Kodiaq Armoured
Now, how will it cope with a MANPAD?
Power steering warning light
I wasn't going to get that from your OP due to lack of information.
barn find felicia pickup.
I can imagine <shudder>. I'd suggest taking the thermostat off the block and opening the lower hose at the radiator, then flushing reverse flushing the radiator and flushing the block with a hose until the water runs clear.
- W8/Superb interior light question
When reversing up a hill, car can smell.
Not what I was thinking then, which is most likely to occur with a small petrol and a PDK.
- VW Caddy mk2 (Felicia) Pick-Up 1.8T
Which engine and transmission?
Smokey
I had the flexible section of the downpipe on mine go porous, with similar effects to you describe, at least if the smoke has a diesel smell.
the truth about electric cars
So, apparently, were trams, but trolley buses have the ability to change lanes...
oil overfill
But only when the sump is within -1l to "stupidly overfilled". Below that you may well not get oil on dipstick.
Changing to RHD
No; the speedometer must display in MPH or MPH and KPH.
Cite needed.
oil overfill
I don't care if the label on the bottle says "VAG 999-99" or not, as long as that meets or exceeds the old 502.00 specification.
a "Tesla Blivet"; a one off, based on a Tesla Roadster, presently in a lowish Earth orbit around 315 miles high.
Not just a question for EV drivers, just any members on here. What temperature do you set your cars interior to be at?
Usually 18C, unless the car has climate control with a lower actual temperature.
Front springs for 2.0 tdi laurin and klement.
Clean the unbroken spring, and look for some dots of paint to establish the spring code. Buy 2 springs to that code, and Robert will be your father's male sibling.
Cooling system issue
That is exactly my point; you're describing design behaviour for a VAG fascia gauge, and actual behaviour from the OBD readout relating to the underlying temperature. It's not broken so don't spend out on trying to fix it!
Doug's 2018 Sportline 272 hatch
HO!! You messin' Jimmi?
Well, IMO you are stressing about a non-problem. Water temperature does not remain as fixed at $value as VAG "temperature" gauges would have you believe,
Skoda Octavia mk3 rear exhaust/back box
A Skoda main stealer seems likely.
Bonnet Silencer ?
"Sound deadening" rather than "silencer". Never had the panel detach itself though.
oil overfill
From reading 1..9 above, you have consistently assumed that the TP69 is actually draining ~3l of oil, despite the lack of any evidence (in your testimony) that this is actually the case.
New car owner, please help me understand the difference
Fair point, but if you can't be bothered to say where you live in metadata you can't expect $nation specific advice?
Also @LightE I can't remember the standard number 😞 but a BSI kite marked pen gauge can be obtained for about £5,
The difference between the first and second row (and also the 3rd and 4th) is that they are pressure recommendations for different wheel diameters.
