Weird Audi A6
OK, it was badged (and styled) as an "Allroad" model, but it was also slammed right into the weeds. I only got a glance so no registration.
Once again owner of a Skoda!
Start with a linkage alignment procedure. Look in our Guides subforum and/or on YouTube.
flashing coil light
@Kcook Any chance of you posting actual diagnostics rather than just "light sometimes comes on"?
help Skoda Fabia
As @UrbanPanzer says above, with the note that this means a diagnostic tool capable of changing settings such as OBD II or VCDS.
4 wheel drive control box
Ok, when you quote something you should see a double indented line saying something like "So long ago, $Usertag said:" on a pale grey background. Below that you should see whatever you're quoting single indented on a paler grey background. This text will all have a medium grey line down the left side. When you get to the white area below the greys, type your reply there.
1.4 TSI twincharger oil spec - VW 502.00 vs 504.00
Well the only intrinsic "benefit" of 5W40 over 5W30 is that the viscosity of 5W40 changes more slowly with increasing temperature. There is no direct relationship between viscosity and a VW 599.00 specification.
Skoda octavia 2022 how can I turn off seatbelt chime in rear seats
Did I say that you do?
You are aware that the passengers are breaking UK seatbelt law if they're not wearing their belts? I'm not sure you can do what you want, but suggest pointing out that they're responsible for their own fines.
Rear door won’t unlock! Mirror motor won’t stop!!
Not a chance IME. The wire snaps inside the plastic sheath, so you need to get a continuity tester in at the individual wires. Never seen that one with the door mirror before, but the mirror controls are usually passenger side, both sides and motors off.
That's what I expected. I'm now at least 99% that you have a broken wire in the bellows to the driver side rear door.
When your car is being serviced etc, would you expect your car to be covered by your insurance or the garages/dealers?
I'll also use @$usertag to credit or reference someone (second person) when actually addressing a third person.
Odds on you have a broken wire in that door. Does the window winder work?
Mk2 skoda fabia tdi 1.6 Monte carlo
Easy peasy if you have halogens; just match up the type code and your registration on a site like Powerbulbs. Beyond that, is there any chance of you writing in sentences and maybe even paragraphs rather than just flow of consciousness?
I'm inclined to say that the owner was partly at fault, tor taking a decent car to Halfrauds for service!
Abs light
Ask them how they would bleed brakes on a VAG car. If the answer doesn't involve a scan tool, say "I'll get back to you" and hang up.
Oil ? - Petrol engine
Apparently yes.
ECU removal
Jackanory, Jackanory...
Bleed breaks skoda fabia 2003
That's for brake line unions, not for bleed nipples.
Emissions
@Clarkypainter @Breezy_Pete In any event both CO and CO2 are colourless gases, and not the "black smoke" that the "new MoT station" supposedly measured a value for.
Actually, further thought occurs. If you contact a competent tool factor or motor factor (so not Halfrauds) and tell them you want a "brake bleed spanner" they will probably offer a 6mm/7mm single hexagon ring spanner.
How to fix ghosting/fading around badges?
Not really; it's more that the red paint has faded everywhere except under where the badges were. This is a well known issue with red.
@Natalie1982 As these guys say, you need a 7mm spanner for OEM bleed nipples. I would recommend trying to find a single hexagon (6 points only) ring spanner for this job because it's unlikely to slip and round off the head.
Brake pedal becomes slow to return
When was the brake fluid last changed and the system bled? Get a different manual; I've never owned a car with disc brakes that didn't have a servo.
Offside/Nearside Front Suspension arm pin or bush Skoda Octavia
Both or either one or neither, depending on the level of wear in the swivels.
Correct Tyre Pressure?
He may be correct; 36PSI is sometimes the maximum pressure for $brand tyres.
