Everything posted by Bap33
@KeteCantek Thanks. I would love to do the same one day. I don’t know whether I´ve seen too many videos of crashes at the Nurburgring or if it’s real life. I would fear discovering a crashed car at the exit of a blind corner and being unable to avoid it… As you say, first victory is to exit the ring without damage on the car. 😉
What bulbs are fitted to the S3 & upgraded bulb recommendations
This topic is not old. It’s just dynamic a full of information. 😁 Take time to read, you´ll find the answer for sure… 😉
- How to change the oil on a DSG6 (DQ250) gearbox
Superb Mk4
@cnc Sorry about TSI204, I´ve read too fast… Regarding the TSI220 on MK3, it has never been sold in France. Indeed, it’s a market thing. Considering the TSI280, the french government has killed it on French market since 2018, because of CO2 emissions taxes. For such an engine, you have to pay an extra ~€15k for this single taxe. This would mean almost €80k for a Mk3 Estate in L&K or Sportline version with some options! Crazy! So simple, that TSI280 isn’t available anymore on Škoda french configurator. 🙄 Recently another taxe against weight has appeared for all cars over 1800kg. Fortunately, it only concerns ~2% of the market. Taxe, taxe, taxe, taxe, taxe… Owning and driving a car is becoming something luxuous…
List of common problems ?
Other common issues : - DCC front shock absorbers leaking (issue on several VAG models) - Coolant pump stuck, leading to engine overheat on TDI190 and probably on TDI150 too.
Superb Mk4
The TSI 204 will be a plug-in hybrid. Most probaby TSI150 (1.5l) + 54HP from electric motor. It doesn’t come from the 2.0 TSI190.
Superb Mk4
Even the ´big’ TDI engine has its max power reduced. No TDI200 anymore, ´only’ TDI193… not a big différence, but mentally a dowgrading. Exactly as when TSI280 was replaced by TSI272.
Superb Mk4
Do you mean: - There won’t be any new Passat Hatchback? Probably ´replaced’ by Arteon? - The next Passat Estate and Superb 4 Estate have the same chassis and wille therefore offer somehow the same inner space?
Superb Mk4
I hope it will look better. I´m not keen on this « edge design » for the moment. It gives me the impression of a jump back in the beginning of the 80s. Citroen BX or GSA… or Renault Super5… 😱 I cross my fingers (and toes if it helps) we have something better…
Powered tailgate Skoda Superb
Maybe she only made a mess with the max height setting and/or antipinch function. Did you try to reset the max height setting? The way to do it should be described in the user’s manual.
@KeteCantek Thanks ! It really looks efficient against dark brake dust. Great ! I also notice that you have Michelin PS5. How are they compared to PS4 (assuming you had PS4 before) ? I had PS2 on a former Audi A3 Mk2, they were brilliant. I replaced them by PS3, but they were worse than PS2, since they didn’t inherit the PS2 whole structure and rubber. Veru disapointed with PS3. Fortunately PS4 are better again. This is why I´m asking.
Canton sound system issues
Hi, Did you check all sound settings from your Colulbus MMI ?
Do you have a pic please? I have so much heard of these pads, I´d be curious to see what the result looks like for ‘real’. TIA.
Start Stop Issues after new battery
It could also come from the ´start engine´ which sometimes have contact issue. But it would be quite surprising that this second issue comes at the same time with your battery issue… 🤔
Moby is pas only the first part of its nick name. The second part has been blanked by the forum protection against nasty words 🙄. But it’s really the name of the white whale from the Herman Melville novel.
Superb Mk4
Surprisingly, the official storyboard video states a max power of 195kw (265HP) on Superb 4. I don’t know what it really means…🤔 - Is it the total power of the iV version whereas the current TSI280 has no equivalent yet on the Mk4 ? - There won’t be a « big » engine anymore? Too detrimental for the VW Passat or even VW Arteon or Audi A6? Future will tell.
