Warrior193
  1. Not being a CI driver, I'm not sure that there is any visual indication on the instrument panel while a DPF regen is being performed - the only references I've heard of are elevated idle speeds, cooling fans running at high speed at engine switch off and unusual burning smells from exhaust system.
  2. Are you seeing frequent DPF regenerations, and/or are regens often interrupted?
  3. Hello, welcome to the forum. If travelling in heavy rail and the windscreen is fogging sufficiently to mask the interior camera, perhaps the driving conditions are not really suitable to be using cruise.
  4. Which it should, if battery voltage is down to 12.2 as stated by OP.
  5. I'd suggest checking the alternator output by testing the battery terminal voltage while the engine is running (should be something over 14 volts) - if that's ok, have the battery fully charged and tested again.
  6. Was the battery BMS adaptation (coding) error corrected before or after the half-term holiday trip? Is the correct type of battery (EFB or AGM) fitted?
  7. That sort of load can give some indication but is not usually high enough to be conclusive - a high load test will be in the region of 50 to 100 Amps minimum - measuring the battery terminal voltage while the engine is being cranked can give a fair idea of condition, but is limited to a short duration test unless the engine is prevented from starting.
  8. At 12.2 volts, that 95% reading can only be battery Health - not SOC. Was the battery load tested under a high-rate load? Do you do a lot of relatively short runs? What is the battery terminal voltage with the engine running?
  9. Another thought - is this happening when hitting deep standing water on one side?
  10. It appears from OPs profile that this was originally a 1.8 L&K - and mentions in the post some 'Clutch' work with the conversion - but not what gearbox is currently fitted. If a manual box, I suspect a selector cable problem.
  11. OP hasn't said yet whether or not the complete powertrain unit was swapped.
  12. You haven't said whether your gearbox is Manual or DSG - What might be an issue is if the original gearbox (if retained AND DSG) is unable to handle the increased torque from the TT engine.
  13. Have you had the vehicle scanned for any logged DTCs? Presume trailer is unbraked, therefore less than 750kg - is that correct?
  14. Was it the complete engine and gearbox that was swapped? Unlikely that your gearbox issue has anything to do with the stated 'Nil Towing' capacity unless the engine (or gearbox) was overheating, which would also seen unlikely with such a small trailer. The 'Nil Towing' capacity will have simply been an Homologation requirement not fulfilled at the time of manufacture.
  15. There is probably an option in the BCM to allow twin rear fog lights, as I believe that this is a standard requirement in some countries. If present, enabling this would allow both lamps to operate without flagging an error. I've always thought fitting a single rear fog light rather poor - apart from cost, the only positive factor I can see is minimising unnecessary rearward glare when lights are misused - which misuse should be policed a lot more.
  16. Agree that rubber will not give an accurate reading, but there will be accessible metal parts that will give reasonably accurate ones.
  17. Your lighting error will be because the fog light circuit is now sensing a higher current than expected (because of the extra lamp wired-in) Was the change entered into the can bus?
  18. Moot point now, how many keys were supplied with the now-rejected vehicle?
  19. 'Love the smell of Napalm in the morning'
  20. Hello, welcome to the forum. You probably wouldn't see any significant difference in running costs between either fuel with your projected use, I'm rather biased towards the 1.4TSI because that's what I've had since 2015. Anything from around 2019 - 2021 will probably have had the cambelt replaced already, following incorrect advice from Skoda UK - that service item is significantly more expensive with the 1.5TSI. I've always thought it a little odd that the 1.5TSI engine should have exactly the same power output as the 1.4.
  21. ^^^ First line - 'Filled with petrol'
  22. Ah, is she absolutely certain that she filled up with petrol?
  23. Hello, welcome to the forum. Sorry that your wife has run into a problem. Engine starting, then stopping almost immediately can indicate immobiliser operation - but AFAIK would not prevent the starter from cranking the engine. That symptom might indicate a bad connection on the starter circuit. Hope they sort it quickly for her.
  24. Possibly not that one - I'd expect factory towbar prep to incorporate a multi-pin socket and a Can bus module, that loom is possibly tail light wiring or rear parking sensors.
