MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. then i had false expectations about [MODE] button, yes, Speed Limiter can be chosen on Virtual Dashboard looks like i found how to add CC Module 13 Adaptive Cruise Control Long Coding -> Cruise Control Mode --> Activated source: https://forum.obdeleven.com/thread/16300/add-regular-cruise-control-feature https://forum.obdeleven.com/thread/18012/long-coding-activate-cruise-control https://forum.obdeleven.com/thread/18036/deactivate-acc-normal-cc can't test, car is gone to dealer for first unplanned service visit, logo projector tried to escape, wires held it
  2. as i have read reports, DQ381 7 gears is more economical than DQ250 6 gears current winter tires are same size as previous 225/55r17 summer will increase in width and decrease in height/circum, 235/45r18 vs 225/55r17 then i had false expectations about [MODE] button, yes, Speed Limiter can be chosen on Virtual Dashboard 1. +1 000 000 i have even sent letters to dealer, importer and Škodas CZ support for new options in configurator: a) ~400e Black Exterior pack Light (Door Trims) b) ~600e Black Exterior pack Medium (Door Trims, Front Grill, Trunk Trim) c) ~800e Black Exterior pack Extended (Door Trims, Front Grill, Trunk Trim, Spoiler) d) ~1000e Black Exterior pack Complete (Door Trims, Front Grill, Trunk Trim, Spoiler, Roof, Rear Skirt) 2. that were first years privilege, now even Amundsen is paid option 410e while Columbus costs 1370e, but i chose Amundsen mostly because real volume control roller 3. sad 4. I try to limit myself, while numbers on odometer is smaller than four symbols :) but one change is noticeable, sensitivity of accelerator increased, if compare with previous, somewhere between normal and sport mode
  3. First emotions after one weekend and first ~400 kms Have to start by few huge disappointments: 1. Line assist goes from one side of line to other side ping-pong 😞 previous 2016. kept middle of the line +++ 2023.03.01 +++ dealer answered, additionally to Line Assist must be activated also Travel Assist, not tested yet +++ 2023.04.07 +++ ping-pong effect can be little bit improved, but fix requires cam software downgrade -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5746167 2. Adaptive Cruise Control missing manual mode 😞 few kms in snowing condition and there is none Cruise Control at all my previous 2016. also had this lack, but i have seen several posts where were reported new [Mode] button on bottom side of Cruise Control stick, when(~2017~) it came and when(202?) it were removed? +++ 2023.03.01 +++ solved by coding -> https://www.briskoda.net/forums/topic/511031-standard-cruise-control-on-an-acc-equipped-superb/?do=findComment&comment=5737174 3. Engine has lost a cover 😞 as result it's loud as diesel, just without tractor vibration. still waiting for answer from dealer, will it be added later or never +++ 2023.03.01 +++ dealer answered, will arrive, no one knows when. +++ 2023.04.24 +++ retrofitted Engine Cover 06Q-103-925-L for 2.0 TSI 280ps DNFE +++ 2024.01.15 +++ received an invitation from dealer 4. Every ignition On/Off resets Driving mode 5. Mib3 head units don't allow upload logos of Radio Stations +++ 2024.01.18 +++ managed to find how to update built in database -> https://www.briskoda.net/forums/topic/520105-radio-stations-logos-database-updates/ Minor disappointments: 1. L&K had to get Direct Tire Pressure Monitoring System, but mine came without. not a big deal, as i prefer alternative independent dTPMS sets from Ali, just for what reason i have bought and mounted second OE sensors set into winter wheels? 2. There is no coding to activate Eyelashes with DRL 😞 3. 9l on 100km fuel consumption where previous 2.0 TSI 220ps had 7.5 4. Škoda's Moon White isn't white at all 😞 Huge improvements: 1. 2023. Amundsen Canton soundings much better than 2016. Columbus Canton and i predict, it will even improve after adding sound deadening 2. Finally i have got feeling of new car, 2023. DCC suspension has zero parasitic sounds. Instead 2016. DCC had them from beginning and weren't fixed even after couple of manipulations - warranty change of rear brushes, both front shocks, 3x steering rack, and later replace all of shocks to Bilstein B6 DampTronic, which hugely improved driving performance, but noises were gone just partly yes, new DCC is softer than perfect tandem, Bilstein B6 + Eibach Pro, but acceptable in sport mode, at least for first years 3. Webasto auxiliary heater can be activated from MyŠkoda app 4. Blind-spot indicator on Mirrors body is much better place 5. Boot opening now asks for long press of button, but can't be closed from interior, Mk3 had coding for that, Mk3.FL hasn't 😞 . . . . . .
