MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. Adding stiffness without lowering succeed the answer is Eibach Pro front springs from Q2; Tiguan marked red, these, which officially offered for Superb Mk3 by Eibach by car weight by springs specs by now only front axle got new set 23-254343 Bilstein B6 DampTronic F11-85-043-02-FA Eibach Pro distance between wheel center and arch corner l. 380mm r. 379mm with DCC 3Q0 413 031 AK 5Q0 411 105 GL were l. 374mm r. 372mm waterbed is completely gone! but changed DCC's modes are almost unnoticeable now some small rattles still there, replace of these parts improved situation partly 5Q0 412 249 E 5Q0 412 331 C 5Q0 413 175 C N 0150816 N 10106402 N 90954802 N 91246401 N 91021601 1K0 412 303 E 5Q0 412 545 D front axle 1 165 € <edit 2025> my next car, 2023. Mk3.FL 2.0 TSI 280ps AWD, got the same upgrade at it's first anniversary, this time without waiting for warranty cases -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
  2. @JR RS btw. 245/45/18 and 245/40/19 are identical in Width and Diameter me too installed 225/55r17 instead 215/55r17 to add 10mm in Width, 5mm in Height and 1.5% in Diameter https://tiresize.com/comparison/
  3. board search -> https://www.briskoda.net/forums/search/?q=rattles orchestra&type=forums_topic&nodes=299
  4. for LHD (left-hand drive) cross compatible: 3V1 998 001 650; 450mm Superb 3 3v1 955 425 650; 3v1 955 426 450mm 5G1 998 002 650; 450mm Golf 7 3G1 998 002 650; 475mm Passat B8 1K0 955 429 B rubber only 3397007863 650; 450mm Bosch AeroTwin A 863 S 3V9 955 425 rear Superb 3 Combi for RHD (right-hand drive) 3V2 998 001 Superb 3
  5. yes +1 none of built in systems can be near online maps i prefer Waze for daily routes and Google Maps for abroad travels
  6. then it's Amundsen. Columbus stores map files into device and for upload can be used any SD Card or USB Stick
  7. +1 just i took few times cheaper independent alternative(Ali) it worth! never have seen which exact tire, maybe MY17 got upgraded iTPMS version than my MY16
  8. if developers can disable, then they can code also speed limit even printed value on spare disc would be better than nothing for me, ~80 kms on nightly, empty and straight highway were enough to decide replace stock 205/55r16 by 205/65r16 tire on the spare wheel
  9. wrong, when installed spare wheel then reset doesn't help, warning disappears just for short time. also Cruise Control can't be activated, as result i installed full diameter tire on stock 16" spare disc -> https://www.briskoda.net/forums/topic/442912-full-size-spare-wheel/page/2/?tab=comments#comment-5040470
  10. nothing of listed, Indirect TPMS reporting false alarms few times a year
  11. @KenONeill bla bla, bla bla several times have seen and which exact tire has problem?! first few warnings were false after checkout, and there is result of ignore one true alternative kits are enough cheep -> model 2017. 53€ -> model 2018. 30€ -> model 2019. 27€ -> model 2020. 20€
  12. Indirect can give false and late warnings
  13. Install Direct TPMS -> https://www.briskoda.net/forums/topic/488740-my17-superb-retrofitted-with-direct-tpms/?do=findComment&comment=5487683
  14. Finally have received package from Tuning-Expert.com ordered Eibach Pro F11-85-043-02-FA front Eibach Pro F11-79-008-01-HA rear Bilstein B6 DampTronic 23-254343 front Bilstein B6 DampTronic 20-267537 rear, had to remove due out of stock ordered: 2021-08-12 shipped: 2021-12-17 arrive: 2022-01-06 installation: 2022-01-19
  15. @dreema Click on second link i posted above, 125/70r18 is the worst option, but better than nothing
  16. recommending custom, full diameter, 205/65r16 -> https://www.briskoda.net/forums/topic/442912-full-size-spare-wheel/page/2/?tab=comments#comment-5040470 Pros and cons of different spare wheel options -> https://www.briskoda.net/forums/topic/494383-can-anyone-with-a-20-tsi-220-factory-spare-wheel-tell-me-the-size/?do=findComment&comment=5550057 -> https://www.briskoda.net/forums/topic/493502-full-sized-tyre-as-spare/?do=findComment&comment=5556680
  17. @koborn then download from VW's or Seat's portal Amundsen (Mib2) -> https://www.briskoda.net/forums/topic/498473-amundsen-mib2-map-updates-202223/ Columbus (Mib2H) -> https://www.briskoda.net/forums/topic/498563-columbus-map-update-2022-mib12-high/
  18. from Å koda's portal you can download only previous 1730 release for latest 1810 use links to VW's or Seat's files
  19. 1. Original 2-3. Bilstein B4/B6 DampTronic and two lowering sets 4. KW Street comfort 5. Bilstein B16 DampTronic
  20. looks like Mk3, but i haven't seen Mk2 https://shop.parks.uk.com/products/skoda-front-rubber-floor-mats-superb-iii
  21. several false warnings made me ignore one true and i blew up rear tire. (on ~110kmh speed) i recommending install Direct TPMS, because our default Indirect is based on disk rotation count information, which is provided by ABS cheep -> https://www.briskoda.net/forums/topic/434028-tire-pressure-monitoring-system/?tab=comments#comment-4893182 OEM -> https://www.briskoda.net/forums/topic/488740-my17-superb-retrofitted-with-direct-tpms/ about spare tire - our stock size spare tire is 5.6% smaller in diameter than regular tire i recommending replace it by closer size -> https://www.briskoda.net/forums/topic/442912-full-size-spare-wheel/page/2/?tab=comments#comment-5040470 -> https://www.briskoda.net/forums/topic/494383-can-anyone-with-a-20-tsi-220-factory-spare-wheel-tell-me-the-size/?do=findComment&comment=5550057 -> https://www.briskoda.net/forums/topic/493502-full-sized-tyre-as-spare/?do=findComment&comment=5556680
  22. @Bap33 just one huge problem - spare parts shortage 😞 i placed order in august: F11-85-043-02-FA Eibach Pro (front) F11-79-008-01-HA Eibach Pro 23-254343 Bilstein B6 Damptronic (front) 20-267537 Bilstein B6 Damptronic but delivery date is moved forward several times, past week i asked seller to cancel rear dampers, to able start upgrade at least with front axle. another unclear question is which exact damper for rear axle Bilstein suggests 20-267537 while couple of other sellers suggest 20-254353 (both are out of stock) probably, must be cross compatible for these MQB platform cars 20-254353 Arteon; Golf; Passat; Octavia 20-267537 Arteon; Golf; Superb; Touran
  23. @Joukkis start by download two year newer maps -> https://www.briskoda.net/forums/topic/498473-amundsen-mib2-map-updates-202223/
