Carlston
Everything posted by Carlston
  1. What size discs have you got? The Kodiaq has three different sizes of front brake discs: 312x25mm, 314x30mm, 340x30mm. The front brake systems on the Kodiaq are all TRW brake systems. Jurid on autodoc suggests that the Kodiaq 2.0TDI 150HP 4x4 has 314x30mm front brake discs. You can check by measuring the outside diameter of the front brake discs, or if you have build code 1LW that would show that you have 314x30mm front brake discs. TRW GDB2114 front brake pads (for Kodiaq 314x30mm front brake discs) £45.14 https://www.amazon.co.uk/TRW-GDB2114Â-Brake-Pad-disc-brake/dp/B06XYN4994/ref=sr_1_1?crid=YKZWU3H5E8H1&keywords=trw+gdb2114&qid=1664803916&qu=eyJxc2MiOiIwLjA4IiwicXNhIjoiMC4wMCIsInFzcCI6IjAuMDAifQ%3D%3D&sprefix=trw+gdb2114%2Caps%2C74&sr=8-1 ATE brake discs are coated, whereas TRW brake discs are painted. Coated brake discs should give better protection from rust. ATE 24.0130-0220.1 314x30mm front brake discs https://www.autodoc.co.uk/ate/7005983 Kodiaq parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/KOD/804/6/615/615010
  2. What brand was the spring that broke after just three years?
  3. What is your current tyre size and rim size? If you're on 165/70R14 fitted to 5Jx14 ET35 rims, there are some non-standard tyre options for those rims. 175/65R14, 185/60R14, 185/65R14, etc. Perhaps 175/65R14 would be the pick of the bunch because it's a common and cheap tyre size and will be a good fit for the 5J rims. The Skoda Citigo also uses 165/70R14 and 175/65R14 on it's 5J rims. Vredestein Quatrac 5 175/65R14 82T https://www.camskill.co.uk/m137b0s7975p134030/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_175_65_R14_82T_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_69dB The 175/65R14 tyre size will give you a much better ride than many of the 15" tyre sizes such as 195/50R15. If you like 195's, then 195/60R14 fitted to a 6Jx14 ET43 rim will give you a much better ride than 195/50R15. However, 195/60R14 is not a common tyre size and considerably more expensive than the common and plentiful 175/65R14 tyre size. Vredestein Quatrac 5 195/60R14 86H https://www.camskill.co.uk/m137b0s7982p144833/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_195_60_R14_86H_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_C_NoiseClass%3A_A_Noise%3A_69dB
  4. ROTARE 7Jx17 ET46 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-rotare-17-pro-octavia-iv/p/5E3071497C+8Z8 225/50R17 would work really well on the 7Jx18 ET46 rim. 225/50R17 is a cheaper and more common tyre size than the 225/45R18 tyre size. 225/50R17 fitted to a 7J rim will be noticeably more comfortable than 225/45R18 fitted to a 7.5J rim. The below tyre would work well in the summer, ie. it's not a winter or all-season tyre as it doesn't have the 3PMSF symbol, so has limited traction in the snow. For best comfort it's important to avoid UHP summer tyres or other tyres that could have stiff sidewalls, and not to over-specify the tyre's load index or speed index. Using a 98 load index instead of a 94 load index will make the tyre's sidewalls stiffer and therefore the ride harder. Using V, W, Y speed indexes if you only need H will again make the sidewalls stiffer and therefore the ride harder. Notice that the below Michelin has a remarkably low noise rating, only 68dB. Using 225 tyres instead of 205 tyres can sometimes increase the noise levels, but the below tyre was carefully chosen by Audi as standard fitment to one of its cars. If you are going to use the tyres all year round and need good winter performance in snow and cold rain, it would be better to look at all-season tyres, as they work much better than summer tyres when the temperature drops below about 7 degrees Centigrade. Michelin Primacy 3 225/50R17 94H (Euro label B A 68dB) AO (Audi Original Equipment) https://www.camskill.co.uk/m54b0s7818p139463/Michelin_Tyres_Car_Michelin_Primacy_3_-_225_50_R17_94H_(AO)_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_A_NoiseClass%3A_A_Noise%3A_68dB https://www.blackcircles.com/catalogue/michelin/primacy-3/225/50/R17/H/94/m?tyre=35021323 Michelin winter tyres will often last considerably longer than most other brands of winter tyres, ie. more miles before they wear out. Michelin Alpin 6 225/50R17 94H (Euro label D B 69dB) Winter tyres https://www.camskill.co.uk/m97b0s1472p158249/Michelin_Tyres_Winter_Snow_Car_Michelin_Alpin6_Michelin_Alpin_6_-_225_50_R17_94H_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_B_NoiseClass%3A_A_Noise%3A_69dB For the 225/50R17 tyre size, 7Jx17 ET45 alloy rims from the Octavia MK3 and Yeti could be used instead of the 7Jx17 ET46 rims from the Octavia MK4. The specification of these rims are almost identical with just a 1mm different in ET number, ie. ET45 instead of ET46. This is so close, that when fitted you wouldn't notice the difference. NIVALIS 7Jx17 ET45 alloy rim (from the Octavia MK3 Scout) https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-nivalis-17-pro-octavia-iii/p/5E0071497F+HA7
  5. 205/60R16 are slightly undersize on the Superb MK3. One of the owner's manuals only mentioned 215/60R16 and 215/55R17 tyre sizes for use with snow chains. 215/55R17 tyres have an outside diameter 2.4% bigger than 205/60R16. wheel-size.com do often make mistakes, so do check your owner's manual.
