Penpusher
Everything posted by Penpusher
  1. I'm in the same position as my wife's Russian (she's totally anti-Putin and fully supports Ukraine) and we're visiting her family and friends at the moment. We've visited her aunt in Belarus previously, but there's no chance of going there this year. In the UK, I keep on having to convert distances to kilometres for her. It keeps my brain active, I suppose!
  2. I've got the KPH display on the speedo, but by changing the settings in MaxiDot, the cruise control can be set in KPH. If you don't change it, you'll have to convert KPH to MPH each time to correctly set your speed. Some are easy to convert, such as 50 KPH is 30 MPH, but others such as 40 or 70 KPH are not equal to a round figure in MPH.
  3. I've changed the display from MPH to KPH for the speed, but I've retained miles for distances. I can better understand, for example, a distance to our destination on the navigation in miles than kilometres. I can work out quickly miles to kilometres and vice-versa in my head as I was an accountant for 46 years until I retired in 2017, so I was used to mental arithmetic all my working life! I started taking my car to France and beyond in 1971 and we didn't have kilometres on the speedos back then.
  4. So far I've covered about 4,500 miles driving on the right hand side of the road since June and haven't noticed any difference, though my 70 year old OAP brain may not be as receptive to any small changes as a younger driver may be.
  5. You may be able to recoup a little of the cost of replacing your headlights by selling your RHD units on Briskoda or eBay. I went on a trip to Croatia in June and I'm currently in Lithuania, both trips being in my RHD Superb. I haven't had a problem with the radar and its worked fine when I've needed it, so maybe you don't need to do anything with it? I've used it for both cruise control and traffic jam assist without noticing any difference to using them in the UK.
  6. I've already bought a UK magnetic sticker and used it last month for a trip to Croatia. It's still on the car as we're off to Lithuania next Thursday to visit SWMBO's family and friends. Diesel in Poland is currently about £1.38 per litre, so I'll arrive with an empty tank and leave with a full tank which should help to minimise the impact on the pension fund!
  7. Could you leave the boot closed, fold down one of the back seats, put her into the boot through a back door and then put the seat back up? Would she be a little nervous if you but her in the boot and then she sees a large tailgate coming down towards her?
  8. I can confirm this as I'm currently on the French Riviera and every time I start the car it informs that the lights are adjusted to driving on the right.
  9. This is a problem for me in most cars on sharp left hand corners, but I just duck down lower to get a clear view under the mirror to see where I'm going.
  10. I'm fine with seat in my car. I'm in Croatia at the moment having driven from the UK and I've had no problem with driving for a long distance, although it was in legs of about 6 hours per day. At 70, it's enough driving in one day as we're usually on the road for 7 hours or a bit more with delays for road works, congestion, toilet breaks, etc. I start off the day with the seat in my memory position and sometimes make fine adjustments on the journey so I'm not constantly in the exactly the same position, but can always return to my preferred settings at any time. That's an advantage of the electric seat and it also gives you very fine adjustment to get in precisely the right position. It can take some time to find exactly the right position. Like irc, I'm the only driver, so the seat and mirrors are only altered by me.
  11. Have you checked with the local Police Station as the key may be handed in there if someone found it? It's probably a long shot, but it may be worth an entry on somewhere like nextdoor and offering a decent reward, say £50, as that's a lot less than paying for a new key! Make sure you don't disclose your address though, otherwise you may lose your car as well as your key!
  12. My most recent fill up last week was £1.49 (€1.67) per litre for diesel. I was in Slovenia though and it'll be back to UK prices next week!
  13. I know the top ones on the hatch are easy to remove and refit as I've done this when I've been trying to stop them catching on the front rubbers. They simply clip over the rubber seal underneath and when you take them off, you will see a flange that they will fit over when you go to replace them. I'm not sure about the V piece on the rear door of the hatch, but it looks similar to the piece at the rear of the combi window around the load area, but you don't have this on the combi back door anyway. I'll order them from the dealer as I don't know anywhere else that is likely to stock them.
  14. The map updates for Columbus come out every 6 months and I'm currently on maps for 2022/23, which came out last month, so yours are well out of date. I updated them before our trip to Croatia that I'm current on to hopefully cover any new junctions, roads, etc. In about 5 months from now, the 2023 maps will be out. You'll need to download the update onto SD or USB and then press the update when it's loaded and can be read and updated. There are plenty of threads on here explaining how to update the maps and overcome common problems.
