Everything posted by Danoid
- Sunshade on parcel shelf not working
Washer Funnel Cap Difference?
Tried ringing local Skoda dealerships no answer..., so I rang a VW dealer and neither of those numbers would show up, so it's definitely a Skoda part. I rang a different Skoda dealership today and sounded like I disrupted a family funeral moment, but the chap couldn't see the difference and has ordered in the 6V0 number for me to have a look at. I'm starting to think the 6V0 number is the part number for cars which have it fitted as standard and the 000 number is the "accessory" part number, and for some reason means a difference price as 000 comes with instructions on how to fit it etc. I'll do anything to save a couple of quid haha
The part number should be inside the flap from what Iāve seen. The dealer I rang never bothered to call back so Iāll ring another
What did you do to resolve this the first time? Iām not sure how they work but Iām guessing theyāll be a cog somewhere which has broken a few teeth maybe? Id also lube it to death with silicone lube spray and see if that fixes it, if it does then youāll need to see if you can apply a grease for longer term fix, if nothing is broken that is
Show your dirty superb!
Haha, youāre not wrong. It did fit okay for a cheap Argos one when new, but over the years it has become less and less effective. I used a pair of marigolds and much better now, though still not brilliant. Iāll be buying a hatch bag if I ever find a job š
As title says, show your dirty car inside or out, it's no fun if you say it's dirty and it's spotless. I'll start with showing where Your Highness (my dog) sits, yummy!
Both those prices are from ETKA, which is confusing. I've rang my local dealership up but couldnt get through to the parts department so left a message. I'm hoping they'll see if they can see the difference, they might even say they can only get the 000 number in which case I'll ring a VW dealership for the 6V0 number. I'll update should anyone ever be bothered about saving £3.98
Does anyone know the difference between 6V0 955 485 (£5.02) & 000 096 706 (£9)? Yes yes £3.98 Both the same part physically, is 6VO a generic VAG number and 000 is Skoda? I know this isn't designed to fit on the Superb or at least the TDI's but worth a punt if I can get it for £5.02
Fixing the fuel line rattle in 5 mins for £1
Where did you place the pads? Struggling to understand where, though I did find this, which looks like the official fix albeit for a VW https://static.nhtsa.gov/odi/tsbs/2014/SB-10069579-2280.pdf Did you put the pad inside the circle in the attached photo?
I read it a few times but confused, where exactly do the pads go? In the second picture does the black bracket need to be removed or lowered then you place the pad on top then put the bracket back into position?
H8 LED fog replacement bulbs (without dash warnings)
Try and stick to a lower Kelvin rating for the LED light otherwise when you use the fog light as intended itāll be crap when penetrating fog
Online Map Update
You could get really geeky and set up wire shark on a laptop and see exactly whatās happening when your car tries to get the update when connected to your own WiFi, but you shouldnāt have to do that. I have literally too much time on my hands right now but I have a 2016 and not Skoda connect so I canāt test this out myself
Online Map Update
Only customisations should be in car setting so take some photos of your settings. It is a pain but at least youāll know for sure if it works or not
Online Map Update
Ah thatās dirty, I assume youāve done a full reset of infotainment for hits and giggles just to eliminate that?
Online Map Update
I believe thereās an option to select which country to update, try selecting a small country and see if that updates rather than do all at once. See what this crazy guy does at 58seconds deselect all countries bar one then try
Online Map Update
Two reasons, 2.4ghz travels further (handy for if car is on the drive) and second was Iām not sure whether the WiFi in the car can do 5ghz, if it can then great but if not be best to make the laptop be the same as the car can get for timings
Online Map Update
What happens when you press download anyway? Iām guessing you connect to your home WiFi and sit in the car for at least 1 hour (depending on home broadband speed)? I donāt know how the online update works but first thing Iād do is have a laptop (connect to 2.4ghz network not 5ghz) in the car then download the file from their website and see how long that takes, that way youāll roughly how long you need to leave your car to do the update
Screen washer jets
I've just looked and not on mine. I believe when you open the bonnet on the right hand side there's is a pipe wrapped but just below that should be where the wiring harness is, but on mine it's just a long flappy rubber nipple thing.
Online Map Update
Where did you buy the Skoda connect subscription? If itās your local dealership Iād go back there and ask for a refund. Failing that Iād go to Twitter as thatās negative publicity for them which theyāll sort it out I bet. Annoying youāll have to do that but itās the way everything has been for years now, a bit like when people complain to a company and nothing gets done, the people then go to watchdog then magically things get done
Screen washer jets
Is there a way to tell if you have heated jets without taking one of them off?
Brake pad confussion
Also, if you go onto the likes of eurocarparts when you click Fitment detail it'll say 1KU etc. Whats weird though, is my front brakes are not listed on my data sticker, but as I have the 190ps tdi it'll be 1ZA, but I agree it's far too confusing for something which should be simple
Ah, sorry I did read you meant brake pads and I listed the disc sizes. Have a look here https://www.bremboparts.com/europe/en/catalogue/skoda-superb-iii-estate-3v5-2-0-tdi/000115168-1 You can see the brake system pn on the right. When I do my brakes it'll be going with Brembo, purely because their discs are coated by the hub, so no more rust. Are your rear brakes in a manky condition? I was advised to change because of scorning etc but what I done was drive around in Eco for ages as you don't get the engine breaking so you brake more which cleans it up, obviously this wears everything down a tad but if your pads are thinning then driving in eco isn't going to help at all
Have a look at your data sticker in the boot, do you see 1KU, 2EM, or 1KZ? I believe if you have like the 280ps Superb then you'll have 1KZ which is 310mm vented, if it's 1KU then it'll be 300mm solid disc
Need a rear light Unit following breakage
Personally Iād ring Skoda to get a price then make the other car owner pay for it. Make a quick document to say something like on this time&day bla hit my vehicle, bought a replacement light and consider the matter closed so no insurance. Both sign a copy and job done. You should not be out of pocket unless you were in the wrong when you parked