  6. The outside diameter of 205/55R16 is too small for the Superb MK3. Have you considered using all-season tyres all year round, such as Michelin CrossClimate 2 ?
  7. The Octavia MK2 uses 205/55R16 tyres fitted to 6.5Jx16 ET50 rims. The Octavia MK3 uses 205/55R16 tyres fitted to 6.5Jx16 ET46 rims. The Superb MK3 uses 215/60R16 tyres fitted to 6.5Jx16 ET41 rims. Outside diameter 205/55R16 631.9mm 215/60R16 664.4mm Therefore, 215/60R16 has an outside diameter 5.1% bigger than 205/55R16. So if you use 205/55R16 instead of 215/60R16, the outside diameter of the tyres will be too small.
  8. ETRTO approved rim widths 235/35 8.0-8.5-9.5 245/35 8.0-8.5-9.5 The 8.5" rim width is ideal for both the 235/35R20 and 245/35R20 tyre sizes, as shown in the chart above. 245/35R20 is a more common and cheaper tyre size than 235/35R20. Uniroyal RainSport 5 245/35R20 95Y XL (about 190 Australian Dollars each) https://www.camskill.co.uk/m63b0s339p188353/Uniroyal_Tyres_Car_Uniroyal_RainSport_5_-_245_35_R20_95Y_XL_FR_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_72dB
  9. 235/30R20 isn't the usual tyre size on an Octavia MK4. The outside diameter is too small, and so is the load index. Outside diameter 225/45R18 659.7mm 225/40R19 662.6mm 235/30R20 649mm The XL load index of a 235/30R20 tyre size is 88 (560kg) which is lower than all of the Skoda approved tyre sizes.
  10. The front tyres on FWD cars wear much quicker than the rears. One option is to keep the new tyres on the front until they wear out. It's often claimed that it's best to fit two new tyres on the rear and move the part worn rear tyres to the front. However, if you have 5mm of tread on the rear it's not necessary because the front tyre wear will quickly catch up with the wear on the current rears. Next time when it comes to tyre replacement you will then be able to look for four matching new tyres.
  11. camskill are based in the UK. However, I was using that website to give examples. There are plenty of other tyre sellers in the UK and it's always worth shopping around for the best price and service.