Superb Wagon 4x4 2.0tsi 272 - Brisk Bambino Bakkie
Increasing braking performance can mean a lot indeed!
Maybe I´m too « old school » but I don’t feel comfortable with the idea of improving engine power and torque without increasing braking performance. If you do guys, that’s fine.
Superb Mk4
I was talking with the Sales Director from my local dealer few weeks ago, he said the Mk4 should be officially revealed by octobre or Novembre this year in France. I assume it should be the same date all other the world.
Will the spare from my Mk II fit on a Mk III?
Technically, both Mk2 and Mk3 use the same spare wheel size: 205/55/16, though standard diameter on Mk3 is a bit wider. Thus, it should fit (I just have a doubt if width and ET values are the same), but you’ll be limited to 50mph if you have to use it. You can then keep the rim of your spare wheel but replace its tyre to have the same diameter as your other wheels. @MartiniB has done it. He can tell you the right size for that. I think you can’t exceed 215mm for tyre width otherwise it will lift up the boot carpet.
@Fr13ndlyGhost I like the Superb3 TSI280 (even more a staged one) being a sleeper. 😉 May I suggest the next mod being bigger brakes to have a consistent car ?... 🤔 😉 Porsche has often communicated on 0-100 km/h time values but also on time required to make 100-0 km/h.😜
Otherwise, small satisfaction of last week-end: nice detailing of the cabin of Moby **** (that's the little nick name of my car, since it looks like the big whit whale 😁). Quite happy to see my Superb sooo clean! BTW, it gave me the opportunity to compare "Sprayabale Leather conditioner and cleaner" from Chemical guys (which I used on my wife's Q3 a week before) and "Gold Class" from Meguiars' which I used for my Superb. Finally, I think I prefer Meguiars' regarding the final aspect, since it almost doesn't modify the appearance. Leathers remain quite mat, as if they were coming straight from the assembly line. Considering now the nourishing and protection effects, errr... I would be very annoyed to try telling which is the more efficient. Some pics of the cleaning : After cleaning with only soapy water : A nice mat aspect, close to its appearance when coming out from assembly line the steering wheel is a bit too shiny though. I had a better result on my wife's Q3 a week ago... After applying Meguiars' Gold class: Moby **** still looks good though 97500km and almost 6 years on the clock.
The workshop manager finally called me back. He said the camber can't be tuned on my car...🤨 Since I don't like being fooled. I've taken a look to the official Skoda workshop manual. Chapter titled "Running gear, axles, steering", Paragraph "2.4 Nominal valus for axel alignment" on page 233 states: "It is possible to adjust camber by shifting the assembly carrier. Very important: Please note the following: Always replace the screws! After carrying out corrections of steering geometry, inspect position of steering wheel and alter to correct position, if necessary." For DCC equiped Mk3, camber range is -39' +/- 30' I called him back this morning. He said trying to tune the camber by shifting the assembly carrier is effectively a solution. But to him, it's quite risky when there's a small difference between FL and FR wheels (which is my case). Nevertheless he suggested I could swap FL and FR wheels since the FR tyre might be little bit more worn the the FL one dure to roundabouts. Sometimes it solve the problem when a car drags a bit on one side. I'll have a try... Additionally, it could help reducing the little groaning that starts appearing on front axle upon cornering at slow speed. I think sawtooth wear begins on the outer threads of my front tyres...
Hi, I let my Mk3 at my local dealer last week to have the geometry set after front shock absorbers replacement. I didn’t pay attention to the report when I got it back. But when I read it, I noticed that the camber is out of specified values. 😡 I went to my dealer this morning and showed the report to the workshop manager. He said the camber might be not tunable… WTF !?! As I was skeptical, he said he will check this morning and call me back (he is just back from holidays). Could this be true? TIA.
Fuse help
To have the correct model of fuses allocation, please tell us which engine / gearbox / version your Mk3 has. Indeed a pic of a TDI150 SEL with mechanical gearbox will not help you much if you have a TSI190 DSG7 L&K…
