Service schedule 1.5tsi
Hi Lee, with your low annual mileage, your car should really be on fixed annual servicing - they usually leave the factory set for variable servicing - but you should have been asked if you wanted it changed to fixed at the handover. SFAIK the system will not change servicing regime according to actual mileage travelled.
Horn stopped working
That clicking sound will most likely be the relay, so that appears to be working ok, although the relay contacts could still be the problem.
Gurgling sounds from the tailpipe of our Skoda Octavia
Could very well be condensation then - surface water spraying up from roadway and cooling the exhaust system could make it act like a condenser. Is your engine petrol or diesel?
Bon soir, Monsieur, welcome to the forum. This is most likely just heavy condensation in the back-box, although it could also be a loose baffle - although that usually sounds like a rattle. Does the sound disappear after a longer run?
Is it dead? Roll up, roll up, place yer bets....
There are some LiFePO4 batteries out there suitable for starting cars - some up to 1400 amps rating. Price is very high at present, but I can see that improving in future.
Hi JR - while that is true for Lithium Ion and lithium Polymer (LiPo) cells, it seems that this is not the case with Lithium Iron Phosphate (LFP) cells.
Perhaps we will soon start to see lithium starter and hotel batteries (in EVs) being fitted as production costs drop. Note to self - do a search for cost comparison between AGM and Lithium ion batteries.
1.4 TSI DSG Cam belt or chain?
And when it does eventually fail, the engine most probably will be scrap 😒
Morning LOL, did you mean 'are now moving to lithium batteries' - rather than 'not' in your last sentence? The only real problem I can see with Lithium batteries would be thermal runaway - but that certainly appears to be very rare now.
Thoughts on timing belt changes
Engine code is first 3 or 4 letters of your engine number, it is listed on line P5 of your V5 document.
Faraday/key pouch
Hello Adz, unless you have keyless entry or full Kessy, there is no need for Faraday pouch. If your remote is press-button type, key fob only transmits code when button is pressed.
Octavia iV Estate - flat 12v battery
I suspect that if 13.1 volts is the maximum charge rate delivered, the hotel battery will not fully charge in the time it takes to recharge the HV battery.
- Battery Help - Please
Is possible convert Regular Skoda Octávia Combi mk2 to Scout?
^^^^^ This plus suspension lift.
Oil topup quantity 1.5l petrol
As @toot says, you need to get an accurate level reading first - this can only be done when car is on level ground. Consequences of significant under or overfilling oil are equally bad for the engine. I would suggest adding no more than 1/4 litre until you can get the car to somewhere the level can properly checked.
At 13 .1 volts, your hotel battery would barely be receiving a charge, correct charging voltage for AGM or EFB is around 14.7 V. It is possible your existing battery has become badly sulphated, affecting the charge rate, but If that is the maximum charge rate available while the HV battery is being charged, I can see more problems in the future, even with a new battery.
Closer to 10%, but nowhere like enough to prevent drastic reduction of life. Persistent undercharging, even at around 60%, (approx. 12.3 V) is not great for any lead-acid battery.
Not the same as my Octavia is Mk3 - but I had both battery and alternator replaced in first year of warranty. Replacement battery (Moll EFB) is still reasonable at 6 years, despite low annual miles.
@rmills has anyone actually checked the terminal voltage of the hotel (starter, etc battery) when the HV battery is charging?
I would expect a reasonable life to be at least 4 to 5 years, I would not expect the hotel battery in a hybrid vehicle to have a shorter life than an ICE. A lot depends of how the battery is treated - no lead-acid battery likes deep discharges or persistent undercharging. Have you been told why your battery does not appear to be charging properly?
I assume that you are aware that at 11.6 volts your battery is more than 50% discharged - even with regular recharging, the life of that battery will be drastically shortened.
Rob's Ur Quattro
Happy New Year Rob, great that your move is completed now - that's real RD country, no problem with noisy neighbours eh? Is that a bach on your property too?
Hello from Northern Ireland
Hello John, welcome to the forum.
OEM SATNAV
Hi Matt, you probably have MIB2, if you post a pic. of the infotainment head unit, the system can be identified.
- Timing belt
