Coolant issue
From the post, it reads as if it was the coolant that had the 700ml top up.
Coolant issue
Low annual distances travelled (or regular short trips) make regular oil servicing even more important - you should consider planning your servicing on an annual basis.
Coolant issue
Has the coolant level fallen since you topped up 700ml? Strongly advise you to monitor both oil and coolant levels more frequently - the oil usage is probably normal given the distance travelled, but the coolant really needs to be kept a very close eye on for some time until you can confirm there is no leakage. Why is there so long between oil services - do you plan one soon? It is a big mistake to simply rely on warning lights instead of doing regular engine checks.
Coolant issue
Are you seriously saying that the oil in your engine has not been checked for 26000 Km? Yes it is normal for an ICE engine to consume a small amount of lubricating oil - but, at that distance, I'd have thought the oil would have been due for a change in any case! For your ghost coolant level warning, did you visually check the coolant level yourself before taking it to the service centre? Was the level below the minimum level marked on the side of the expansion tank?
Scala Tyre Pressures
A different model, but still indirect TPMS - my Octavia does identify which wheel has triggered the warning - but the wheel ID message disappears very shortly after the warning chime - leaving just the general tyre pressure loss warning message.
how much £ to fill the tank 2 bars
Do tell, what did they do to p155 you off so much? Name and shame.
I'm not sure of the MkIV tank capacity, but I'd suggest putting in 10 litres, you could try leaving the ignition on so that you are able to read the gauge while filling. Annoying, but it will be much cheaper to err on the slightly generous side (to the rental co) - the penalty 'refuelling' charges will result in probably the most expensive fuel anywhere!
Octavia IV rear wiper delete
Completely agree - the Combi is even worse in rain - to the point of virtually zero rear vision directly behind without the wiper.
Sat nav giving incorect info
The battery may be recoverable - but it will have suffered some damage through the deep discharge. I'd suggest recharging with a suitable charger then a proper condition test before deciding on replacement - remember, any replacement battery will require adaptation ('coding') if your vehicle has smart charging system.
Which voltage means your battery is down to around 35% state of charge (yellow warning level) - even more importantly, your battery voltage will almost certainly be falling to critical level when the starter is operated. At a minimum, your battery requires a full recharge, then a proper test.
Cost of new 1.4 TSI water coolant pump fitted?
It looks like an intentional machining, but does not appear to run beneath the sealing ring - if so, would not affect the seal.
Engine oil - how long once opened?
If you consider that a vehicle could be on extended servicing - with the oil changes at up to two years, there is no reason to think that lubricating oil kept in a closed container and stored in reasonable conditions will deteriorate. The main reason for mandating regular oil changes is to remove the contaminants picked up during engine run cycles - it should be remembered that there was once a considerable market in re-refined lubricating oil - where used oil was recycled and resold. The original base lubricant was reported as being essentially unaffected by previous use. Unlike brake fluid, lubricating oil is not hygroscopic while stored after being opened. I used to purchase 2-stroke oil in bulk, and have stored it for at least three years with absolutely no detrimental effect.
- Smart alternator fault ?
Regular clonking noise from passenger side on coasting
I've seen prominent signs in some workshop mandating all wheel fixings being rechecked by leading hand mechanic before vehicle is released. Perhaps more should do this.
2020 Fabia keeps locking itself!
One thing to do is to verify that all the door detection switches are operating correctly, open each door in turn and check that the indicator on the instrument panel responds accordingly.
How long does it take you for the 5 M walk to car after pressing unlock button? Are you are aware that doors will relock if no door is opened approx. 35 secs after unlocking?
Purge Valve?
High idle for short period after start is normal - appears to be much more noticeable on the 1.0TSI than on my 1.4.
Locking wheel nut and bolt
As far as I'm aware, many main Stealers hold a full set of the wheel bolt security keys, a visit to ascertain the correct key, then buy one over the parts counter. No help when the key is missing - but there is a ID letter code stamped into top of VAG security keys. The Ebay option is probably your best (and cheapest) option, suppliers I've seen supply the correct key identified by you sending a clear image of your security wheel bolt face.
Superb Mk2 Estate boot doesn't open fully
Does your wagon have electrically opening hatch - or standard gas struts? If fitted with standard struts, hatch would need to be manually lifted to approx. 1/2 way before gas struts take over.
Excessive ABS, low speeds?
The real thing to ask though is why the brake pedal is being pressed so hard to bring about these ABS interventions? Unless driving too fast for the existing conditions, encountering unusually slick road conditions (diesel spill, ice, etc) or being suddenly presented with an unexpected hazard, it should not be necessary to press the brake pedal so hard that ABS is triggered.
Abs light,
If the tyre pressures are equally high - and remain within the detection tolerances of the TPMS from when they were last set, raised pressures will not trigger the alarm on a indirect system. Indirect TPMS detects changes relative to the other tyres.
I believe that what JR is saying is ABS will intervene any time the brakes are applied hard to reduce risk of control loss through wheel locking. No matter what speed, the vehicle could be travelling in slippery conditions, which could lead to loss of control through hard brake application without intervention. I've had full ABS mode operate a couple of times at around 10 to 15 MPH when front assist has detected a possible collision risk.
Purge Valve?
Unfortunately, no help from our 2018 110PS - for confirmation, assuming yours is a RHD vehicle - is this component in the vicinity of the offside engine mount?
Purge Valve?
Hello, welcome to the forum. I'll take a look at SWMBOs Fabia tomorrow - is this a 95 or 110PS, what year?
- Change key battery
