Chronic problems with Amundsen ICE in 2016 Octavia SE L TDI
Sounds like diagnosing it without a proper fault code scan is going to b just guesswork, you need someone with OBDeleven or VCDS to do a full scan for you I believe.
VED and Car List Price
What VED did you pay in March 2023 and March 2024?
Michelin Crossclimate 3s
I fitted a full set of Goodyear Vector 4 Seasons Gen-3 in October and been really pleased with them. Cope really well with icy mornings and standing water, and lower road noise than the Continental summer tyres fitted before.
thinking of remapping and slapping a cold air filter on my 2015 fabia 1.2L
The factory air intake takes cold air in directly from just behind the grille, so I don't think changing to a "cold air intake" will be of any noticeable benefit. The only time I've found a cold air intake to be of benefit was on a Citroen C1 where the factory intake ended inside the bonnet directly above the exhaust manifold so in summer it took in less dense hot air. Adding a reinforced flexible hose to a convenient hole in the grille noticeably improved performance on hot summer days.
Dynamic Road Sign Display - Please Clean the Windscreen
I had this last week when the auto high beam also stopped working, I cleaned the area of the windscreen where the camera is and on restarting the next morning both were working correctly again.
ACC error
A Google image search shows it's behind the solid block in the centre of the upper grille below the Skoda badge on a facelift (i.e. 2017 onwards) Mark 3.
ACC error
On the pre-facelift Mk3 the radar ACC sensor is in the middle of the lower front grille, not sure about the facelift like you have.
- Window wipers
- Window wipers
OBD2 Tool
I've owned genuine VCDS for over 20 years, and it has paid for itself many many times over with saved garage diagnostic costs as well as tweaks to my own cars plus I've helped many other VAG owners diagnose and tweak their cars - plus even a colleague with a Lexus using OBD mode. The help I've received from the experts, both professionals and fellow enthusiasts, on the Ross-Tech website has been key on a few occasions to understanding the sometimes strange descriptions that VAG choose for faults and their gathered decades of knowledge. So for me not having access to that support is not a choice I would make or suggest to others.
- OBD2 Tool
aftermarket wheels thread
Then I would expect significant wheelarch rubbing.
What is the PCD? - Octavia needs 5 x 112. And what is the centre bore? - Octavia need 57.1mm You also need to check the overall diameter and the offset/width combination won't cause rubbing. Best to use a tyre size calculator, there are many online.
Orange triangle
Not on UK spec Mark 3's where it's permanently live. I believe other markets have a fuse that can be moved to make the 12V socket ignition switched.
Orange triangle
I used one during Covid lockdown to keep the battery topped up, just plugged into the permanently live 12V socket in the centre console.
Permanently disable A.C.T ?
Changing the timing belt on the 1.4ACT and 1.5ACT needs special tools and takes much longer than the non-ACT versions. For this reason the normal cost for a ACT belt change is around £900, how much did they charge you and are you confident they had the special tools needed by the ACT versions?
What year did the software issues stop ?
Some of the VAG engines are actually designed by Skoda (the 3 cylinder ones IIRC), and all of the VAG software (whether it's used on VW, Audi, Skoda, SEAT, etc.) is outsourced to third parties. The only difference is how much time and money each 'brand' spends on getting the software problems fixed.
Orange triangle
TDI or TSI, manual or DSG?
Orange triangle
Would be helpful to know model year, and what engine and gearbox you have.
- Window wipers
Are factory fitted Octavia IV batteries AGM..?
Most Skodas are factory fitted with EFB batteries not AGM batteries, cost saving!
Difficult conversation: L&K TSI 190
I have a 2016 L&K with the 1.8TSI and DQ200 DSG gearbox, there's no way I could describe it as sluggish.
- Dsg 1.0 tsi Octavia
Dsg 1.0 tsi Octavia
Same here but with a 1.8TSI, just leave your left foot on the foot rest and use only your right foot on brake and accelerator. I live in an area where I have to do lots of hill starts and find the few seconds while the car holds the brakes on for me is plenty enough to not need to either select N (with stop/start the engine turns off so there's no concerns about clutch slip) or use the handbrake. I only use the handbrake (along with P on the selector) when parked on a slope. Very occasionally, mainly for smiles, I tap the selector back to D/S which switches the DSG to Sport mode that holds lower gears and increases the rpm point for upshifts. Then just tap the selector back to return the DSG to Drive mode.
How to start a new categorie
How many people would read the sticky? Almost on a weekly basis people are posting in the wrong forum on this site for their car. I've reported many posts for being in the wrong forum so admins can move them to the correct forum so they get advice from owners of the some model. I don't see how a 4.5 forum or sub-forum will help this situation?
