Everything posted by Gammyleg
7 Speed DSG - how is the manual shift feature supposed to work?
I've never experienced the upshift but that's probably because I don't thrash it hard enough. As stated by others, It will downshift as & when it decides its necessary.
- If an auto car breaks down
Engine coolant question
The G12 Evo should also allow you to dispense with the silica 'tea bag' in the expansion bottle ( if it has one that is. )
Yes, my Michelin Cross Climates made a massive difference compared to the previous Dunlop SportMaxxs. I'm always interested in 'simple' add-ons to reduce the cabin noise further.
Has the sound deadening had much effect?
Car failed MOT brakes - question
Mine is offside front. Managed to mangle the connector when taking out the old pads though. It seemed to have become a little brittle over time.
ABS/wheel speed sensor and faults
Were the fault codes read and cleared after you fitted the sensor?
Advice on tyres
+1 from me. I've found them so much quieter than the Dunlops too.
DSG Oil Change?
Ignore the official advice and get the oils changed, both transmission and mechatronic @ 40k. Having seen the state of the oil from my DQ200 it is certainly worth doing. £215 is not a bad price but a good indy would likely do it a bit cheaper.
Multiple DTC on driver assistance systems.
Maybe this....? https://www.independent.co.uk/news/science/subatomic-particles-cosmic-rays-computers-change-elections-planes-autopilot-a7584616.html
- R16 tyre pressures when loaded/towing.
Driving modes
If you can't feel the difference between the settings then it's likely not working.
Gearbox fault on startup and Cruising speeds
All searches that I've done point toward the Mech being at fault, however as yours is a 2013 and a DQ200, has it ever had a Mech oil change? It won't have been done during a standard Skoda service as it's listed not required, sealed for life ( or words to that effect ). IMO it needs to get done in line with service schedules listed for other VAG DQ transmissions. Mine came out as a brown goo rather than a green liquid and frustratingly the filter is internal to the mechatronic so it would require disassembly in order to change/clean it. The drain & refill procedure is not particularly difficult and there are a few youtube videos showing how it can be done. Just be sure that it's the DQ200 version you watch. This may not be the 'fix' but it will do no harm and is a cheap to do. The fluid is only about £20 and about 1 - 2 hrs labour.
- Gearbox fault on startup and Cruising speeds
VRS Estate MPG/Fuel Economy
Did you get the dpf checked out by your man? Your previous thread mentioned high idle after runs and I think the fans staying on which are early signs of regeneration issues.
- Air Quality Sensor Faulty
The cost of ownership.
Ha ha yes indeed, however most cars will depreciate over time so I missed that off. The way things were with the 2nd hand car market 4 years ago, I could have sold it for more a year later with 25k extra miles. I've no clue what it's worth now though. Out of interest I plugged the details into webuyanycar and they refused to price it and pointed me toward Motorway who valued it at about £3500 iirc.
Two timing belt and water pump changes plus replacement clutch pack and flywheel was where the most of the labour was. Have bought 12 tyres, ( 8 Dunlop SportMaxx & most recently 4 Michelin Cross climate 2's) . I've changed the brakes & discs all round and the rear shocks, so saved a couple quid on labour there.
A quiet Friday at work so did a few calcs based on my 4 year ownership ( almost to the day ) of my 2016 1.6Tdi Estate. Days Owned 1460 Maintenance, Service, Spares, Repairs £7220.48 Insurance £1568.73 Road Fund Licence £80.00 Total ( excl fuel ) £8869.21 Distance Driven ( Miles / km ) 100,608 / 160,973 Av. Miles / km per day 68.9 / 110.26 Fuel used ( gallons / ltr ) 1725.33 / 7843.52 Av. mpg / km/ltr 58.3 / 20.52 Cost per day ( excl fuel ) £6.07 Maintenance includes fitting of a new clutch pack & flywheel + transmission service. The rest being usual tyres, wipers, servicing etc all of which was carried out by an indy. Dull I know, but something to do whilst waiting for a courier to turn up, albeit a day later than arranged.
Skoda clutch advice
Where does the clutch bite, near the top?
Normal startup noise 2016 EA888 2.0 Video included
That sounds like a Tdi but I'm guessing it isn't.
Help needed with oil leak
A myriad of possibles, particularly as not much info known about the car's history, servicing, mileage etc which may be relevant. If the leak-check is the green dye shown in the picture, was that spilled as well, or is it what has accumulated after running the engine? First off, I'd run the engine with the filler cap removed to see if you've got pulsating pressure puffing out, this may indicate worn rings or badly seated valves.
Octavia Scout 2016 MKIII - Disable foglight on together with turnsignal light
Is this a "Feature" of the car or a malfunction? So many cars now have the annoying (dangerous IMO) feature of the headlight switching off when the indicator switches on.
Maybe it is a Cuvèe
