Everything posted by Kenny R
2017,Octavia 1.4 auto ,new battery required
£300 + is about the right price for an AGM battery. As above will require coding when replaced. Are you positive, excuse the pun, your +ve terminal is on the left. Normally the -ve terminal is nearest the bulkhead when fitted.
LED Lights
How does mist in the headlights confuse the light sensor that’s mounted on the windscreen?
Rain Sensor on 2016 Scout
Suppose it’s easy enough to check yourself, put wiper in auto position and pour some water on sensor.
Using Apple Play on a Karoq
I’m sure the karoq hasn’t got Apple wireless car play yet. Also I believe current MY21 cars are usb c .
Moll car battery at 11.79V - normal?
No the +ve charger lead should be connected to the battery +ve and the -ve lead connected to the earth tag on the bulkhead adjacent to the battery -ve terminal.
Central locking
If your having to open the door from the outside, either your interior handle is faulty, but you would expect this not just to happen occasionally, or somehow you are activating the deadlock, which deactivates the interior door handles. Are you saying every time you stop the car you are pushing the lock/ unlock buttons?
ADVICE
Towing capacity of SE 5 seater shown here... Just bear in mind it is far easier and cheaper to spec a tow-bar, or at least tow bar prep, as a build option than fit one aftermarket, especially on the latest models.
Multiple Faults?
Sounds like low / faulty battery.
Headlamp washers karoq portugal
Can only presume that the LED headlights in your Karoq have an output below 2000 lumens. Uk spec Karoq that have LED headlights have washers, as does my Kodiaq.
How tough is the Yeti suspension?
Have you seen this..
Water/ice in compartments under boot floor
Is your rear washer operating correctly, or has hose popped off filling your boot.
Rear wiper failed
I’m sure the rear wiper doesn’t work if the boot is open, perhaps your boot wasn’t fully closed, or thought it wasn’t closed. I know the fronts certainly don’t operate if the bonnet is open or of the latch.
High beam wire for 2019 SE Superb Mk3
A simple answer would suffice my curiosity Your curt answer makes me think it is what I thought..
Heated washer nozzles
As you’ve found, having heated washer nozzles doesn’t negate the need for having washer fluid suitable for the current freezing conditions.
Fuels and Oils Skoda Karoq 1.5 TSI Edition
As yours says 95 Ron minimum you are very likely to benefit from improved performance and better fuel consumption using higher octane petrol as in para 2 above. Anyone with 95 recommended Ron sticker are very unlikely to experience any benefits and there is not much point paying the extra 5p a litre. My 2.0 Tsi Kodiaq likes Tesco momentum 99.
The owners manual covers many options and counties that may not be relevant. As above, what does the fuel flap filler sticker say.
Karoq Dash Cam Installation
- Fuels and Oils Skoda Karoq 1.5 TSI Edition
What does the sticker on the back of the fuel filler flap say 95 Ron/ 95 ron min or 98 ron ?- Wheels
Do you have a mode button beside the gear selector, if so press it and see if a snow mode comes up in the options.- Wheels
17” steel wheels are hard to come by. 16” wheels with 215x60 tyres is a recommended size for winter wheels for a Karoq.- Wheels
Find another dealer that’s willing to put a bit of effort in. The correct part no for 16” steel wheels is 5Q0601027CJ03C You can also get steel wheels with winter tyres from the likes of mytyres. Com Please don’t be tempted to just fit winter tyres to only the front wheels.- Tire Pressure Monitoring System - any user interface other than "set now as good" and "idiot light"?
The “ idiot light” system has worked well in my previous Yeti and current Kodiaq and informed me of a screw in the tyre causing a slow leak on both occasions.- When is the new kodiaq out?
What new Kodiaq?, it’s not even had it’s face lift yet, but expected this year.- Tinted
Can’t see it from here- Definitive Tyre Fitment info - where the hell from!?