  12. Standard tyre sizes on the Octavia MK4: Michelin CrossClimate 2 205/60R16 96V XL (Euro label B B 69dB) £114.40 https://www.camskill.co.uk/m139b0s8005p208537/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_205_60_R16_96V_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_A_Noise%3A_69dB Michelin CrossClimate 2 205/55R17 95V XL (Euro label B B 69dB) £123.00 https://www.camskill.co.uk/m140b0s8838p208583/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_205_55_R17_95V_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_A_Noise%3A_69dB Michelin CrossClimate 2 225/45R18 95Y XL (Euro label C B 71dB) £157.45 https://www.camskill.co.uk/m141b0s8784p208577/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_45_R18_95Y_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Michelin CrossClimate 2 225/40R19 93Y XL (Euro label C B 71dB) £167.60 https://www.camskill.co.uk/m142b0s11852p208584/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_40_R19_93Y_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB I suggest you look at the 16" and 17" options rather than the 18" and 19" options. The 16" and 17" options are far more comfortable, make less noise, more mpg, and are cheaper. If you've got 340mm diameter front discs, then 17" rims will be the minimum size. If you like to fit non-standard tyre sizes, then there are lots of options such as: Michelin CrossClimate 2 225/55R16 99V XL (Euro label B B 71dB) £138.70 https://www.camskill.co.uk/m139b0s8009p208559/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_55_R16_99W_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Michelin CrossClimate 2 225/50R17 98V XL (Euro label B B 71dB) £130.80 https://www.camskill.co.uk/m140b0s8019p208529/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_225_50_R17_98V_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Octavia MK4 alloy rims https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIV%2B%282019%2B%29&page=0
  13. The VW Polo MK5 came out years before the Fabia MK3. The VW Polo MK5 used the same 185/60R15 tyre size fitted to the same 6Jx15 ET38 rims that the later Fabia MK3 used, so maybe VAG dealers started selling the VW Polo MK5 spare wheel as a spare wheel for the Fabia MK2. 185/60R15 (fitted to 6Jx15 ET38 rims) was likely a cheaper spare wheel option than 195/55R15 (fitted to 6Jx15 ET43 rims). If a Fabia MK2 owner was using non-standard and oversize (bigger outside diameter) 215/40R17 tyres, then 185/60R15 would have been a good match to the outside diameter of the 215/40R17 tyres (closer than 195/55R15).
  14. That is why in most other countries, 17" wheels are very popular on the Octavia MK3 VRS instead of 18" wheels. The extra sidewall height makes the rims far more resistant to pothole damage. I suggest you sell your remaining good wheels one at a time (ie. singley), as this is a very common problem...so plenty of buyers out there looking to replace their pothole damaged wheels. https://en.wikipedia.org/wiki/Škoda_Octavia#/media/File:20200509_Skoda_Octavia_vRS_Estate.jpg 17" rims for the Octavia MK3 https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29 https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/601/601070 https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/0/071/71070
  15. Could the choice of non-standard 185/60R15 over standard 195/55R15 on the Fabia MK2 have anything to do with price? ie. lower price on 185/60R15 compared to 195/55R15. Although the 185/60R15 would give a better ride, and slightly better mpg due to slightly less drag being a narrower tyre. Michelin CrossClimate 2 185/60R15 88V XL £85.50 https://www.camskill.co.uk/m138b0s7989p208561/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_185_60_R15_88V_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_69dB Michelin CrossClimate 2 195/55R15 89V XL £105.95 https://www.camskill.co.uk/m138b0s7992p208530/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_-_195_55_R15_89V_XL_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_B_NoiseClass%3A_A_Noise%3A_69dB
  16. It's possible people were using 185/60R15 size tyres as spares before the Fabia MK3 came out, but it wouldn't have been fitted to the same style of 6Jx15 ET38 steel rim that the Fabia MK3 uses, because that wasn't available until the Fabia MK3 came out. One of the benefits of the 185/60R15 tyre size was the lower price compared to the 195/55R15 tyre size. Fabia MK3 6Jx15 ET38 steel rim (notice the 6 square holes for the wheel trims) https://www.oponeo.pl/felga-stalowa/alcar-kfz-7760#22916128 Octavia MK1 6Jx15 ET38 steel rim https://www.oponeo.pl/felga-stalowa/alcar-kfz-8380#22776394
  17. The 185/60R15 (which was fitted to a 6Jx15 ET38 rim) didn't come out until the Fabia MK3, so couldn't have been OEM on the Fabia MK2.
  18. 185/60R15 isn't an OEM size on the Fabia MK2, although I expect it would fit in the spare wheel well because the outside diameter is only 7.5mm more than the 195/55R15 tyre size.
