Everything posted by Shuggyboatsuperb
Fuel filter
Your best bet is to look for the part number painted on the outside of the fuel filter holder/ outer canister then trace / cross reference correct filter element to the canister. There will be a few different options fitted at the factory - not worth guessing which.
Any way of disabling this auto braking?
Oops - apologies. And assumed it may be switched off at the same time / same system.
It can definitely be turned off in the car settings menu ( I think under manoureing? But cant remember for now exactly which setting, sorry ) Absolutely a pain - Have to switch it off when reversing boat trailer ( when trailer electrical plug is removed) otherwise the car thinks its going to reverse into a stationary object and slams the brakes on every time the car and attached trailer move a few inches. Bugger of a job the first time I used this car for the task till I realised a bit later what was happening - 10 mins and only 10 feet further back! had to be done every time though, its not a permanent reset.
Fuel filler. Adding a bottle of additive troubles
No funnel is supplied to fit past the anti syphon device in the fuel pipe ( unlike some Fords etc.) is yours petrol or diesel? might need to use something like a flexipipe that comes with a 5 litre spare fuel can - either the correct petrol or diesel version to fit - theyre different - and pour the additive in through that. some additive bottles have a long straight nozzle of the correct diameter to fit into the fuel pipe in the car ( look at Forte diesel additives for example) - but not manyπ³
Just jumping in on this, apologies: this is the marine grease I prefer for outboard engines and boat trailer hubs etc ( after trying many over the years). It doesnt harden with time like some do, and very resistant to washing off or emulsifying. Will use this when the time comes on the Skoda bushes: ( Quicksilver being the consumables brand from Mercury/Mariner): https://www.marinechandlery.com/products/mc-2-4-c-grease?variant=48267389993307&country=GB¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&srsltid=AfmBOorX6Q1P0HsUSziSSXj_NoxjZ8rn_uQE0T5OAcWqkgdWFle_mkiNhf8
Battery coding
Maybe not so cheap, but will do battery coding and electric handbrake service release/ reset as well as a load of fault code reading. Might pay for itself once used a couple of times? Mine has! https://m.gendan.co.uk/product_FXNT530VAG.html
P029900, Turbo Charger Under boost
@MunsterScot βI reset the code and put some Forte Advanced Diesel Treatment and Forte Diesel Turbo Cleaner in the fuel and ran it for a while β Above is a great tip - have used other Forte products many years ago and always good results. Just ordered the twin pack for Β£23.39 on ebay to use as preventative maintenance on my steadily driven diesel. (It usually gets filled with Esso supreme or Shell V power to try to help keep the internals clean but this Forte stuff can only help. )
Automatic V Manual Transmission - And does manual have assisted driving features same as auto
Equally I could say : Bit of a dumb concept to buy a car with a known weakness such as many of the DSG gearboxes, could I not?
My SE diesel manual has ACC. Works well especially for steady driving ( as opposed to in traffic). Obviously, if for example following a lorry up a long incline and speed reduces significantly, you may need to change down a gear, but when ACC is set, this gear change is done without touching the throttle- the computer adjusts the revs nicely on depressing and releasing the clutch. Very smooth. Same when βover the hillβ and you need to change up again. I dont do much town/ city driving in the Superb so any βbenefits β of DSG auto in stop/ start town driving arent useful to me. personally, I went for a manual because of the need to sometimes manoeuvre slowly and accurately in reverse with a ( boat) trailer attached, and I feel a manual box and my clutch foot give much better control. I also believe the manual box to be dependable and more reliable - even more so since joining this forum and seeing so many DSG auto tales of woe.
I've been mugged off, haven't I. The service never happened!
