headlight bulb upgrade
That would be the best legal method.
2006 Fabia no power
An Autel is not a VCDS or even an OBD II.
All 4 brakes binding after pressing the brake pedal
This might seem off the wall, but do you get similar symptoms with the clutch?
3rd party key cutting
Not a recommendation as I've never needed this doing, but most branches of Timpsons will do this for less than a main stealer.
- Citigo power steering & ABS/EPS LIGHTS
Octavia mk2 estate suspension questions ?
In the first place I wouldn't replace the dampers because they don't control the ride height. What I would do is investigate the rear suspension for broken springs, probably up at the pig ears.
the truth about electric cars
OK, I'm only 4'22", but I've yet to find an SUV (hydrocarbon or Scalextric) that I find easier to get in and out of than a Superb. I can say that a Kia Niro (EV) will not let me sit behind myself comfortably.
Driver side window not working
Put the parts cannon away! Does the window make mechanical "not playing" noises when you press the switch? If so, I'd suspect the window regulator.
Superb 2.0 140 BHP - Hesitation when cold
Best shot would be to check whether the Throttle Position Sensor holds a constant position under acceleration.
- Will a 19" wheel be too big?
Cooling system problem (AGAIN) in my Felicia
In the only expansion I've ever heard of it is "Back To Base", so returning a Skoda to Czechia.
- Shock Absorbers -Question
2006 Fabia no power
Maybe not then; when my TPS went, the (diesel) engine went into limp mode but would still get to 40mph.
2006 Fabia no power
@L98 Ok, has the car shown a slight hesitancy to pick up out of corners (maybe 1 or 2 s) when going back onto throttle? If so, the throttle position sensor may be failing but not yet gone.
@Thefeliciahacker @D.FYLAKTOS What you have just proved is that Felicia temperature gauges are not truly calibrated. Time to spike this thread maybe?
Dashboard Warning signs
Ignore; these can vanish by next year ( or sooner; I once had an advisory on fuel tank check straps in Dec year 1 (fail) and not mentioned in Jan year 2 (pass). I probably shouldn't have even seen the fail certificate.
Leaking oil on driveway
OK- This is more probably engine oil than transmission. All this proves is that you've not lost sufficient oil to activate the idiot light. The oil drips from probably engine, maybe transmission, onto the drip tray and then runs off, so where it appears is irrelevant to where the leak is.
EPC and engine management light. Car not pulling/accelerating
NO! I can tell you that it is a fault that has thrown an EPC code and put the car into limp mode. I'd need fault code(s) to go any further.
Include the "average journocritter" here.
Fabia driving very slow
Also @L98 I was going with information from ZF Transmission that you should change ATF about every 4 years or 48_000 miles. I mean what do they know about automatic gearboxes? (other than more than I do)
As requested?
Pretty sure it's a torque convertor 4 speed auto. My first suspicion is that it's low on ATF, but after 90k miles it needs new fluid. The bad news is that I'm not clear how to drain it and refill it. You will get all the information you need from Erwin.
Recovery services, good or bad?
Never had AA or RAC. OTOH Britannia Rescue have been pretty good. One recovery I'd have liked to be quicker, and one where they achieved a turnout time of "I was still on the phone to the call centre and passed it to the recovery operator". 5 minutes later I was on the way down the road.
Looking of getting another skoda (Superb Estate 2025) advice please
As already discussed it'll ride better, and have fewer issues with being jarjared with emissions gear and with LEZ Zones.
Rim size
Well, the tyres are markedly different sizes. We need to know the full wheel sizes which are literally cast into the insides of the wheels.
