Everything posted by MartiniB
The 280PS Thread
i would say more, out of stock in Europe 😞 still waiting rear's since august -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/?do=findComment&comment=5620484
- Memory module for Start-Stop button
@Colin170CR @Timmyboy Amazon/Ebay/Ali's aren't genuine - smaller https://www.drive2.ru/l/500982303787319849/
Start Stop Issue Skoda Superb 280ps 4x4
https://www.briskoda.net/forums/topic/485940-memory-module-for-start-stop-button/
Filler cap stuck query
choose newer revision when replace 510 810 773 A -> www.drive2.ru/l/579792548487233855/ 8V0 862 153 B -> www.drive2.ru/l/600025211705759752/ instead my dealer installed old 510 810 773 -> https://www.briskoda.net/forums/topic/459115-instructions-for-winter-refueling/?do=findComment&comment=5515671
Sportsline Fuel Consumption
highly depends on driving style, 2.0 TSI isn't for economy, but for pleasure 220ps FWD DSG6 Tires +1.5% in diameter - 225/55r17 98E avg l/100km 2016 9.6 2017 9.5 2018 10.1 2019 10.7 2020 9.8 2021 10.4 last year i hadn't abroad trips, there is 2020. where beginning and end of year contains 90% urban + ~30 minutes Webasto each day 13.7 12.7 12.8 13.1 11.8 12.7 12.6 9.3 11.2 11.8 10.8 7.8 7.6 7.5 7.5 7.6 7.2 9.5 7.9 6.4 7.8 8.4 13.0 9.0 11.5 15.6 13.5 15.6
Superb III Sportline 190 suspension wallowing and pothole bumps
@BPL use board-search 'suspension' -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/?do=findComment&comment=5625462 . . . . . .
MY17 Superb Retrofitted with Direct TPMS
alternative dTPMS display can be kept in whatever pocket you like (place under windscreen helps to charge it by solar panel, but it can be connected to 5v MicroUSB cable) opposite to OEM system, where info is always hidden under several sub-menus i never have told OEM system is bad choice, just alternative isn't as crime as someone described here yes i know, mainstream population is happy with limited functionality of Android Auto / Car Play on head unit's screen, but i prefer independent displays - phone's 6.7" for navigation (Waze for local routes, Google Maps for abroad trips) while head unit's 8" will stay free for multimedia and drive modes
Superb III Stop start 190 sportline 2020
use board search 'battery'
with alternative, independent, dTMPS kit these positions not required additionally it will show temperature too 53€ 2017 Direct TPMS Set works well since 2017. jun 3.61€ 2020 Direct TPMS Set not tested yet
Skoda Superb Gearbox Rattle
@Stiggy no, he swapped new Superb to used BMW
Tyre Pressure Monitoring Display
@WibblyPig use boardsearch 'dTPMS' start with this -> https://www.briskoda.net/forums/topic/488740-my17-superb-retrofitted-with-direct-tpms/
Columbus Map Update 2022 (MIB1/2 HIGH)
@Garrardrj at which point you have problem? -> https://www.briskoda.net/forums/topic/452002-direct-download-links-for-ece-20182019-maps/page/2/?tab=comments#comment-5095042 couple of potential questions are answered in previous posts: Columbus Maps 2021/2022 Columbus Maps 2021 Columbus Maps 2020/2021 Columbus Maps 2020
by shown title of current maps, i can guess for sure, it is correct device for these maps, Mib2H 0086 ECE 2014/2015 0123 ECE 2015 0134 ECE 2016 0157 ECE 2017 0161 ECE 2017 0166 ECE 2018 0169 ECE 2019 0175 ECE 2019 0177 ECE 2019/2020 0184 ECE 2020 0187 ECE 2020/2021 0189 ECE 2021 0192 ECE 2021-2022 0195 ECE 2022
@Garrardrj Mib2 SD Card slot is located in glove box also USB slot can be used to upload maps in to head unit
Mib1 DVD Mib2 SD Card or USB
Automatic lights on
in settings there is option early/late for lights, the problem is it's only one - for Low Beam i prefer 'late' but for High Beam 'early', in other case it waits for complete darkness - video 175Mb threshold for Low Beam i have changed too https://www.briskoda.net/forums/topic/368574-vcds-options-on-superb-iii/?do=findComment&comment=5338494 haven't found solution for High Beam
Uprating rear suspension?
on rear axle can be installed stiffer Eibach springs from AWD Superbs Eibach Pro F11-79-008-01-HA which give 0 lowering on FWD cars on front axle already have installed Eibach springs from Q2; Tiguan Eibach Pro F11-85-043-02-FA -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/?do=findComment&comment=5620484
Taillights
Tere! replace to another lights, part codes you will find here https://www.briskoda.net/forums/topic/476310-new-fl-skoda-superb-2020-tail-lights-retrofit/
Bilstein B6 DCC shock absorbers available at last
@MarkyG82 Answer is one post above, AWD springs on FWD car
Adding stiffness without lowering succeed the answer is Eibach Pro front springs from Q2; Tiguan marked red, these, which officially offered for Superb Mk3 by Eibach by car weight by springs specs by now only front axle got new set 23-254343 Bilstein B6 DampTronic F11-85-043-02-FA Eibach Pro distance between wheel center and arch corner l. 380mm r. 379mm with DCC 3Q0 413 031 AK 5Q0 411 105 GL were l. 374mm r. 372mm waterbed is completely gone! but changed DCC's modes are almost unnoticeable now some small rattles still there, replace of these parts improved situation partly 5Q0 412 249 E 5Q0 412 331 C 5Q0 413 175 C N 0150816 N 10106402 N 90954802 N 91246401 N 91021601 1K0 412 303 E 5Q0 412 545 D front axle 1 165 € <edit 2025> my next car, 2023. Mk3.FL 2.0 TSI 280ps AWD, got the same upgrade at it's first anniversary, this time without waiting for warranty cases -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
Alloy wheels - swapping OEM wheels
@JR RS btw. 245/45/18 and 245/40/19 are identical in Width and Diameter me too installed 225/55r17 instead 215/55r17 to add 10mm in Width, 5mm in Height and 1.5% in Diameter https://tiresize.com/comparison/
Strange buzzing sound after acceleration
board search -> https://www.briskoda.net/forums/search/?q=rattles orchestra&type=forums_topic&nodes=299
Replacement Wipers
for LHD (left-hand drive) cross compatible: 3V1 998 001 650; 450mm Superb 3 3v1 955 425 650; 3v1 955 426 450mm 5G1 998 002 650; 450mm Golf 7 3G1 998 002 650; 475mm Passat B8 1K0 955 429 B rubber only 3397007863 650; 450mm Bosch AeroTwin A 863 S 3V9 955 425 rear Superb 3 Combi for RHD (right-hand drive) 3V2 998 001 Superb 3
Superb MKIII owners register
yes +1 none of built in systems can be near online maps i prefer Waze for daily routes and Google Maps for abroad travels
