Cairus
Everything posted by Cairus
  1. Fw 0253T https://mega.nz/#P!AgEDeRWdGttRAsXCXNEvOYEm17bDYWmmCzT6PSQ-j8N-pb8V3EhGv0DeiL_wgPndDwA67vYcMJnYzgwns09MczzMVhqv0hy801-YQ74oYN-C2_fJM3WJuwxAafcWEp8FrbTCBOUC9FI
  2. Green Error Code is a Not Activ Code
  3. Unit 19: Hardware-Nummer 3Q0907530BA Hardware-Version 542 Software-Nummer 3Q0907530BB
  4. Unit 16: Hardware-Nummer 5Q0953569F Hardware-Version 100 Software-Nummer 5Q0953521MG Software-Version 0275 Seriennummer 20240124500556 Lange Codierung 6404 Unit 13 Hardware-Nummer 2Q0907819 Hardware-Version H03 Software-Nummer 2Q0907567B Software-Version 0534 Unit 09 Hardware-Nummer 2Q0937090F Hardware-Version H15 Software-Nummer 2Q0937090F Software-Version 0982 Unit 03 Hardware-Nummer 2Q0614517CB Hardware-Version H20 Software-Nummer 2Q0614517CP Software-Version 0120 Unit A5 Hardware-Nummer 2Q0980653A Hardware-Version H19 Software-Nummer 2Q0980653G Software-Version 1505
  5. So, i found Kamiq 2023 with ACC on my Server...
  6. I did make one mistake, though. I apparently had a different car in mind regarding ACC without unit 16. Scala will have it as soon as ACC is available. Sorry for my incorrect information on this. MP?
  7. You have the Connection between?
  8. You have the Controller R242?
  9. I know, my Password... SwaP ACC solution
  10. https://mega.nz/#P!AgBDv0fNLhDxADcVZB4_YlmHhQZ4FzDlKVVLJZ4J64bj0iKdPPC3lwi1Bjj76OsGsBB_5rsKwWSm7tEOWP4nUOVGRQcEQVyPZnAaxR5aUACdAbSObK06Jg
  11. https://ovoko.de/gebrauchte-ersatzteile/hst271614-skoda-octavia-mk4-sonstige-steuergerate-module
  12. https://forums.ross-tech.com/index.php?threads/42131/
  13. You know that the Scala and Kamiq without ECU 16 also have ACC? However, you have a BCM that has the gateway integrated, probably mid-version. I think this is the Problem
  14. I now have the opportunity to regularly work on an MQB EVO. First, the thermal fog lights and daytime running lights... If somebody Like To des: NHTSA Properties Limitation Dependency Speed Threshold NHTSA Limitation Switches for Android Auto without Video Playback On NHTSA Limitation Switches for Android Auto without Text Input Not On NHTSA Limitation Switches for Android Auto without Voice Input Not On NHTSA Limitation Switches for Android Auto without Setup On NHTSA Limitation Switches for Android Auto with Limit Display yed_message_length On nhtsa_limitation_switches_for_carplay_no_softkeyboard d On nhtsa_limitation_switches_for_carplay_no_softphonekey ypad Not On nhtsa_limitation_switches_for_carplay_limit_nonmusical Lists Data in Real-time Not activated NHTSA_Limitation_Switches_for_CarPlay_Limit_MusicLists not activated Long coding NHTSA_Limitation_Switches_for_CarPlay_No_IAPAN Adaptation Not activated
  15. BMS and Gateway. The BCM has nothing to do with the car's energy management in the direct sense. It is a command receiver for the gateway and deactivates comfort features when necessary. Therefore, the battery sensor and alternator are sub-participants of the gateway. If the battery sensor fails or delivers implausible values, a permanent charge should be carried out and a message should appear in the vehicle
  16. Control unit 09, also called BCM, adjustment, then take the appropriate light
  17. And I can tell you, even without a data set for start-stop or with normal battery settings in the gateway or AGM, my mqb vehicles at home, there are 3 of them, not over 14.6V... you can also drive completely without start-stop parameters, you can also remove the fake recuperation and the Maximum is 14,6V
  18. you have to edit the driving profile selection in the gateway data set and reload it into the gateway
  19. At 14.8V, I'd be concerned about the control units. At 100% demand from the alternator, it shouldn't be more than 14.6V.
  20. https://drive.google.com/file/d/1Gnr75jfpnEC9fyfNLqYGYfYROt20dOXr/view?usp=drivesdk
