Everything posted by rum4mo
Broke down in my 1.5 TSI - oil in spark plugs
@wiilydog , sad to say that I've just seen that YouTube video about that issue, ie after roughly 80,000miles expect it - horrible!
Oil Change
You could always check on the opieoils website to see which "weight" or options of "weight" of engine oil you could use to start with. I'd think that it will be a 0W-?? that will be suggested so that you can retain the emissions and fuel economy that the manufacturer quoted - but then maybe you'd rather go for slightly better protection and so aim for a 5W-30 oil. It might depend on what sort of annual mileage you typically do in this car, for years I've stuck with Mobil 1 ESP 5W-30 which is an oil that claims to a bit more tolerant to LSPI which many modern DI petrol engines can end up suffering from probably due to slight misuse - but there again my cars are not brand new, don't have variable oil pressure control and have not been marketed to be used with 0W-?? engine oils.
Scala rear brake piston
Changing the fluid every 2 years stops that happening.
Skoda octavia scout 4x4 engine light
That is high oil usage. Maybe check that the crankcase emissions "stuff" on top of the engine are working okay - is there a high vacuum when you remove the oil filler cap?
Sagittarius 19" alloy cover loose and fell or theft?
Just seeing as comment has been about Goodyear Allseason tyres ending up cracking, my daughter chose Goodyear Winter tyres for her 2019 SEAT Leon Cupra - and bought "one size down" alloys to use them with. That worked out very well for her, until, she was "too busy" to let me or her partner swop the wheels/tyres over after winter 2024-2025, so at MOT time in April/May 2026, with these Winter tyres being used in some hot weather in Summer 2025, she got advisories for both the original pair of Winter tyres which were now on the rear, luckily, the front pair had already been replaced as one ended up with a serious puncture, and these maybe 5 years newer same brand/version Winter tyres, did survive that use through Summer weather. While the classification of the advisories were for "cracking", I think that also included "damaged" - there was tearing visible on the sips areas on these tyres. Hopefully she has learned a lesson wrt using full winter tyres in hot summer time - though maybe Michelin and others will "accept" that use - I have left Pilot Alpins on my 2011 S4 over the past few summers, but I only use that car for longer journeys and if I know that I will plan to use it in hot summer weather, I'll definitely swop over to summer wheels/tyres before going out on a longer journey.
It really does make life easier if you remove the handbrake cable - just flick it out using a screwdriver, clean the lever and grease it and the ball end of the cable - I do this every 2 years when I service/clean the brakes. The handbrake cable can then be removed from its mounting on the calliper, so apply a bit of "squeezing" effort to its locking sleeve and push it back out of its mounting. Just my suggestions for the "next time".
Normally you can get a lot better access if you remove the handbrake cable and unclip a couple of brake pipe clips. I might e wrong, but I think that in the past, I've temporarily fixed the removed calliper back to the calliper carrier by using the bottom calliper bolt hole fitted into the top calliper carrier guide pin - to help with keeping an troublesome calliper in control while fighting with the piston retracting - I think that I've even resorted to slightly moving the handbrake lever when a piston could not be rotated easily - at first.
Opinions for new shocks+springs
@JohnMack , wrt the Lesjofors springs that you fitted to your Dad's Focus, I think that was probably due to the lack of paint or surface protection being applied to these springs by Lesjofors, I think that Lesjofors product should be good quality as they are in the "steel for springs" business, but I've sadly discovered that after just one year - or just one Scottish winter, all 4 Lesjofor springs are showing signs of surface rust - so my cunning plan of replacing the original VW Group springs on my wife's 2015 Polo after 10 years - to avoid suffering a snapped spring, will possibly have backfired on me! I've just had too many snapped springs at inconvenient times in the past, so for once I've tried to avoid this on this 2015 Polo. And I'll repeat what Carlston said about many aftermarket brands offering a "short" range to cover a "large" range of VW Group part numbers, both for springs and dampers - my wife's 2015 Polo now sits almost "flat" instead of being raised at the rear, which is okay as it looks better and normally only 2 of us are in that car - Lesjofors did list a matching front spring for that car but excluded "5 door" and the actual correct part number for the rear springs - so I took a chance!
OEM Parts
I'd just buy a genuine VW Group oil filter while the car is still within warranty, doing that must save/avoid a lot of messing about if anything associated with the engine does need warranty work. Okay the factory fitted filters tend to be Mahle with VW Group re-branding, and the service parts tend to be Mann with VW Group re-branding - but typically there is not much savings to be made between genuine VW Group and Mann if you buy with care.
Fabia 2 windows stop after 10 minutes.
Maybe I'm picking you up wrong, but, after switching the ignition off and staying in the car, the controllers will go to sleep after a certain time, and 10 minutes sounds about right, so after that, the electric windows will not work - unless you flick the ignition ON/OFF again. Also, if you, for instance, have a passenger in the car and after you switch the ignition off, as soon as they open a door then close it - the electric windows will not work unless you - as in the previous paragraph, flick the ignition ON/OFF.
Jack Point
That’s annoying, I tried to remove them from my wife’s 2002 Polo - on the day we went to collect her new 2015 Polo, but unfortunately I had not left enough time to get the hard plastic peg bits out! So I had to buy a new set for that car, hopefully I’ll plan ahead a bit better when that 2015 Polo runs out of useful life!
