Paws4Thot
  1. You said it first. After all, we can't comment on Brand_X tyres unless we know what they actually are, and they will literally have something like "Yingtong Ditchfinder 265/40R19 S79H" written on them for you to copy. Similarly the standard wheels will literally have full size data cast into the rims.
  2. Note types contemporary to when this happened; I was booked "A Rover 400 or similar", got to the hirer and was offered "A Rover 400, an Au'tin Montego estate or a Ford Mondeo estate". I took the recently introduced to market Mondeo.
  3. No problem. I should have said to get the kind where the height is adjusted by pins rather than screws, but the difference is obvious when you see them.
  4. Ah well, cheeri Andreas.
  5. One (or 2 since they're usually sold in pairs) axle stands would be better; this is a wheel(s) off job if you have to replace the sensor or its wire.
  6. Or a Fraud Fester, Fix It Again Toni 500...
  7. Which is why I asked; I've had aquaplaning at 3mm left on 205/55R16s. That makes that tyre borderline at best.
  8. You haven't said what size (particularly width) it is, but I'd reckon aquaplaning to be a real possibility.
  9. Serious answer; I won't get the same sort of experience of sexism as you will.
  10. I'd love to give you a recommendation but am male and don't live anywhere near you.
  11. No idea why; I've had gap insurance before without needing to supply my DoB.
  12. Ding ding ding ; We have a winner (somewhere between "Don't know" and "Are sexist idiots").
  13. I don't think so; you're wasting your time with that garage though.
  14. When was the last oil change?
  15. Thanks Natalie; I've added "check PAS fluid level within limits" to my list of "cheap and easy checks".
  16. This is one of the reasons why you have a handbrake.
  17. Was the expansion bottle labelled "mit silikat" before the investigation and not afterwards?
  18. Well d'oh!!! You're changing from D into N, R and then P, and the car reacts, especially when you select R!
  19. You should be able to see the switch and press it through the handbrake lever hole. The console is held in place by screws, but I can't remember where they are on the Fabia.
  20. As Pete says except that you can get the alternator exciter wire pulling off the contact without breaking. Been there, done that; Knew the base problem and had the car in the local garage at 08:00, back repaired at 17:20, and bill was ~£20 for 30 minutes work (minimum charge),
  21. The 1.9 Di should fire and run even with bad glowplugs, as long as you'll take a puff of white smoke on start up.
  22. @Skezza The Golf/Jetta 5 is more closely related to the Octavia.
  23. Well, the ABS light will almost certainly throw a fault code you can read with VCDS or OBD II, and the most likely faults relate to the wheel sensors, so the brakes will work normally unless you're on a slippery surface. If it's not a wheel sensor, it could well be low voltage for the ABS control unit. The handbrake light staying on might well be the switch being adjusted too low so that the lever doesn't press on it. You may be able to see that down the side of the lever.
  24. @Natalie1982 When the PAS light was coming on, were you also seeing the battery light flickering, even dimly? @Breezy_Pete may well be right about the strip fuzes (but what is a heic file?) OTOH it might also be a bad power connection, or a weak alternator or battery. I'm guessing a bit here, but would advise that a good auto electrician will help; in particular they'd deep load test the alternator and battery for free conditional that they got the business if either needs replaced.
  25. I don't know that this is the case but the throttle potentiometer could be slowly dying.