  19. Octavia MK3 rear brake calipers for 272x10mm rear brake discs (TRW brake calipers) 1 5Q0615423B Brake caliper housing left 1 PR-1KS 1 5Q0615424B Brake caliper housing right 1 PR-1KS 1 5Q0615423C Brake caliper housing for version: left red 1 PR-1KT 1 5Q0615424C Brake caliper housing for version: right red 1 PR-1KT https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/615/615062 autodoc are listing remanufactured rear brake calipers matching 5Q0615423C. Price is about £99.18 on their 30% discount day (ie. Mondays). You can tell they match 5Q0615423C because that is the only OEM part number mentioned on the listing, and the colour is specifically stated to be red, and the below photo is shown on the listing. The right side 5Q0615424C isn't currently available on autodoc. https://www.autodoc.co.uk/trw/7488940 TRW right rear brakes calipers matching 5Q0615424C is not currently in stock on autodoc. https://www.autodoc.co.uk/trw/7488941 However, they do have the plain coloured ones matching 5Q0615424B https://www.autodoc.co.uk/trw/7488939
  20. What specification are the 15" alloy rims that are fitted? If you find out, you might be able to get a matching 15" steel rim, ie. same width and offset. The 15" rims that the Fabia MK2 normally uses have a specification of 6Jx15 ET43 which you can see in the chart below. As you will see, there are three different steel rim sizes that the Fabia MK2 uses, 5Jx14 ET35, 6Jx14 ET37, 6Jx15 ET43. The 5Jx14 would normally use the 165/70R14 tyre size, the 6Jx14 would normally use the 185/60R14 tyre size, and the 6Jx15 would normally use the 195/55R15 tyre size. The outside diameter of a 185/65R15 tyre is a massive 7.6% bigger than 185/60R14, although a more reasonable 4.4% bigger than 195/55R15. As long as the 185/65R15 doesn't rub (including on full steering lock) and you are happy that the gearing, especially 1st gear and top gear isn't too high. However, 185/65R14 would have been a better choice than 185/65R15 as it keeps the gearing standard, and can be fitted to either of the two standard 14" rims. 1 6Q0601027R Steel rim 5Jx14 ET35 6Q0601027R 03C rally black 1 6Q0601027AC Steel rim 5Jx14 ET35 6Q0601027AC 03C rally black 1 6Q7601027B Steel rim 6Jx14" ET37 6Q7601027B 03C rally black 1 6Q7601027C Steel rim 6Jx14 ET37 6Q7601027C 03C rally black 1 6Q0601027M Steel rim 6Jx15 ET43 6Q0601027M 03C rally black https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/697/6/601/601010 Note that 6Qxxxxxxxx is the same OEM part number as 6Qxxxxxxxx 03C. The 03C is simply the associated colour code, and the OEM part number can be quoted with or without this final 3-digit colour code. Most people don't bother adding the 3-digit colour code to the OEM part number, because adding the 3-digit colour code makes the already long OEM part number even longer. There are at least 20 different specifications of VAG steel rims that would fit the Fabia MK2, ie. PCD 5/100, Centre bore 57.1, including: 5Jx14 ET35 6Jx14 ET37 5Jx14 ET38 6Jx14 ET38 6Jx14 ET43 5Jx15 ET28 6Jx15 ET29 5.5Jx15 ET34 6.5Jx15 ET34 6Jx15 ET35 6Jx15 ET38 5.5Jx15 ET40 6Jx15 ET43 6Jx16 ET31 6Jx16 ET35 3.5Jx16 ET38 (space saver rim) 6Jx16 ET40 6.5Jx16 ET42 6Jx16 ET45 3.5Jx18 ET38 (space saver rim)
  21. It's best to find what build codes your shock absorbers have. Do your front shock absorbers have 50mm or 55mm struts. If they are 55mm (shown as 54.6mm below) then they are probably in the list below. 8 5Q0413031EQ Gas shock absorber 54,6MM 2 PR-G02 8 5Q0413031FP Gas shock absorber 54,6MM 2 PR-G03,2UC https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411001 25.05.2015>> 8 5Q0413031ER Gas shock absorber 54,6MM 2PR-G02,7IM,7ZV https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411005 25.05.2015>> 8 5Q0413031EP Gas shock absorber 54,6MM 2 PR-G04 8 5Q0413031EQ Gas shock absorber 54,6MM 2 PR-G05 8 5Q0413031ER Gas shock absorber 54,6MM 2 PR-G06 8 5Q0413031FP Gas shock absorber 54,6MM 2 PR-G07,G08 8 5Q0413031FS Gas shock absorber 54,6MM 2 PR-G10 https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/411/411006 KYB 3358015 front shock absorbers are sold to replace all of the above OEM part numbers. KYB 3358015 front shock absorbers OEN 5Q0413031EP — SKODA OEN 5Q0413031EQ — SKODA OEN 5Q0413031ER — SKODA OEN 5Q0413031FP — SKODA OEN 5Q0413031FS — SKODA https://www.autodoc.co.uk/kyb/14359022 Sachs 315 911 and Sachs 317 330 front shock absorbers are also sold to replace all of the above OEM part numbers. https://www.autodoc.co.uk/car-parts/shock-absorber-10221/skoda/octavia/octavia-combi-5e5/59680-2-0-tsi-rs?supplier[0]=32&criteria[100][1]=VA
