Everything posted by AnnoyingPentium
Recent pics of your fabia for no reason, just stick em up!
I have indeed. Both threads actually! You should do something unique to it (seat retrim???)
It is a stunning bit of kit though!
Hi
Welcome to the forums, Levi!
Hello
Welcome to the forums, Phil!
At speeds above 80km/h the power steering stop working, at consistent speeds above 110km/h some of the electronics stop working and the ABS and Braking red warning lights come on.
I didn't check mine with a multi-meter so I can't help there sadly, but possibly on a continuity setting? Yes, I used a nail file with mine on the end that connects to the body.
Have you checked your batteries' ground connection (between battery and front wing area)? Make sure it's clean. That was the issue with mine, but also check this DFM wire too - I can't provide help there, sorry. I hope you can get this sorted!
AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
Okay, so if any of you people follow me on Instagram (link in signature) then you'll know I've made some purchases which will be posted on here.
Photography Thread
Taken along the A713 near Parton last night from the window of a moving Dacia Duster. Just used my phone, a Samsung Galaxy S7 to take the photograph. I was a passenger, before anyone panics.
Hello!
Welcome to the forums!
Stupid ME
Very true. Nothing has ever been straightforward with mine, learned a lot though!
European Road Trip Car Advice
I haven't got an Octy so I can't provide solid advice. This thread may help a little bit, if I've read it correctly... I knew someone with a Race Blue 2.0 TDI vRS and it seemed nice externally, but I was never in it nor did I drive it. Good luck with buying one!
Suspension Service
As Wino says, check the cap. My 1.2 has the cap exposed and I imagine yours will too.
Stupid ME
These cars keep more tabs on you and your financial situation than the Secret Service!
Stupid ME
Don't have to let it hear you. The bloody things are psychic - they also know when you have money...
Stupid ME
Mine has done 55,000 miles and belonged to an older gent so everything OEM (had presumably original front discs up until May-ish) is choosing to die currently. Next on the list is some new bushes as it creaks like hell and I live in the speedbump county.
Stupid ME
Fitted new stereo = wheel bearing needing replaced, added alloy wheels = bad ground caused electrical spasm and dodgy accelerator pedal position sensor. I believe in your theory.
Ayup from Sheffield! 😜
Greetings
Welcome to the forums, fellow 1.2 BME owner!
Hello from Croatia
I ended up with the rear view mirror coming off in my hand (leaving the bracket), you just turn it 90 degrees from centre and fit it that way - the solution I mention is on these forums somewhere.
How'd you manage that one?
Windows 11
My i7-2600k isn't supported either. It'll be a miracle if my computer is about by 2025*! *not saying that they don't build 'em like they used to, but my 1995 Toshiba Satellite T2130CT laptop (among other Toshiba laptops I have accumulated of a similar vintage) is working very well to this day.
