Cairus
Everything posted by Cairus
  1. Octavia 4 But you need the Ground plade from Octavia 3
  2. OBD11 and Carista will not receive an SFD 2 license from VW.
  3. Due to the change in the mirrors, the LED part number has also changed: 5E6949145 5E6949146 This should clarify which mirrors are being installed.
  4. I recommend upgrading to a navigation unit, HW4. You can Patch IT own With the HW2 Bolero unit you have, you can activate Smart Link, but it runs somewhat sluggishly. And you have To Open the Unit for the Patch I have an HW4 Bolero unit at home, fully unlocked and working perfectly. It just needs to be coded to the vehicle. Where are you from?
  5. Wrong Information But you need the correct people and Money
  6. Mib3?
  7. Oh the old 5Q0 Interface... 😜
  8. And 2 Warning LED each Side ^^
  9. Since when is it possible to access all partitions of the emmc via QNX?
  10. Why 3V0035816K? This is kamiq/Scala Not for 9,2" Screen
  11. You are Welcome You have a Link from your AliExpress parts?
  12. I check my documents for the parts Numbers
  13. 3.11 GB file on MEGAFirmware 369T
  14. Die Steuergeräte sind komplett, der Kabelbaum auch. Der erste Außenspiegel komplett zerlegt Die anderen Teile für OEM Retrofit in den Außenspiegel sind im Zulauf. Gestern habe ich am Tisch die Steuergeräte aufgebaut. Firmware sauber neu geflasht auf beiden und einen für mich vermutlich passenden Datensatz aufgespielt. Der Octavia 3 hatte nie die 2Q0 Steuergeräte verbaut, dadurch gibt es keinen originalen 2Q0 Datensatz dafür. The control units are complete, as is the wiring harness. The first exterior mirror is completely disassembled. The other parts for the OEM retrofit in the exterior mirrors are on their way. Yesterday, I assembled the control units on the workbench. I cleanly reflashed the firmware on both and installed what I believe to be a suitable data set. The Octavia 3 never had the 2Q0 control units installed, so there is no original 2Q0 data set for it.
  15. There is no official solution for the clock problem in your firmware. The only solution, also listed in the Digital Elite forum, is a cross-flash to a VW firmware, which addresses the clock issue. Then the Skoda HMI needs to be flashed. Only attempt this yourself if you know what you're doing; otherwise, you risk bricking your software.
  16. Your Part Number have this Features: 7UF Navigation system - Standard I8D Standard radio (Gen1) 7UH Preparation for navigation system (MIB) QH0 Without voice control QV3 Digital radio reception QH1 Voice control ER1 Regional code \ ECE \" for radio"
  17. Amundsen MIB 1 with DAB&MOST Possible Firmware 0490 You have Soundsystem?
  18. Wrong Information 85% the GPS Antenne is damage. You can check it With a good Diagnose Tool by unit 75
  19. Did you drive all positions to the limit? Control unit have kodiaq Dataset?
  20. Unit is from Kodiaq?
  21. Which Part Number have The Controller unit?
