Warrior193
  1. Welcome to the forum. Your concerns about the DSG would tend to suggest it's a wise decision to leave it. Sounds expensive too, if exterior condition is as you describe - also a little odd given the interior condition.
  2. If the shift is fly by wire as E13 says, a failing battery can definitely be the cause of many electrical gremlins. 11.6 volts on no load is below 20% SOC and is well below battery danger level!
  3. If the washer pump is actually operating without any fluid appearing at the rear nozzle, I'd be checking for a blockage, kink or leak - possibly where the washer hose loops between the body and the rear hatch/tailgate.
  4. AFAIK, Galvanic action is possible whenever any less-noble metal is in contact with a more noble metal.
  5. Probably a Combi if fitted with rear wiper.
  6. Why do you think that the bulb cannot be removed ?
  7. Welcome to the forum. Yes, I have seen other posts with similar clutch issue without loss of fluid. Very likely to be an internal fault with master or slave cylinder seals - best to try replacing the master first - especially if slave is the internal type.
  8. @whitevx did you fix the fault?
  9. Likely to be a failing master or slave cylinder.
  10. Provided it physically fits, fitting a larger capacity battery is not an issue as long as the vehicles BMS is adapted (coded) with the replacement batteries data.
  11. Flickering leds can also be caused by a faulty led driver - whether the driver unit can be replaced separately is another question, very likely to be integral with the led module.
  12. I believe that the pad/bung should be removed and replaced with Audi-type lift pads.
  13. ^^^ as above - but on or as near to a subframe mounting-point as possible.
  14. That was probably some type of ACC - not standard cruise.
  15. Very likely that the older vehicles had stronger engine braking than these later ones.
  16. Welcome to the forum. Doesn't look bad actually - I rather like the bi-plane and extra 'kick up' look. I wonder if it actually helps to keep the rear window a bit clearer in rain?
  17. Do you mind me asking what they paid you for it ?
  18. There is a strong possibility that your warranty provider may not be telling you the truth about there being 'No faults' (DTC codes) recorded - AFAIK, anything that causes the ECU to go into limp mode will flag a DTC - which they should be able read on the equipment they have available.
  19. Three questions - What warning indicators (if any) light up on instrument cluster when this fault happens ? Do you get any engine misfiring immediately before the fault happens ? Does the fault only appear when you accelerate hard ?
  20. 70-75% SOC could well be due to the Smart charging alternator algorithm allowing headspace for regenerative charging - I suspect that this algorithm can lead to irreversible plate sulphation if usual driving conditions never allow the battery to regularly achieve more than, say, 90% SOC.
  21. Going on data from your previous posts, I'd suspect your batteries charge acceptance capacity is down, possibly from hard sulfation of the plates. Does your charger have a 'recondition' function ?
  22. Yes, that's normal for standard cruise - there's not a lot of engine braking, so gravity will tend to take over on longer down-slopes.
  23. For context, has this battery ever been charged from external source?
  24. 10 year old Moll EFB, 59Ah, 320A DIN. 89% healthy at 82% SOC - 4.61 mOhms internal res.
