Coolant G13 vs AF12+ - mistake ?
Yes. Look for a stain where water has come out (usually from a pipe, the radiator, the water pump or the thermostat housing. I could show you, but you'd have to pay an open return air fare from Glasgow to Stansted and a day car hire for me.
OBD reader
Paws4Thot replied to mikefelicia's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanComments inline, italic.
They're intermiscible but make sure any future topups are the later spec. More to the point, where's the leak!
Would 6.5J x 16 ET46 Octavia wheel fit 2020 Karoq
Maybe? Which trim and engine do you have, because the brake disc size varies?
Air conditioner buttons not lit or working
Throw it back to the mechanic with the words "You broke it; you fix it! Where's my free courtesy car while you're doing so?"
Used Karoq SE or Sport line
Well, a "Sportline 1.5 with 19-inch alloy wheels" will have a teeth chipping and osteopath pleasing ride.
Manual gearbox oil change
Well, technically they are correct. That said, from about 40_000 miles the effective viscosity of the gear oil starts to rise, and you may achieve lower power losses (hence better mpg, gear shift quality and acceleration) with a change. This is more marked with an automatic, to the extent that it is a service recommendation from ZF Transmission,
Doug's Race Blue VRS wagon
That'll be it!
My Car Does Not Stop/Brake Automatically When A Car stationary In Front Of Me
H*11 NO you are not the only person thinking this!
Intermittent windows controls + rear door not locking drivers side.
Answers inline, italic font.
Octavia 2 Heater Hose
If it's a moulded hose (which it sounds like) a parts factor or a main stealer.
No Drive to Wheels
One word; differential . If one driveshaft is now effectively disconnected, you'll get no drive to either wheel.
Beeping on hard acceleration
Frankly no. There is a traction control light that would flash.
Two annoying and unusual faults. Help appreciated.
That covers a lot of territory; are you any nearer to Maud?
the truth about electric cars
..."meat". I know vegetarians who dislike "vegetarian meat", at least in part because they dislike the texture of meat rather than on any ethical grounds. I actually agree with them and will ignore vegetarian "burgers" and "sausages" on a menu as "not food" but will happily order something like, say, mushroom chilli, cheese sauce pasta... In the same vein, I would dislike an electric car with "simulated ICE engine sounds" (and dislike ICE cars with simulated engine sounds too).
- Skoda Estelle Rapid 1988 Water Pump
1.4 tdi greenline boost leak
Almost certainly yes. And if you had a boost leak on a TDi black smoke.
Advisories
Bushes or pins first. Then the rack and yes I'd get a garage to supply and fit an exchange rack. Then tyres. And finally alignment, which would need doing after the other suspension work anyway.
Knock on rear suspension
Exhaust back box I think.
Post a recent picture of your car
@RichardStandard10 My best suggestion for the fan would be a search for Kenlowe (note spelling) and Skoda 130 (since the Estelle and Rapid 130 have lots of common parts).
2013 fabia vrs
Which will only give us the place and approximate time of first registration; There may be something like 8_000 vehicles with those details.
Long list of fault codes detected
Check the battery is correctly coded into the car; If that's wrong it could explain all you reported codeds.
- Mirabelle - A thing of beauty
