels do spin, if you lift off no power will be transferred to the rear wheels.- Disappointed in off road performance
1st thing I would have done, is test it for myself to make sure. Don’t always believe what dealers tell/ fob you off with.- "Eco" tyre pressures
If the garage that replaced the tyre or if you had “reset” the TPMS you would not have gotten any warning and would have been oblivious to the fact that one tyre was inflated to 2.5 bar. Which shows the benefits of checking tyre pressures regularly and resetting the TPMS as required. In the instance when you fitted the spare wheel, if you had reset the TPMS, no warning would have incurred.- Rear interior lights
You can switch the interior lights on/ off individually, or switch them on/off using the switch in the front roof console mentioned above, and there’s another switch on there also that operates the interior lights when a door is open.- Heated mirrors
I believe SE and above have heated mirrors. Have you turned the switch to the heated position?- Installing Sat Nav in a model without sat nav
In that case you can instal/ update the map data using an SD card or usb stick from here.. https://updateportal.skoda-auto.com- Installing Sat Nav in a model without sat nav
Depends on what unit is fitted. If it is the Amundsen then it should have been supplied with a SD card with map data installed. If it’s a recent purchase go back and ask for SD card that’s been removed. - Scala Monte Carlo