  4. similar troubles with "chrome" -> https://www.briskoda.net/forums/topic/406172-change-of-color-of-door-chrome-strips/ painted all door trims to black -> https://www.briskoda.net/forums/topic/367311-the-superb-iii-picture-thread/?do=findComment&comment=5570909
  5. 2023.01 280ps DNFE came without cover as result, it's lot louder than my previous 2016.02 220ps CHHB waiting for info from dealer, will it be added later or never
  6. I left Waze's voice on phone speaker What interesting, for BT sources volume is decreased on Waze msgs, but FM not
  7. @Angelo Amato Thanks! a lot of different profiles, but none similar i wrote them message
  8. @Kasper_DK browse link i posted above
  9. perfect! 11-79-008-01-HA is little bit low even on FWD Hatch, check pictures few posts above i can suggest four lottery tickets 11-79-013-01-RA 11-85-016-10-HA 11-85-026-03-HA 11-85-011-01-HA
  10. @Kasper_DK OE Sport springs will be too soft anyway, i have installed Eibach Pro, but to prevent unnecessary lowering i took from weightier car -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/?do=findComment&comment=5689278
  11. after 4 years OEM springs were dropped ~30mm replaced to stiffer Eibach Pro -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/?do=findComment&comment=5681671
  12. by GUI and maps numbering looks like Mib2H # 2015 P39 # 201? P49 # 2018 P68 # 2018-2019 P71 # 2019 P76 # 2019-2020 P79 . . . . . . # 2022-2023 P101 # 2023 P313
  13. painted roof, mirror covers, rear skirt to black and number plate holders to white on my brand new L&K 280ps step by step to design which were presented at the Geneva Motor Show, but weren't adopted on production line 😞 previous also were Style at beginning
  14. replaced -> https://www.briskoda.net/forums/topic/457537-replace-oem-xenon-with-osram-d3s-next-gen/
  15. -> https://www.briskoda.net/forums/topic/368574-vcds-options-on-superb-iii/page/69/?tab=comments#comment-5338494 it's perfect for DRL/Xenon switching, but extremely too late for automatic High Beam, sometime have to visit subsection in head unit and change 'Late' to 'Early'
  16. @Camarao69 order better new, whole part, from Ali -> https://www.aliexpress.com/w/wholesale-skoda-superb-rear-air-vent.html
  17. no, it's hardware limitation 😞 but all three of present colors can be customized -> https://www.briskoda.net/forums/topic/368574-vcds-options-on-superb-iii/?do=findComment&comment=5478337 -> https://www.briskoda.net/forums/topic/428238-ambient-lighting/
  18. got call from dealer, 280ps L&K arrived! ordered 2022. apr, haven't seen yet
  19. 1) press and hold lock button on the key
  20. please add some info what kind of LEDs? i have add four of these in to current MY16 -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=4842014 -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=4893173 and there are any problems with them. already ordered new fours for my coming MY23, don't need that surprises
  21. me to "can't" test full diameter spare wheel replaced OEM 205/55r16 by custom 205/65r16 in far 2017.
  22. to avoid guessing what's wrong, i have installed dTPMS alternative set, independent to car's system -> https://www.briskoda.net/forums/topic/434028-tire-pressure-monitoring-system/?do=findComment&comment=4893182 there is info how to install OE set, integrated to car's system -> https://www.briskoda.net/forums/topic/488740-my17-superb-retrofitted-with-direct-tpms/
  23. any of OEM springs will be too bouncy, as result annoying waterbed. and note, "Sportline" springs aren't the same as springs from optional "Sport suspension" i can promise, these(fronts F11-85-043-02-FA) Eibach Pro won't be too hard, just stiffer without lowering. for double check, ask to @fencer -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/?do=findComment&comment=5713073 for wagons or AWD hatchs rear, maybe these will be better 11-85-016-10-HA or 11-85-026-03-HA not tested, guessing just by looking on springs specs
  24. also on Style as option, together with leather seats, but never have been available for Sportline
