Everything posted by Cairus
Unleashing the Power of OBDeleven: A Must-Have for SKODA Owners
Yes to Support it... You need the document that describes the channels. This list might help: https://www.t4-wiki.de/wiki/Messwertblock
Annoying Android Auto behaviour via dongle
Which HW & SW Version have the mib 2 Unit?
Which vehicle did you use to read the data? Felicia? Back then, there was another list showing which channel was which; even the workshop with the factory tester didn't see that. OBD11 can't be blamed for that.
No SFD 2 / UNEC Car
- Ambient light options/coding
Skoda Octavia 2019 reverse camera
The only things you get from Skoda are expensive plugs and an expensive reversing camera.
Which Car? Skoda released the SFD 2 protection at most two months before the EU deadline. I've had plenty of MY24 vehicles without SFD 2. I can tell you exactly if you send me the VIN via PM. The Kodiaq 2 and Superb 4 were exceptions. Regarding a diagnostic tool, what features do you want to be able to use? For data set and firmware flashing, I definitely recommend VC Tool. For everything else, Car Scanner Pro is sufficient. OBD 11 costs a monthly/annual subscription. VCDS is too expensive without VIN restrictions. VCP costs an annual subscription if you want the latest version. VC Tool also costs money, monthly/annually, but offers the most features. It requires a VAS 6154a dongle.
Octavia 2014 Bolero MIB1 to MIBx
Sorry ist no Plug & Play solution
Mib 2 Retrofit is now Plug Play solution
You have To Change Display, Unit, Unit must be patched. It depends on where you buy the parts, but you can expect to pay between €400 and €1000. This depends on whether you choose MIB Low or High, which display, etc.
- MIB3 Amundsen (MOI) - maps are not updating
OEM Skoda, No Problem High Version : Part Number: 5Q0980568B Connector Camera T8t/8 = Blue = Orange/Brown ---> Car Side T12g/12 = MIB 2 T8t/4 = Yellow = Orange/Violett ---> Car Side T12g/6 = MIB 2 T8t/1 = Red = KL30 = SC18 = 7,5A = Red/Blue Wire T8t/5 = black = KL31 = Ground = Brown T1d/1 = White = Video Signal = T12j/6 = MIB 2 T1d/2 = Black = Video Signal = T12j/12 = MIB 2 No warrenty
Drivers door won’t open
I remember that problem from my Octavia 2 days. What always helped me was to lock and unlock the door repeatedly, while firmly tapping under the door handle with my fist and changing its position.
Skoda Octavia Mk3 Combi 5E5 – Third Brake Light Replacement Guide Needed
Only German Link Activ until 12pm https://mega.nz/folder/4zMQBRAB#un-JU5fvB0ARzapC8DAdXw
You have MIB 2 Low or High?
a small project
One step forward. Door connector replaced, cable pulled through, test connection in vehicle with new door connector.
CarPlay crackling issue, software update fix?
As I already mentioned in another forum, his 2022 Kodiaq no longer has long-term coding in control unit 09, the BCM. Everything there is set to 0. Additionally, please note that you cannot view the coding in any system using a VIN. Only with ODIS and server access can you perform an SVM comparison.
- Mib 2 - car icon change
Okay, let's give a detailed answer. You'd have to use the ToolBox to create a dump, then decrypt the encrypted file that manages the image files. There are hundreds of individual images, and all of them would need to be replaced. A colleague of mine has a VW unit in a Seat and spent a total of three months manually replacing these individual images.
Amundsen MIB2 randomly restarting while driving
Reflash Firmware, Unlock Developer Mode, SWDL Download
- Blind spot assist retrofit
"Move selector to P position and visit workshop" after retrofitting heated steering wheel
Simply replacing the steering wheel does not change the coding of control unit 16. Of course, if you replace the control unit because you are retrofitting a heater, then the coding must be adjusted again.