  22. Having lower gearing for the 60PS version than the 75PS would make no sense as they both have the same low down torque and so the lower powered version can just as easily pull the same gears as the 75PS version. Having different gearboxes and/or final drive would add unnecessary expense to produce the cars. Lower gearing would mean higher fuel consumption, and the 60PS version is actually slightly more economical than the 75PS version, ie. 4.5L/100km instead of 4.7L/100km. As you can see in the below chart, both versions produce 95Nm of torque between 3,000rpm and 4,300rpm. 1.0 Litre non-turbo petrol engine 60PS/75PS 95Nm@3,000rpm–4,300rpm https://en.wikipedia.org/wiki/Volkswagen_Up#Engines It would have been nice if the Citigo had been produced in a 0.65Litre (650cc) two cylinder turbo petrol version with 75PS/130Nm. That could have made an average fuel consumption of 4L/100km (70mpg) possible instead of 4.4L/100km (64mpg) for the 1.0Litre (1,000cc) three cylinder turbo petrol. As a turbo petrol engine can have maximum torque coming in much lower in the rev range (perhaps from 1,500rpm to 3,000rpm) than a non-turbo petrol engine, a 650cc two cylinder turbo engine would be much nicer to drive than a 1,000cc three cylinder non-turbo petrol engine.
  23. 3.5Jx18 ET25.5 steel rim 1K0601027AP 1 1K0601027AP Steel rim for space-saving emergency wheel 3,5JX18H2 ET25.5 1K0601027AP03C rally black https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/601/601012 3.5Jx18 ET25.5 steel rim 5Q0601027BC 1 5Q0601027BC Steel rim for space-saving emergency wheel 3,5JX18H2 ET25.5 5Q0601027BC03C rally black https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/585/6/601/601012
  24. Octavia MK3 VRS with 17" wheels (225/45R17 fitted to 7.5Jx17 ET51 alloy rims) https://en.wikipedia.org/wiki/Škoda_Octavia#/media/File:20200509_Skoda_Octavia_vRS_Estate.jpg DORADO 17" light alloy wheel for OCTAVIA MK3 7.5Jx17 ET51 https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-dorado-17-pro-octavia-iii/p/5E0071497C+8Z8
  25. As you can see below, 17" wheels can be fitted to the Octavia MK3 VRS. The Octavia MK3 facelift diesel VRS has smaller front 312mm discs, so 16" wheels will fit those cars. 205/50R17 tyres fitted to either 6Jx17 ET45 or 6Jx17 ET48 rims are approved for snow chains. 225 tyres are too wide for snow chains on the Octavia MK3. You could use a 205/50R17 tyre fitted to a 6.5Jx17 ET38 5/112 57.1 steel rim from the Kodiaq. That will clear the front brake calipers on the 340mm diameter front brake discs. 6.5Jx16 ET38 5/112 57.1 steel rim https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=672860434273997936%3A%3A0001 Skoda Octavia 2017 2.0TSI 245PS VRS – Generation: Mk3 A7 (5E) Facelift [2017 .. 2022] – Market: EUDM – Power: 241 hp | 180 kW | 245 PS – Engine: 2.0L, DHGA, I4, Petrol – Options: RS – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 120 Nm – Thread Size: M14 x 1.5 – Trim Production: [2017 .. 2020] Tire Rim 225/40ZR18 92Y 7.5Jx18 ET51 2.2 / 2.3 205/50R17 93H 6Jx17 ET48 2.2 205/50R17 93H 6Jx17 ET45 2.2 225/45ZR17 91Y 7Jx17 ET49 2.2 225/35ZR19 88Y 7.5Jx19 ET51 2.4 https://www.wheel-size.com/size/skoda/octavia/2017/#trim-20tsi-eudm-241 Skoda OEM 6Jx17 5/112 57.1 alloy rims 5E0071496A Aluminium rim 6Jx17 ET48 CRYSTAL 5E0071496A 8Z8 Diamond silver 5E0071497E Aluminium rim 6Jx17 ET48 CRYSTAL 5E0071497E FL8 Black metallic 5E0071497B Aluminium rim 6Jx17 ET45 FLASH 5E0071497B 7ZS chrome coloured metallic https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/805/0/071/71070