I agree totally with battery and wiper suggestions above: they are basically just (long term) consumables so why subsidise main dealer prices: For wipers I now buy Ebay. 10-15 pounds for set of 3! Original rear wash was poor ( till later on I opened up the jet slightly with a mini drill bit) and the rear wiper creaked from new. Mentioned at first service- no interest- fobbed off. After 18 months I bought a genuine replacement rear wiper from dealers at about Β£25. This one also creaked and skipped. when at the second service the report suggested I needed a new rear wiper I nearly flipped. Politely explained it was a nearly new one from their own parts shop and no way would I ever put another genuine Skoda blade on. The Ebay cheapo bought afterwards has never creaked or skipped. Try batterymegastore.uk or Taynabatteries for a new battery (Yuasa or Varta) delivered at less than half the dealer price - maybe even an improved AGM type for that, and get it coded locally for a minimal price ( and fitted locally if needed).
What Is This?
Yup, its the radar sensor, vital part of the ACC system. (Correct alignment of it has to be done with specific dealer equipment as far as I know )
Superb 3v3 axle bolt torque spec
Could mean something as simple as βbrakes onβ. Or held / locked in some way ?
36 inch x 3/4 inch breaker bar and 3/4 inch x24mm 12 point socket on hand should I ever need to do these bolts- then I need to find a stronger or heavier person or two !
Rear brake part numbers.
About to embark on Skoda ownership, Superb L&K Estate
Both parts are needed- both the rubber with 4 βbarbsβ that pushes into the car as your part, then the hard plastic insert with βpinβ that pushes and locks into this rubber to lock it into the car ( if available).
Superb Rear Park Pilot
My 2020 - same experience as Nicknorman - tried reversing boat trailer onto slipway ( electrics disconnected) soon after I bought the car and wasnt aware of all these βsafety?β Systems. Bloody thing kept emergency braking every time I very slowly moved a couple of feet in reverse - it was suspecting I was about to hit this boat. honestly it took 20 minutes to manoeuvre about 40 feet backwards. same when doing 3 point turns on country lanes when it stops me reversing into the thigh-high long soft grass behind. I now know how to turn this β featureβ off.
Spraying of the rear identification mark
Is this not the spray cleaner for the reversing camera fitted just above the registration / license plate - so is best left switched on?
Replacing rear spring on 280 estate
Quoting @Macsamillion βIt looks to be a torx screw in the middle of a nut?β the torx bit you can see is just cast into the inner part of the protruding β boltβ so that if the nut is seized and starts to spin the bolt you can put a torx key in to hold the bolt steady while you undo the nut with a spanner (or straight through socket) with a bit penetrating oil on the nut and the fact theres not a lot of exposed dirty bolt thread, you might get away without holding it with a torx key or torx socket bit.
Spare Wheel kit for 2020 superb sportline plus hatch
Theres a lot of info and advice in several threads: heres one you might find helpful. (Lots of good options outside of / less expense than a dealer) :
Damage to rear bumper and a rear light cluster- Any advice?
I doubt many dealers will have their own bodyshop these days - will contract it out. Likewise most insurance companies would direct you to a manufacturer approved repairer rather than a dealers workshop. try googling : skodaapprovedrepair.uk And see if theres any good ones near you.
- Is this signalling the end of high performance cars
They dont seem to work on the ( often Irish registered) lorries heading along the SW Scotland A75 for the ferry - good job though since the HGV limit on most of that road (mostly single carriageway) is 40 so its not too bad following one of those trucks with a defective speed limiter at 60 ish ( plus a bit!) or so. I firmly believe its much more dangerous when queues are following a truck doing the 40.
Brake disk failure
Similar here, March 2023 at 3 years old and only 20k miles. Outside faces didnt look too bad but shocked at the inner faces. I thought it might have been due to sitting idle for longish periods (like delivered 2 weeks before first 2020 lockdown, long unused spells, and then used only for long weekend trips every 2-3 weeks since) but learnt from this forum it is common at a low mileage for the original discs. replaced with Brembo ( no way was I going to pay the dealer for like for like replacements that might only last another 20k) and they remain smooth and sparkling so far, 10k miles later.
My Car Does Not Stop/Brake Automatically When A Car stationary In Front Of Me
Does anyone else sometimes get this and the accompanying bong when driving on twisty country lanes? The system must think I am about to drive straight on into the hedge or long grass / overgrown verges. Up to now, luckily I have steered into the bend before it brakes for me!
