Everything posted by Cairus
DCC Slider adjustment option mod
What does the file have to do with the fact that the colleague is looking for someone who can do it for him? And Odis, vcp are Not the only Tools which can write Dateset
Volume won’t change and I’ve got this in my settings
Have you tried factory reset?
MY17 Superb Retrofitted with Direct TPMS
Share a Autoscan Protokoll
Amundsen MIB2 Firmware Update
MEGAMEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB nowPassword write PM
- Blind spot assist retrofit
MiB 2 coloumbus infotainment system frozen, buttons and touchscreen don’t work
- Broken door grab handle
It could certainly have been repaired more attractively and better. But our 2019 Kodiaq is also on its way.- MiB 2 coloumbus infotainment system frozen, buttons and touchscreen don’t work
The unit is probably defective. MIB1 /mib2 units are unfortunately prone to failure.- Blind spot assist retrofit
- 73 Plate Superb Est, TSI 4x4 S/A: 2 questions please.
Regarding the wind noise, check if the seal where the door rests is properly installed and supple.- enable Traffic Sign Recognition with VCDS
- Seat memory wont "chime" on manual calibration.
He dont belive us- VCDS Help: High Beam Assist
For 5Q0 Control unit 09 > Access authorization: 31347 > Adaptation > Channel "Assistance lighting functions - Menu control High beam assist" > Set value to "present" Control unit 09 > Coding > Byte 02 > Set bits 0-2 to "03 Bi-Xenon headlights with Light Assist" Control unit A5 > Coding > Byte 02 > Set bits 0-7 to "01 coding_Light_Assist High_Beam_Assist"- I have some issues/questions with my BCM
How High is the voltage- Seat memory wont "chime" on manual calibration.
You have a Tool for Firmware Flash?- Seat memory wont "chime" on manual calibration.
You need a Update- I have some issues/questions with my BCM
Why you Dont say that? Check the voltage with the multimeter Directly when a second Person Start the Car- I have some issues/questions with my BCM
Is the Error Directly after Start the Car?- I have some issues/questions with my BCM
Which SW you installed in the Radio?- I have some issues/questions with my BCM
Ist the Error without this Box?- What have you done to your Kodiaq today?
Buy a New virtual Cockpit- I have some issues/questions with my BCM
IT IS Possible, that the Radio Update is the solution nur No warrenty from me. Ist the Error after Radio Update, Flash BCM
