AGFalco
Everything posted by AGFalco
  1. You can download maps first at home via wifi, and then use them offline so you use no data at all. I also use this when I go abroad. This also works when you don't have a mobile data connection. Thanks. AG Falco
  2. It is normally the sensor that gets broken, not the valve stem! Does the car tell you the individual tyre pressures? Thanks. AG Falco
  3. So the wife went to use the Fabia yesterday and got the spare car key out of the cupboard. But no red light on the fob when pushing the buttons. ( Flat battery? ) This key is hardly used. When I get home I try my key ( which is used every day ) and this still works. So I think that the battery in the spare key that is hardly used, is flat. So I swap the batteries over in the keys. But the battery from my key wont work in the spare key. So is there a fault with the spare key? And the battery from the spare key wont work in my key. So I swap the batteries back and then at least I have one working key. Today I go to Bath with my key and when I try to come back, guess what. My key stops working, no red light on the fob. So I get two new batteries, CR2032's are tight but will fit, and guess what, they both now work! This is the first time I have fitted new batteries in either key in 7 years since new. So does the battery last longer if you use it every day? Thanks. AG Falco
  4. You are checking for a saw edge pattern on the inside edges. If they are NOT directional tyres then try swapping them from side to side. Thanks. AG Falco
  5. Rear tyres? Inside Edge? Thanks. AG Falco
  6. Would agree. Thanks. AG Falco
  7. How much fuel in litres did you use? Thanks. AG Falco
  8. Is the direction marker on the dial 180 degrees out? Has the dial been fitted wrong? Thanks. AG Falco
  9. With a smart charger and not connected to the Negative battery terminal? My Stop/Start battery is still good from June 2016 at 73K miles. I would agree with this. Is a 2021 battery still in warranty? Is it an AGM or an EFB battery? Check the top of the battery. Thanks. AG Falco
  10. Is it a Stop/Start Battery and did you charge it on the car? Thanks. AG Falco
  11. I use the 10 BAR compressor at work. Although this wont fit in the back of any of my cars. I have a small 12 volt compressor at home which is fine to just pump the tyres up. Don't rely on the pressure gauge on the compressor though. Thanks. AG Falco
  12. 063 is 175 mm high. 027 is 190 mm high. How high is the present battery? If a bigger one will fit then buy that one. Thanks. AG Falco
  13. Yes. on the S level it was an option. Thanks. AG Falco
  14. Half way down the hinge end of the door by the check strap bar. Thanks. AG Falco
  15. Have you swapped the fuse or has it blown again? Is there any voltage behind the 12V socket? Do you need the ignition on? Thanks. AG Falco
  16. See my posts on 23 April and 24 April above. Thanks. AG Falco
  17. See ALL of this post:- My Fabia III 2016 has 72K miles and the belt still looks good. Thanks. AG Falco
  18. Can you weld them back together using the soldering iron method? Thanks. AG Falco
  19. TPS. Look here:- Mine did, but mine is a facelift version, post 2017. Yes, see above. Thanks. AG Falco
  20. The Suzuki Swift you drove might be a bigger car and have a a bigger / more powerful engine than the Citigo. Which one did you drive? Is the engine full of oil? Heat shield loose? Exhaust getting old? Under bonnet sound absorbing mat can be fitted. See post from 12 Nov 2022 below:- Thanks AG Falco
  21. My TSI Fabia has this feature but my MPI Citigo does not and the Citigo is newer. Thanks. AG Falco
  22. Just did my Fabia's 8th service including spark plugs and air filter. Note, spark plugs are due at 40K miles and air filter at 60K miles. No change to mine. Is this the first car you have had with this anti stall feature? Try applying a small amount of throttle and holding it before you lift the clutch. Thanks. AG Falco
  23. Look OK, but worth doing. Thanks. AG Falco
  24. So don't do this. It sounds like you are not quite used to this feature. It took me a while. 😒 Thanks. AG Falco
