defsix
Everything posted by defsix
  1. They're wrong. Filter is on the top, looks like a small engine oil filter.
  2. Thanks, are you sure that chart is correct? There appears to be a part number difference between Saloon and Combi even though there are the same part numbers on the individual springs? In Saloon the 02 is for FWD, 03 for 4x4, 04 for DSG ? On the Combi 03 is FWD, 04 is 4x4, 02 is DSG. Assuming DSG is the last line Is the DSG box that much heavier?
  3. I used this place to find the recommended. I also noticed E10-79-012-03 version. I wonder what the difference is?
  4. Why do you think I have a slightly different part number? Estate / DCC / FWD 2.0 190BHP
  5. I fitted EIBACH Pro-Kit E10-79-012-04-22 Suspension kit, coil springs and H&R 55573-15 (15mm) Wheel spacers all round. On Bridgestone Potenza S001 235/40R19. Never had any clearance issues.
  6. You don't recall the post title? Tried a few searches but no results 😩
  7. I've an intermittent fault with my 2020 FL Subwoofer. It the the connection on to the speaker itself or the plug that fails ?
  8. Sunroof or Windscreen adhesive failed. Test with garden hose.
  9. Yeah, i was playing with my seats too. Same result as you. I still think it's the motor that doesn't like being stopped at the extreme position. The controller maybe winding it back as a preventative measure.
  10. I know what I'm looking for now! Thanks!
  11. Yeah, I was surprised to see only one connection being used on the antenna. Cairus suggested an alternate place for the GSM one.
  12. Thanks Cairus, I'll have look there.
  13. Ok, New Antenna installed. A bit awkward to do. Boot seal removed, rear side trims and wedged down the Headliner. I did manage to break the clip that holds the headliner in the centre, but the boot rubber holds it in place. Here's the clips I broke. And the antenna. The antenna was full water. After removing the APEX connector which was very awkward, cleaned roof where it was mounted, there was quite a bit of oxidation. I wonder is the metal of the roof used as a ground plane? Cleaned the connector with Electric Switch Cleaner, the new Antenna was fitted loosely. I checked GPS on sat nab and was getting 7 to 9 of 10 Satellites. So proceeded to finish the job. Now after clearing the faults I am still getting the error on the GSM side. There was only one cable connected to the antenna, so assuming this was the GPS one. So where is the GSM Antenna located?
  14. Let me know how you get on.
  15. I'd read that before. Did you try it?
  16. That doesn't happen in my case at all. Are you saving the profile to the key manually? Have you heard the ping when you save the position on the seat itself?
  17. I never noticed the actual movement 🤔
  18. Yup, I'm the same as you. Ass down all the way. I think the seat doesn't like being sat at the limit of it's position. It always works it's way back up a little.
  19. Do you have the seat at the full lower position? I'm other words at the end of its postion?
  20. Ordered 5Q0035507AH from my local dealer. €104+ VAT I'll update whe it's time to install.
  21. Legendary as always Cairus 😉 Is it just the top part or is there a PCB underneath that corrodes? I was unable to determine with ETKA. I don't suppose you could advise a part number? I think it's either 5Q0035507AH5FQ or 5Q0035507AH VIN TMBKJ7NP2L7006611
  22. Hi, had a GSM Antenna open circuit error for a while. Today I have a GPS Antenna open circuit error too, resulting in no GPS, Partial ACC, and sporadic location on Android Auto. I believe moisture has worked it's way into the Fin. Is this a clean and reseat job or replacement? Can anyone advise on the part numbers? Superb 2020 FL Model Combi
  23. Id be going down a diagnostic route. Check fault codes and report. May give an indication if it's a decide fault, wiring issue or something else causing it. Have you added anything or changed anything on the car recently? Bulbs etc.
