john999boy
Honorary
Everything posted by john999boy
  1. Unless the Fabia is unique, the car can normally store codes for previously used head units. The reply is also being made as part of a Briskoda test.
  2. Please only use English on Briskoda. πŸ‘
  3. Is the dome light switch in the correct position to turn the light on?
  4. I've never heard of that programming coming from the factory and it's not anything to do with the car having an OEM towbar as I can still adjust my AH and also have a towbar. P.S. Maybe update the car details in your profile settings.
  5. Just a reminder and to keep everything fair, referral links are not allowed on Briskoda.
  6. Just press the A button and your wishes will be answered!
  7. The power rating of that socket is more than you'd require for an EV but the cable appears to be just twin+earth. Most EV cables have data too.
  8. I've moved your Ad to the correct place. πŸ‘
  9. Only the offside needs to be working to pass the MOT.
  10. VCDS can be used to make that a single press action.
  11. @edwards May I ask how much and from where?
  12. Looks like it was an additional 8Gb USB stick after all. πŸ˜• Just out of interest @arnold what came on the stick as each supplier normally says the latest version IS NOT included?
  13. I already have one but have to agree that's a very good price that should hopefully be snapped up quickly. Just one thing though, what's the USB stick that you mention? Maybe add a photo?
  14. Maybe time to cut out the unnecessary comments now and stick to things that are relevant!
  15. I think Hue requires an additional hub to allow an app (or hardware controller) to make full use of the bulb. Other bulb options don't require a controller so may be better in the long run.
  16. I've done it on a previous car with a pin. πŸ‘
  17. Thanks for that. My only excuse is that I never go in the rear of the car. ☺️ In saying that, my car may not have it so I'll check later. πŸ‘
  18. Could you be confusing it with a tri-zone (inside) temperature display - which still won't show a clock?
  19. I don't think any cars have had a rear clock.
  20. As George has mentioned, there’s only one thread pinned in this section. πŸ‘ You will then see the other unread posts in order below that.
  21. Ah. Surprised they needed all three keys to service the car. You'll find there's numerous threads regarding fob batteries and their 'new' replacements.
  22. The key fob only has one battery!
