Traffic red lines no longer showing on Sat nav
I doubt it, neither of the Octavia Mk3's I've owned have any online connection so they can't access live traffic data by any means other then the now turned off Trafficmaster TMC.
DSG repair costs-should skoda pay
If you don't mind me asking, who by?
2818 ŠKODA Octavia VRS TDI just bought
Sounds like time for a new 'other half'
Turbo blown?
Could be one of many reasons, you need a fault code reader to make any sensible guesses without that it's just speculation.
Parking pawl not engaging
I had the handbrake fail once on my previous manual 1.4TSI, I came out of the shop to find my Octavia 'resting' against the rear bumper of the car in the parking space in front - no damage to either car.
1 UK gallon = 4.54609 litres but 1 US gallon = 3.78541 litres
recharging the battery?
Yes, it's the serial number that tells the BMS a new battery is fitted. If you don't change the serial number then the BMS will assume the old failing battery is fitted and is likely to start turning off systems to protect the old battery that's no longer fitted.
2018 ŠKODA Octavia VRS TDI VCDC lead
Not on any VAG vehicle without SFD - which the Octavia 3 (like your 2018 model) doesn't have.
You'll need to get an adaptation done because you're fitting a new battery. The CCA isn't something the BMS knows about and the difference between 68AH and 70AH is so small there's no need to change the AH details so all you need to do is change the serial number - just change 1 digit that's enough.
Computer Glitch?
Anyone with VCDS or OBDeleven or similar can do it - no need to visit a dealer.
Computer Glitch?
Also worth clearing any codes that indicate an ancillary has been shutdown for power saving reasons, if there are any, and any codes on the seat memory and infotainment system - some codes are 'sticky' and will affect the operation even after the root cause has been solved until the codes are cleared.
Wing mirrors
Yes IMHO provided the time between post and bump is "reasonable" i.e. more than a few hours.
Mk1 vrs new exhaust, holding back
No, some mods don't affect certification but others like removing the cat do.
SatNav SD card not loading?
Not a very bright dealer, as that's the map SD card for a MIB1 Amundsen as fitted to an early Octavia 3. I suggest you post in the Octavia 2 forum and ask how map updates should be done https://www.briskoda.net/forums/forum/28-skoda-octavia-mk-ii-2004-2013/ *Edit* Some surfing shows that if you have an Amundsen it will be an RNS310, so you need an SD map card for an RNS310 not a MIB1.
The likelihood of passing an MOT with a decat is very low, and removing the cat on a car certified to need one (which a Mk1 Octavia is) then using it on the road is AFAIK a moving traffic offence which is why plod would be 'interested'. We're not trying to make you a nervous wreck, just making sure you understand the legal niceties of deleting the cat on a road car.
What sat nav system do you have, the SD card requirements vary? Is the SD card for your system not a later MIB1 or MIB2/2.5 system as fitted to an Octavia 3 (a 2011 Octavia is an Octavia 2) - the maps are different between them all.
Amundsen Mib2 Map Updates 2024
It the VAG naming convention: In late Spring they issue maps that cross over 2 years, so this year it's 2023/2024 maps. In late Autumn of the year before they issue maps for the next year, so in Autumn 2023 they will issue 2024 maps. The year naming of the maps doesn't indicate when the map data is frozen, for example I moved into my house on my new build estate in April 2022 (other residents moved in nearly a year earlier) but the 2023/2024 maps still don't show the road that I and nearly 60 other houses are on!
- 98 replies
- amundsen
- discover media
- maps
- mib
Tagged with:
TMC traffic events no longer being received...firmware update required?
I've been using the 2024 maps with my MIB2 Amundsen for a couple of weeks and it's made no difference - TMC is still crossed out.
VAG no longer issue map updates for the MIB1 systems fitted to the Octavia until 2016, when questioned they admitted that they only issue map updates for the MIB (and similar) systems for 5 years after they are no longer used in production. It is the MIB systems that they class as end-of-life not the vehicle. If they follow the 5 year rule then map updates will no longer be available for the MIB 2 and MIB2.5 systems after around 2025.
Correct, I took my MIB1 Amundsen equipped Octavia 3 to France many times and each time it picked up French TMC data and displayed it correctly - even if the data was not totally up-to-date (on one road it was a year out of date!).
Computer Glitch?
Is it an AGM or EFB battery, and has the car been coded to tell it a new battery has been fitted? If not it could still be load shedding to protect the old battery!
Timing Belt Change
IIRC the Octavia 3 1.5TSI was only ever sold as the ACT version, but as you say toot it's very important to mention it's the ACT version especially when talking to a non-Skoda dealer.
French TMC data will only be looked for when the GPS signal shows the vehicle in France, so I think this was an interesting but ultimately pointless test.
False Loss of pressure warning pops up
TPMS analyses the pattern from each WSSS not just the speed, so something on the rear hub is causing an irregularity in the WSS signal - like stickig caliper, failing wheel bearing, etc. You say you swapped the tyre, I'm assuming wheel and tyre not just tyre?
KAROQ 2018 front discs
A different MOT tester might not even mention them... Unnecessary "upselling" of replacement discs and/or pads has been commonplace for many years.