  15. Mine's a hatch, which is a different design to the combi but I've had the same problem over the years and have been pushing the chrome strips back on both sides back whenever they've come loose. Just over a week ago I was on the Dover-Calais ferry and the nearside must have come loose when SWMBO was getting in the car as we going along the French motorway about 15 minutes after starting our journey when there was a metallic noise from the nearside. When we stopped for our first night, I discovered that the top chrome strip had gone and the V section at the end of the door was bent, so I'm going to have to replace these. I can only assume the wind got behind it and pulled it off as we gathered speed. I can't blame SWMBO for not noticing if it'd come loose as I opened the door for her. I may have missed it as it was noisy on the car deck and the light was poor. I hope a new chrome strip will fit firmly on the rubber as I'm worried that after pushing the old one back many times, the rubber strip will be tired and not hold it properly. I think the chrome strips are just an interference fit, so they shouldn't be too difficult to replace. We're in Croatia at the moment and won't be back for another week when I'll look at the problem.
  16. I have the same problem and find it's not the easiest place to clean with its knobbly finish. The MkII was better as I could lift it out to clean it in the sink without having to dismantle the entire centre section. So much for improvements on the MkIII!
  17. My windows are always the same after every wash, but a polish with a glass cleaner clears all the water and dust spots. I washed mine yesterday and will polish the windows and car today ready to go away next week. At 70, washing and polishing the car in one day is too much for my old bones!
  18. That makes sense. If you were driving along and accidently touched a button for a very tall or very short person and the seat stated moving forward or back to the extreme of its travel.....
  19. We use ours to run a cool box that held upright with a bungee strap. It's especially useful at this time of year if we go shopping in Merthyr Tydfil at Tescos, Asda, etc as it's a 20 mile journey or when we go away to keep drinks and food cool. We simply turn it in or off by plugging or unplugging it as needed. Could you do this for your fan as I'd have thought you'd be opening the tailgate to let the dog in and out anyway?
  20. I wasn't offended and I'm sorry if my reply sounds as if I was! I'm only too pleased to chat with people like yourself about these topics and issues.
  21. I run on Vredestein Quatrac Pro, which are all season tyres. I find these are adequate for the weather we receive here, as it's often wet and below 7c, even at this time of year! I retired in 2017, so I no longer commute and I don't need to use the car if the weather is bad. I live within walking distance of the town centre if we get snow. Nowadays it's quite rare that I'm driving in the dark or before 9.00 am when the roads are more likely to be affected by bad weather.
  22. I agree with what you say, but if you applied that rule rigidly you'd never be able to rotate the wheels to even out tyre wear if the rear tyres had to be the ones with more tread on them. The front tyres weren't very old and I haven't been far since with lockdown, so there's not much difference between the front and rear tread depths. As I mentioned previously, the rear tyres were fine regarding tread depth, but were starting to perish and splits were easily visible. With two trips to Europe by car coming up soon (to Croatia and then Lithuania), I want the everything to be in tip top order before I leave. I don't swap to winter tyres as we don't have the bad weather to warrant them. Last winter, we didn't have any snow, apart from on the mountains, and the roads were unaffected. I know that winter in Finland is completely different; I went there once in winter and spent from Christmas to New Year in hospital in Helsinki with pneumonia!
  23. I'm replacing my rear tyres and I'll ask the tyre depot to rotate the wheels so that the new tyres will be on the front. The rear tyres are starting to perish rather than being worn as they've only done 30,000 miles but are 6 years old. I'd have probably worn them down to the limit if we hadn't had Covid and lockdown. They'd ordered the tyres I want and they were due to be changed on Thursday last week, but when I got there and they looked at the tyres, they realised they'd been sent 18" tyres, but mine are 19"! Luckily they looked at the new tyres before taking my old ones off the rims.
  24. Mine was registered in October 2016 and it's only covered 30,000 miles so far (I've hardly used it over the past two years with lockdown). I had the cam belt and water pump changed last year when it was 5 years old as I wouldn't want to take the risk and leave it longer, although it's not cheap but as it's only every 5 years, I'll have changed the car before it's due again. The rear tyres on the car are the originals and they're starting to perish so I'll need to change them very soon. The rubber cam belt could have be going the same way. We're planning on two trips abroad by car this year; next month to Croatia and to Lithuania in August. I wouldn't want to set off on these journeys with any niggling doubt over whether I should have ignored service recommendations. Also, as I had the work carried out at the main dealer, I have European breakdown cover for a year and if the cam belt or water pump broke, I'd expect a hefty contribution from Skoda.
  25. Thanks for the above and I've read about Wet and Forget and I think I'll try it. There is some algae around the garden to shift, but on the car I have algae on the door seals. One of the reviewers of the product says they've removed it from their door seals with this product.
