Everything posted by 26DIPP
Change Units in virtual dash
I do not have "Units" as a subcategory. I had a look through my adaptation maps of STG 09, 17 and 5F as I thought these might be relevant for the Units. I can see a section inthe dashboard that describes all the customer set ones, but no sectio that make "Units" appear in the settings section.
All lights in headlight on ONE side not working
I don't know about the indicator. Side light, low and high beam are not working. I did not think to ask about the indicator.
Hi, My daughter has just told me that all lights on her FII from 2009 are not working onthe left. I do not have access to the car right now, but guessed and googled that it could be a fuse problem. Am I right or is it a long shot to tell her to check fuse 56 or 57?
Hi, I hope someone can help me. We have gone into continental Europe and I wanted to change the units from miles and MPG to kilometers and L/Km. I am sure I have done this once before because we did take the SIII abroad. I cannot not remember but there is no clue in any of the menue buttons in the headunit. I have looked in car and setup, but no unit settings. I only hope I have not coded this out by mistake, but have never intentally changed anything around unts.
Mold
Check for any leaks. Hire an ozon humidifier to fog the inside of the car.
Skoda Fabia 2 2008 Electrics Playing Up
Are your electrics still playing up? Did you have a bad battery? All these functions are on different fuses and in different controllers.
Interior light & door open dash icon coming on
My daughter's Fabia had the same problem. There was a broken wire in the door loom at one point, which I soldered in the loom. I added an extra piece of cable in. But the fault came back. Only this time it was a microswitch inside the door lock. I started a thread on this and you will find pictures. Eventually I bought a new door lock.
16 inch alloys on MK2 Fabia
- VCDS options on Superb III.FL
This is one way of changing CH / LH. You can choose different light combinations. Start / Stop can be turned off on very old models but not on the newer ones.- VCDS options on Superb III.FL
Hi, Yes you can.- VCDS options on Superb III.FL
From memory you put the Ah in and just add +1 to the battery code from the old one.- Superb, Kodiaq, Octavia, Kamiq heated steering wheel - SOLD
Want it? Still for sale.- TSR now available in Skoda shop
I noticed that an activation for TSR is available in the Skoda shop for 2022 Octavias. Other models have not been listed. Does anyone know if the A5 camera and other components are different on the Octavia compared to other Skodas of this age? I am still interested in the TSR activation for our SIII from 2023.- Superb, Kodiaq, Octavia, Kamiq heated steering wheel - SOLD
I am selling a Skoda 2-spoke leather steering wheel. This is off a 2023 Skoda Superb. It is in very good condition with no marks or scratches. It has the following features / functions: paddle shift for DSG heated stearing wheel control volume control source control for the head unit voice control - Lara virtual dash board design control to change the layout assistant control to change the centre part of the dash board The part number is 5E3 419 093 AK VKH. This should fit the following models: Skoda Superb, Octavia, Kodiaq, Kamiq. Price: £85- VCDS options on Superb III
I have used engine off for about 40 years. At first in the 80ies and 90ies when engines were really using fuel and I was a student, it was to save money. It worked. No engine, battery, ignition or other issues ever. I usually kept cars for quite a while. I have done this on european - Volvo, Opel / Vauxhall - and japanese cars and when start / stop was introduces I often thought that engines could switch off when the ECU prevented them from doing so. On my last Superb - SII - the battery went after ten years. I never had a problem of not getting off the spot or not being in control ever - how can you not be in control? You have so many controllers on your car that control everything from steering to braking, so effectively on a modern car YOU are really not in control ever..... @Meridion, engine manufacturers have long gone away from the concept of running in new engines and with some diesel engines it can take forever for the engine to be at working temperature. You will have more wear if you stick to mega long oil change intervals.- Travel assist retrofit
So sad, I just had a look in my steering wheel if I can fit the KLR Evo. There is no KLR module at all. Mind you I do not have TA in the steering wheel. So I guess they would not have put a dummy holder in there or can the KLR module holder be retrofitted?- Software failure not so Superb
OOOOH, Subtle is different... Is this the SEL steering wheel or will that be the one now? I am sure they could have got the lettering even bigger. Software is definitely an improvement.- Travel assist retrofit
Hello Mario, How easy is it to remove the steering wheel airbag? Any hints?- Kodiaq 2023 heated steering wheel retrofit
Hi, Have you done it yet? How easy is it to remove the airbag?- Mib3 Map Updates 2024.06
Hi Tell, Thanks for the in depth reply. You mention presentation. I downloaded straight off the server with the VIN. It is the file starting OI... . I opened the zip and copied all the separate files onto the stick. There was no messing about. Or would my system still be up to date with the files updated in February?- Mib3 Map Updates 2024.06
Hello, Could I have some advice on what type of USB C adapter I have to use to copy / upload data into a Superb III MIB3 - sadly. I am trying to update the maps and also radio station logos. I have used a 32 GB USB stick formatted to FAT32 with a USB A to C data adapter - no luck. I have bought a 64 GB USB stick with USB A and C connectors. This 64GB stick can only be formatted to exFAT as windows only formats up to 32GB in FAT32. Still no luck with either the maps or radio station logos. What devices other than the Skoda ones do people use?- Software failure not so Superb
Why can they not just do over the air? It works for some of their other software updates. My "old" 2023 SIII tells me occasionally that new upgrades are available.- Software failure not so Superb
Hi, Yes this is the thread. This sounds like a few levels below the briskoda thread, unless there are fewer users with a new SIV on the german site or the briskoda owners ofa SIV are massively exaggerating. - VCDS options on Superb III.FL
