OBD Reader questions?
No matter, you should still be covered by Consumer Rights Act 2015 as it is now called. Take a look at what your rights are given the circumstances. You can also check with Citizens Advice. Suggest that you try an approach to the dealer principal first though.
I would think that'd be noted on your sales invoice or the warranty document.
Perhaps an approach to the Dealer Principal first to see what their attitude is, can you confirm that it was actually sold to you as 'approved used'? IIRC, a refund, minus an allowance for mileage travelled since purchase, is likely, excluding the legal aspects of the dealer selling an illegal vehicle.
Skoda Octavia mark 3 Sat nav update
Hello, welcome to the forum. Have you checked the lock switch on the side of the SD card? It's possible that it got switched during handling.
Bear in mind that the sale of goods act (or whatever it's now called) requires items to be of merchantable quality, AFAIR, it will still apply to your vehicle beyond the warranty period. Worth considering.
If the dealer was aware of this illegal modification to the vehicles exhaust, I'd consider that, at the very least, it would give you considerable leverage on addressing other faults. Do keep in mind that in the UK DPF removal will be a MOT hard failure point if it is detected.
coolant type
Get a couple of litres of de-ionised water from your local supermarket - normally used for steam irons, etc. Cheap as chips and a lot more reliable than the 'distilled' water your local Sh1tFix gets from the men's room tap!
Well, I can't say I'm completely surprised, but I'd imagine that could be very embarrassing to the Dealer concerned if it became public - which it is now of course! How and when was the delete discovered?
So, unless the DPF delete has been done in a manner that it is visually undetectable, that dealers MOT is probably worthless, I wonder what else the tester missed? Was this an 'approved used' vehicle?
1.4 TSI CZDA fuel rail leak
From the invoice, I believe that it had simply loosened, resulting in damage to the sealing ring. Seems that replacement of the damaged seal and correctly tighten the bolts was sufficient for fix.
Octavia Mk3 'Stop/Start error' Loss of accelerator response. Battery replacement time?
A reasonable test for a fully-charged battery is to test what the voltage minimum is while the engine is being cranked - a load is really needed to check actual battery health.
No issues since June last year. Apart from this single issue, I think the 1.4TSI is a brilliant engine - although I wouldn't say no if I was offered a straight swap for a 2.0TSI 245! 😄
Have you had any MOT issues with the DPF delete?
White smoke from a diesel can be concerning, I'm trying to recall why. Blue smoke = oil. Black = excess fuel. If I recall correctly, I think white smoke indicates coolant, perhaps someone can confirm. Is coolant being lost?
I do know that TDIs can be sensitive to slow cranking speeds, although I don't know why it would crank OK when dead cold, but not so much after a 6 to 8 hour stop. Is there an unusual amount of smoke after a slow start?
I don't have recent experience with diesels, but it may not be necessary to replace glow plugs if they test OK.
I wouldn't consider that to be a 'warm' start - engine will have cooled to ambient temperature after 6 to 8 hour stop.
I believe that at least one glow plug also incorporates a pressure sensor.
That may even be original battery, if so has done extremely well - is there a date code stamped on the neg. terminal?
Warm start is definitely going to be less stressful on battery than cold, so something else is possibly the cause of slower warm start.
Is your 2014 vehicle fitted with Stop/Start? OBD reader is probably unable to give a battery condition report. Given the way the battery management operates for recuperative charging, consider adding a suitable battery test instrument (and possibly charger) to tool box.
Hello, welcome to the forum. Did you actually have a fire caused by this failure? I filed a report to the DVSA detailing my fault and highlighting the NHTSA recall, they dismissed my report, saying that there was considered to be no fire risk!
What is typical usage of vehicle - is it mostly short trips? Do you know how old the battery is? There is often a date code stamped onto the top of negative terminal - format is WW;YY. Suggest getting a full battery test, there are very reasonably-priced test meters available that will give accurate condition readings - or get a trusted garage to do it, who may charge a significant portion of the cost of having your own device. Outlets providing 'free battery testing' may not always be competent or completely unbiased.
Hello, welcome to the forum. Best advice is to get the battery tested, don't forget that any replacement battery will require adaptation (coding) to the vehicles BCM. Also, get the DTCs (error codes) read from the OBD data port.
Hello, welcome to the forum. That alternator output, if constant, could possibly be an indicator that the battery is struggling to hold charge - depending on whether it drops back to float voltage after replacing usage, etc. shortly after start up. Around 14.7 volts is normal, max. charging voltage for AGM/EFB. One fact I've not often seen mentioned is that a charged secondary battery, in good health, acts like a smoothing capacitor, if battery health is compromised, more electrical interference (noise) from the alternator can be present in the vehicle circuits. Have you had the battery tested?