Jack Point
From VW Group, ie Audi TT Mk1, these jacking point protectors came as 2 parts, first you'd remove the cover that was fitted to cover these 4 holes in the body, then press in the rubber part 8N0 804 583, once it was fully located in the body, you'd fit the hard plastic locking peg part number 8N0 803 855 normally by jacking up under it with a suitably sized socket on the trolley jack saddle - and continue jacking until it "pop'd" fully into its location. After that has been done, the rubber protector is locked in position and the hard plastic flat top'd peg it there for you to safely jack up under. If I was you, I'd be removing these rubber protectors until you can get hold of the hard plastic peg parts - and just jack up under the body at these points using a suitable material to cushion between the trolley jack saddle and the metal of the car body. Now for the bad news, I've just checked an online VW Group parts listing and while the rubber parts are still available, the hard plastic peg part was dropped by VW Group in 01/04/2023 with no replacement provided. Maybe the Powerflex etc kits still have their own version of these hard plastic pegs, and maybe this explains why your car has the rubber parts fitted but no hard plastic pegs!
Jack Point
Was this car bought used, if so I'd reckon that the previous owner fitted these Audi TT Mk1 jacking point protectors, and either did not bother to also fit the hard plastic locking element to them - or, attempted to remove them before the sale but failed to get the rubber part out of the body. I'd be a bit wary about using these rubber pads until you have bought the plastic locking element that fits inside them. If you need the part number for the hard plastic locking element I can find it and hand it over - there should be 4 of these pads - do none of them have a hard plastic locking element fitted into them?
- 5 error at a time
FIXED: Electronic Gremlins - are we just unlucky?
I myself would have thought that a Yuasa brand of battery is a safe bet, but it seems, from more informed professional sources that that is not true - some trade people only trust Varta. Bosch and Varta seem to share manufacturing facilities - but that does not necessarily mean they are the "same" battery with just different colours used on the cases. Varta for VW Group tend to get JCB to manufacture their batteries - so who know! I've had success from Bosch - both AGMs, one a direct AGM to AGM replacement only due to age (10 years) and one an EFB to AGM replacement again only due to age (10 years) - in both cases updating the car's battery/charging system controller using VCDS.
Correct Spark Plugs?
Your correct, thanks there is no "L" in the 94224 version. The "04E" and "05E" were taken from the VW Group parts listing. Edit:- both the VW Group part numbers that I quoted were listed against a quantity of "3" I avoided listing any that were listed against a quantity of "4" so that should have removed any 1.4TSI or 1.5TSI ones.
Okay, VW Group p/n 04E 905 602 D is the same as NGK ILKER7A8EGS stock number 94224 and it has a 19mm reach according to the NGK UK spare parts web cat - and that is what they claim suits Skoda Karoq 1.0TSI 2022 MY, the Skoda VW Group parts listing also offers 05E 905 602 B which is the same as NGK ILKER7B8EGS stock number 91512 and it is listed as having a 26.6mm reach but only used with PR:DS8 - whatever that version is! Edit:- typically the change from "A" to "B" is just a heat/temperature change, why this, in this case seems to coincide with a "reach" change is strange - I'm just using the "A" and the "B" versions of the plugs my wife's car uses to make that observation, nothing more. Heat change does normally affect the exposure or shrouding of the centre electrode though.
I think that that only works if you can link the VW Group part number with the NGK stock number, at one time, the VW Group branded NGK also had the NGK number on them, but not now I seem to remember.
opie oils is only okay if your are getting best price AND over the "free delivery" limit.
I agree wrt NGK, try their website for model etc and use that info.
Cleaning the air conditioner with cleaning foam
Just general comments really, I fussed about this when I had my 2000 VW Passat 4Motion and at that time, maybe round about 2005, the "AC bombs" seemed to have a long tube and that needed feeding into the air plenum box - but I didn't actually complete that task! By the time that I got round to re-visiting that task with later cars, all the "AC bombs" had done away with the long tube, and the plan was now to just start up the car with all windows closed, turn on the AC on recirc, place the bomb on the floor in the rear of the car, and set it off, close doors and leave the car for a certain length of time, then open the door, switch off the engine and remove the now empty bomb container - job complete. I've used that method but removed the pollen filer first then closed the pollen filter cover, and fitted a new Frecious pollen filter after running that AC bomb. Edit:- sorry that I didn't answer your question exactly, but in all these cars the AC evaporator is inside the cabin heater box, along with and beside, the heater matrix. So, that is a closed mainly plastic box and getting into that area in a way that allows full access to the evaporator - will be a very big job, so all you can try is to use one or two of these "AC bombs" and that should kill the bugs and most of the smell.
- Rapid 1.2 TSI Broken valve / hose
Coil pack removal
Mind you, it would have been more helpful if I had written “yank the coils up” and not “yank the plugs out”!
Coil pack removal
I’d reckon that none of these listing bothered to be updated when 1.0TSI became popular. I spent good money on a Laser Tools version, and that style is the most expensive even today - it is the version that is just an aluminium alloy grab bar with finger shaped cut outs and an expanding shaft! I’d just stick with what is cheapest and looks better than that one!
